Pamac behaves differently on 3 devices (AUR) Related
Hello,
I have created some screenshots where you can see that Pamac shows different AUR info’s on all my 3 Devices, i also made sure all system has the same Pamac-GTK3 10.7.0-1 version installed, i also tried to switch in the past to another Pamac-gtk (which is gtk4) for a short time, but i reverted back to GTK3 since the issue persist.
(PC OLD Pamac works flawless installed at 2020)
(PC NEW Pamac shows to 100% self installed AUR Packages like EDDIE VPN, but
Kirigami no AUR Info, while Lib32-tdb has the AUR info):
(Laptop has the worst Pamac behavior and ONLY shows self installed AUR Packages like EDDIE VPN, but refused to display any AUR Info for outdated Foreign packages):
Both of those packages have recently been moved to the AUR (lib32-tdb on 2026-08-23 & kirigami2 on 2026-08-29).
Possibly you have out-of-date AUR databases on the 2 machines showing those packages as not being in either the official repos or the AUR.
Try refreshing your databases via the menu in pamac’s GUI, or with the following command:
pamac update --force-refresh
Then close & reopen the Pamac GUI & see if the packages are now shown as being in the AUR.
Edit 2026-09-09T02:30:00Z: if refreshing the databases does not work, then try deleting the AUR database first:
sudo rm /var/lib/pacman/sync/packages-meta-ext-v1.json.gz
Then refresh the databases again.
Yeah, thats worked thank you :slight_smile:
