Pacman will not update database
When I try pacman -Syy or pacman -Syu it says that everything is up to date despite there being packages I have that I know are not up to date. If I try to specifically update them or just reinstall them pacman just says that they are the latest version. I’ve used Manjaro for about a week now and every time I try to update it tells me everything is up to date.
I have no trouble installing things with pacman so I assume it is just failing to update the database. I’ve tried using different mirrors but I still get no luck.
does anyone have any idea why it is not working
It depends which branch you are on. There is a Stable-Staging Update at the moment. Stable should be soon, I would think. You can try to update your mirrors with sudo pacman-mirrors --fasttrack
To see which branch you are on take a look here: /etc/pacman.d/mirrorlist
To switch branches to testing for example: sudo pacman-mirrors --api -B testing
The announcements section here gives a terrific indication of what is going on and any issues that you may encounter. I would recommend reading regularly.
Try it Now… maybe because of this?
Run this and report:
sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu
I tried updating the mirrors to fasttrack which still didn’t work but I’ve just tried the command
which seemed to work and I’ve just upgraded everything and everything seems to be up to date now so thank you for the suggestion :slight_smile:
