Pamac cli crashed updating with error zsh: terminated pamac update
I was updating to Stable Update] 2026-02-23
I opened Konsole and run
pamac update --dry-run
I got no error so I then run
pamac update
it was downloading qtsomething, the message
was appended to what it was displaying in that moment.
I was using firefox and it kept working; I had KDE’s system monitor open and I saw the system was still downloading stuff so I let it be, then I clicked on “tools” to check the logs and in that moment the UI froze.
So I did REISUB.
At boot it says can’t load the kernel etc (it can’t load any kernel that I have).
I have timeshift’s snapshot so I booted on of those, I still haven’t taken any steps in fixing because maybe having the system in this state can help troubleshooting the issue.
I was told to post my inxi -zv8 so here it is.
  Kernel: 6.19.0-rc7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2026-03-02_20-47-26/@/boot/vmlinuz-6.19-x86_64
    root=UUID=ecbc0f71-e2df-4c2c-85a1-b83c7000eab8 quiet splash
    udev.log_priority=3
    rootflags=compress=zstd:1,subvol=timeshift-btrfs/snapshots/2026-03-02_20-47-26/@
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
    wm: kwin_wayland vt: 1 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop System: Gigabyte product: AB350-Gaming 3 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: AB350-Gaming 3-CF serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: F52i date: 02/09/2023
  System RAM: total: 16 GiB available: 15.54 GiB used: 3.04 GiB (19.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 2933 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3000C15-8GVGB serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001138
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1550 min/max: 1550/3200 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1550 3: 1550
    4: 1550 5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550
    bogomips: 76649
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
    lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
    svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Gigabyte driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: DP-3,DVI-D-1,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 48.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4480x2520
    display-ID: 0
  Monitor-1: DP-1 pos: bottom-r model: MSI MAG274QRF-QD serial: <filter>
    built: 2023 res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2
    chroma: red: x: 0.694 y: 0.298 green: x: 0.212 y: 0.725 blue: x: 0.149
    y: 0.047 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1080, 1680x1050,
    1280x1024, 1440x900, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  Monitor-2: DP-2 pos: primary,top-left model: Dell S2721HS serial: <filter>
    built: 2021 res: mode: 1920x1080 hz: 75 scale: 133% (1.33) to: 1440x2560
    dpi: 82 gamma: 1.2 chroma: red: x: 0.639 y: 0.337 green: x: 0.314 y: 0.624
    blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 ACO DRM 3.64 6.19.0-rc7-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.335 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 25.3.4-arch1.1
    device-ID: 1002:67df surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.19.0-rc7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 2.96 TiB used: 2.09 TiB (70.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B7QCXE7 temp: 35.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD1002FAEX-00Z3A0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
    scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: MSI model: Optix Driver size: 22 KiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 1.1 spd: 12 Mb/s
    lanes: 1 mode: 1.1 tech: N/A serial: <filter> fw-rev: 1.00
  ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
    used: 45.95 GiB (19.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: ecbc0f71-e2df-4c2c-85a1-b83c7000eab8
    used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 710D-A3C4
  ID-3: /home raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
  ID-4: /run/media/acca/CaviarBlack raw-size: 931.51 GiB
    size: 931.5 GiB (100.00%) used: 794.93 GiB (85.3%) fs: exfat dev: /dev/sdb1
    maj-min: 8:17 label: CaviarBlack uuid: E4DF-8089
  ID-5: /run/media/acca/CaviarBlue raw-size: 931.39 GiB
    size: 931.39 GiB (100.00%) used: 920.14 GiB (98.8%) fs: ntfs dev: /dev/sda2
    maj-min: 8:2 label: CaviarBlue uuid: 225EF70B5EF6D68F
  ID-6: /run/media/acca/Mx500 raw-size: 931.51 GiB
    size: 931.48 GiB (100.00%) used: 379.57 GiB (40.7%) fs: exfat dev: /dev/sdc1
    maj-min: 8:33 label: Mx500 uuid: 59F3-5281
  ID-7: /swapp raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
  ID-8: /var/cache raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
  ID-9: /var/log raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -1
    file: /swapp/swapfile
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-2: 1-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0
    chip-ID: 058f:6254 class-ID: 0900
  Device-1: 1-2.3:3 info: Micro Star MSI Gaming Controller
    type: HID,mass storage driver: hid-generic,usb-storage,usbhid interfaces: 2
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 1462:3fa4 class-ID: 0806 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Turtle Beach REACT-R type: <vendor specific>
    driver: xpad interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 10f5:7018 class-ID: ff00 serial: <filter>
  Device-2: 3-3:3 info: Trust GXT 833 Keyboard type: keyboard,mouse
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 145f:02b0 class-ID: 0301
  Device-3: 3-4:4 info: Razer USA Naga Mouse type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:0015 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 49.5 C mobo: N/A gpu: amdgpu temp: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 796
  Packages: 1380 pm: pacman pkgs: 1370 libs: 344 tools: pamac pm: flatpak
    pkgs: 10
    1: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    2: https://manjaro.ynh.ovh/stable/$repo/$arch
    3: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    4: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    5: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    6: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    7: https://manjaro.grena.ge/stable/$repo/$arch
    8: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 378
  1: cpu: 100% command: ps pid: 3668 mem: 4.09 MiB (0.0%)
  2: cpu: 23.5% command: firefox pid: 1806 mem: 629.0 MiB (3.9%)
  3: cpu: 18.3% command: firefox pid: 2349 mem: 519.1 MiB (3.2%)
  4: cpu: 6.9% command: kwin_wayland pid: 1009 mem: 193.0 MiB (1.2%)
  5: cpu: 2.8% command: firefox pid: 2267 mem: 429.6 MiB (2.7%)
  Memory top: 5 of 378
  1: mem: 629.0 MiB (3.9%) command: firefox pid: 1806 cpu: 23.5%
  2: mem: 519.1 MiB (3.2%) command: firefox pid: 2349 cpu: 18.3%
  3: mem: 486.2 MiB (3.0%) command: plasmashell pid: 1237 cpu: 1.8%
  4: mem: 448.8 MiB (2.8%) command: firefox pid: 2132 cpu: 2.0%
  5: mem: 429.6 MiB (2.7%) command: firefox pid: 2267 cpu: 2.8%
  Processes: 378 Power: uptime: 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Anything I can do to help in finding the issue I’ll try, just ask
Well then fallback to a robust workflow:
pacman-mirrors
  • If Green then skip the next step.
sudo pacman-mirrors --fasttrack --api --timeout 3 && pacman-mirrors
  • if Green, then carry on. If not, let us know.
sudo pacman -Syu
Following that, up to you…
pamac upgrade --aur
any issues, just go with:
yay
after that you could just run pamac again to see if it’s cleared up.
Please see this advice from the Stable Update thread. :backhand_index_pointing_down:
This is great…
I actually use the Ghostly notifier now (i.e. Octopi - but it looks like a Ghost) and it is set to open a terminal when updates come in.
Though I’m more likely to pre-empt this by running my hideous abbreviation anyway.
First ‘mirrors’ runs ‘pacman-mirrors’ to check, then ‘mup’ updates them…
abbr mup 'sudo pacman-mirrors --fasttrack --api --timeout 3 && pacman-mirrors '
Simply typing ‘up’ after that runs:
sudo pacman -Syu && pamac update --aur --devel && flatpak update
Well, octopi is a wrapper around pacman, and if you know the Pacman game:backhand_index_pointing_down:
… then you’ll understand where the appearance of that icon comes from. :wink:
I would suggest follow what @Ben posted as it looks like your system has not been updated for awhile.Your still using Kernel: 6.19.0-rc7-1-MANJARO arch and plasma is still on KDE Plasma v: 6.5.5.
Your point is probably valid, but I think stable and testing branches are still on KDE Plasma 6.5.5.
Not from that screenshot.
Hold on, I’ll dig out my Amiga 500… I played this all night - with the music (stereo no less) turned up loud enough to annoy the neighbours.
It was fully updated, I’m on stable.
More issues.
pacman-mirrors
It only had loke 5 mirrors and only 1 was OK
so
Added a ton more
sudo pacman -Syu
It started downloading and installing, got to 299/350 (it was SMP IIRC) and the pc froze. After 10 minutes I used REISUB, now I could not boot from the latest snapshot, I had to go 1 back.
Should I try yay? Should I check someting else before?
Should I “fix” my system before updating?
I think this is correct, right?
sudo su
install-grub
update-grub
grub-mkconfig -o /boot/grub/grub.cfg
If you can actually use the System Requests, then your machine is not frozen, because those are direct one-key kernel commands. In other words, the machine was just being very slow, possibly due to a stuck process that was hanging up the others, or due to a bottleneck situation.
No. yay is a wrapper around pacman with access to the AUR.
Yes, but you can do it in one go… :backhand_index_pointing_down:
You mean just
[ -f /var/lib/pacman/db.lck ] && rm -f /var/lib/pacman/db.lck
pacman-mirrors -f && pacman -Syyu
update-grub
exit
I don’t need to chroot, right? My pc has booted from a snapshot, I’m not using the live usb
If you want to repair your system, then you do need to chroot from the snapshot. On the other hand, if you’re going to roll back the snapshot, then it’s not needed, but then you must first reboot into the restored system.
I’m getting so tired of this, I have another thread open in this same sub, everytime I update the OS breaks.
Now I booted the live usb and chroot in my system, I had to use
SKIP_AUTOSNAP=1
to have it update, It did, still couldn’t boot, chroot again, tried installing and updating grub, now it wont show at boot, it boots but the screen stays black with no GUI.
ctrl+fn or ctrl+alt+fn (I tried with FN key pressed too since it’s a multimedia kayboard) doesn’t bring me to a tty.
I’m tempted or reinstalling and never update again :face_with_diagonal_mouth:
I do appreciate that you’re a little frustrated, but with regard your comment – in the first instance "reinstalling ", we would then be obliged to close the thread without a solution – and in the second “never update again”, you would no longer be eligible for Support via this forum.
Quick tip:
I note that Octopi was mentioned earlier as a replacement for pamac-manager (Add/Remove Software) – further to that, if you use the AUR I’d suggest also installing yay, as Octopi uses that to handle the AUR instead of Pamac.
I am very frustrated but I’m not giving up easly.
I’m trying to have grub to show again, so I chroot, tried updating (nothing to do) so
update-grub
Found linux image: /boot/vmlinuz-6.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.19-x86_64.img
Found linux image: /boot/vmlinuz-6.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.18-x86_64.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
grub-probe: error: cannot find a GRUB drive for /dev/sdd1.  Check your device.map.
Detecting snapshots ...
Found snapshot: 2026-03-01 14:00:00 | timeshift-btrfs/snapshots/2026-03-01_14-00-00/@ | daily          | N/A                                           |
Found snapshot: 2026-02-28 14:00:00 | timeshift-btrfs/snapshots/2026-02-28_14-00-00/@ | daily          | N/A                                           |
Found snapshot: 2026-02-27 00:00:01 | timeshift-btrfs/snapshots/2026-02-27_00-00-01/@ | daily          | N/A                                           |
Found snapshot: 2026-02-20 22:01:04 | timeshift-btrfs/snapshots/2026-02-20_22-01-04/@ | ondemand daily | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2026-02-08 12:55:05 | timeshift-btrfs/snapshots/2026-02-08_12-55-05/@ | ondemand       | Manualmente                                   |
Found 5 snapshot(s)
Unmount /tmp/grub-btrfs.gMKrDqyYX3 .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
While trying stuff I got this error:
error: could not open file /var/lib/pacman/local/lib32-gcc-libs-15.2.1+r604+g0b99615a8aef-1/desc: No such file or directory
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
pacman -Syu lib32-gcc-libs
 core is up to date
 extra is up to date
warning: lib32-gcc-libs-15.2.1+r604+g0b99615a8aef-1 is up to date -- reinstalling
warning: could not fully load metadata for package lib32-gcc-libs-15.2.1+r604+g0b99615a8aef-1
error: failed to prepare transaction (invalid or corrupted package)
I tried cleaning the cache and fixing the keyring with
[manjaro /]# pacman -Scc
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove ALL files from cache? [y/N] y
removing all files from cache...
error: could not remove /var/cache/pacman/pkg/download-mwrmCo: Is a directory
error: could not remove /var/cache/pacman/pkg/download-sMBU0o: Is a directory
error: could not remove /var/cache/pacman/pkg/download-inaAMk: Is a directory
error: could not remove /var/cache/pacman/pkg/download-Mr3hPW: Is a directory
error: could not remove /var/cache/pacman/pkg/download-qldgQi: Is a directory
error: could not remove /var/cache/pacman/pkg/download-d7RGpY: Is a directory
error: could not remove /var/cache/pacman/pkg/download-nbJvD4: Is a directory
error: could not remove /var/cache/pacman/pkg/download-cc7xwa: Is a directory
error: could not remove /var/cache/pacman/pkg/download-lgfLKX: Is a directory
error: could not remove /var/cache/pacman/pkg/download-jvr50o: Is a directory
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n] y
removing unused sync repositories...
[manjaro /]# rm -r /etc/pacman.d/gnupg
[manjaro /]# pacman-key --init
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/3DD86DCD26ED24C5C64E3098AA4474596077B488.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
[manjaro /]# pacman-key --populate
==> Appending keys from archlinux.gpg...
==> Appending keys from manjaro.gpg...
==> Locally signing trusted keys in keyring...
  -> Locally signed 23 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
  -> Disabled 45 keys.
gpg: Note: third-party key signatures using the SHA1 algorithm are rejected
gpg: (use option "--allow-weak-key-signatures" to override)
gpg: depth: 0  valid:   1  signed:  21  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  21  signed:  85  trust: 0-, 0q, 0n, 21m, 0f, 0u
gpg: depth: 2  valid:  72  signed:  19  trust: 72-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2026-03-13
but I have the same error.
I tried
[manjaro /]# pacman -S lib32-gcc-libs --overwrite '*'
Fixed maybe with:
touch /var/lib/pacman/local/lib32-gcc-libs-15.2.1+r604+g0b99615a8aef-1/desc
touch /var/lib/pacman/local/lib32-gcc-libs-15.2.1+r604+g0b99615a8aef-1/files
[manjaro /]# SKIP_AUTOSNAP=1 pacman -S lib32-gcc-libs --overwrite '*'
Packages (1) lib32-gcc-libs-15.2.1+r604+g0b99615a8aef-1
Total Installed Size:  45,31 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                                     [####################################] 100%
(1/1) checking package integrity                                   [####################################] 100%
(1/1) loading package files                                        [####################################] 100%
(1/1) checking for file conflicts                                  [####################################] 100%
(1/1) checking available disk space                                [####################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due SKIP_AUTOSNAP environment variable being set.
(1/1) reinstalling lib32-gcc-libs                                  [####################################] 100%
ldconfig: File /usr/lib/libkbookmarkmodel_private.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libkbookmarkmodel_private.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6TextTemplate.so is empty, not checked.
ldconfig: File /usr/lib/libKF6TextTemplate.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6TextTemplate.so.6.23.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6Holidays.so is empty, not checked.
ldconfig: File /usr/lib/libKF6Holidays.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6Holidays.so.6.23.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6NotifyConfig.so is empty, not checked.
ldconfig: File /usr/lib/libKF6NotifyConfig.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6NotifyConfig.so.6.23.0 is empty, not checked.
ldconfig: File /usr/lib/libkonsoleapp.so.25.12.2 is empty, not checked.
ldconfig: File /usr/lib/libkonsoleprivate.so.25.12.2 is empty, not checked.
ldconfig: File /usr/lib/libkpmcore.so is empty, not checked.
ldconfig: File /usr/lib/libkpmcore.so.13 is empty, not checked.
ldconfig: File /usr/lib/libkpmcore.so.25.12.2 is empty, not checked.
ldconfig: File /usr/lib/libQuickCharts.so is empty, not checked.
ldconfig: File /usr/lib/libQuickCharts.so.1 is empty, not checked.
ldconfig: File /usr/lib/libQuickCharts.so.6.23.0 is empty, not checked.
ldconfig: File /usr/lib/libQuickChartsControls.so is empty, not checked.
ldconfig: File /usr/lib/libQuickChartsControls.so.1 is empty, not checked.
ldconfig: File /usr/lib/libQuickChartsControls.so.6.23.0 is empty, not checked.
ldconfig: File /usr/lib/libKF6Runner.so is empty, not checked.
ldconfig: File /usr/lib/libKF6Runner.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6Runner.so.6.23.0 is empty, not checked.
ldconfig: File /usr/lib/libKSaneCore6.so is empty, not checked.
ldconfig: File /usr/lib/libKSaneCore6.so.1 is empty, not checked.
ldconfig: File /usr/lib/libKSaneCore6.so.25.12.2 is empty, not checked.
ldconfig: File /usr/lib/libKF6UnitConversion.so is empty, not checked.
ldconfig: File /usr/lib/libKF6UnitConversion.so.6 is empty, not checked.
ldconfig: File /usr/lib/libKF6UnitConversion.so.6.23.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Sensors.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Sensors.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Sensors.so.6.10.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6SensorsQuick.so is empty, not checked.
ldconfig: File /usr/lib/libQt6SensorsQuick.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6SensorsQuick.so.6.10.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6Designer.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Designer.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Designer.so.6.10.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6DesignerComponents.so is empty, not checked.
ldconfig: File /usr/lib/libQt6DesignerComponents.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6DesignerComponents.so.6.10.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6Help.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Help.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Help.so.6.10.2 is empty, not checked.
ldconfig: File /usr/lib/libQt6UiTools.so is empty, not checked.
ldconfig: File /usr/lib/libQt6UiTools.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6UiTools.so.6.10.2 is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so.6 is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so.6.5.5 is empty, not checked.
ldconfig: File /usr/lib/libkcmkwincommon.so.6 is empty, not checked.
ldconfig: File /usr/lib/libkcmkwincommon.so.6.5.5 is empty, not checked.
ldconfig: File /usr/lib/libkwin.so is empty, not checked.
ldconfig: File /usr/lib/libkwin.so.6 is empty, not checked.
ldconfig: File /usr/lib/libkwin.so.6.5.5 is empty, not checked.
ldconfig: File /usr/lib/ld-linux.so.2 is empty, not checked.
(1/1) Arming ConditionNeedsUpdate...
