Pacnew warning request
Continuing the discussion from User seems to be deleted:
Just want to note that I got the same problem. The pacnew checker overwrites the passwd file as I click accidentally to get the whole new file. (Thanks to a backup, it was not a massive problem.)
So, maybe the pacnew checker could get a special warning for some files that could prevent the user from login? A warning with something red blinking or a guy that jumps out of the screen and slaps the user before he can click something. Should be a small feature…
:sweat_smile:
Wheel user password “reset itself”, now twice
To fix it there is usually a backup /etc/passwd~. Verify your username is at the end of the file and - if it is - use cp to replace the existing file.
sudo cp /etc/passwd~ /etc/passwd
No - passwords are never reset by an update.
Confused by the presence of a file named passwd.pacnew?
It would happen if you - without giving thought to the process - replace a configuration with a .pacnew file
Never automate .pacnew files - it may wreck your system completely.
Your post has been moved to a dedicated topic.
The question, or rather the responses it may invite, may prove interesting for many newer Members.
I envisage something more like a little green guy who jumps out and slaps a User upside the head for running commands they have little understanding of. :troll: :wink:
I was thinking more of if using a laptop having the lid auto slam shut and break all fingers.The time it takes for the fingers to heal should remind the person to never make that mistake again. :grinning:
Rather brutal, but no doubt effective. :joy_cat:
Jeez, the user complains he has to edit config files, then somebody makes automation and ther complain about that too.
For the lazy and brainless, at the end of the road there is windows, where the user have to make no decisions at all. It auto updates, it auto spys, it auto crashes. No thinking involved.
Stable Updates already have a warning that includes a link to manjaro-pacnew-checker:
As far as I know, manjaro-pacnew-checker offers four choices for a .pacnew file:
  1. Open configuration file and .pacnew file to merge contents
  2. Delete .pacnew file
  3. Replace configuration file with .pacnew file
  4. Do nothing
I use a modified version of a script that only has option 1
Modified version includes request to delete .pacnew file after it has been merged in meld
BASH script to merge .pacnew files in meld · GitHub Gist - nik-gnomic
For some reason both that script and manjaro-pacnew-checker not only go out of their way to not use pacdiff for the actual managing (and thus similarly evade proper use of sudo -e)… but they also actively ignore pacsave files.
This strikes me as straight-forwardly incorrect but maybe there is some undocumented rationale?
Tagging @Ste74 since he’s the developer.
