Hi, I’ve recently had some issues when trying to run “Pacman -Syu” I’ve looked around for a solution but I haven’t been able to figure out where the problem is, or where to fix it.
when I try to run “Pacman -Syu” I get this as a response:
:: installing alsa-lib (1.2.7.2-1) breaks dependency 'alsa-lib=1.2.6.1' required by lib32-alsa-lib
:: installing alsa-plugins (1:1.2.7.1-1) breaks dependency 'alsa-plugins=1:1.2.6' required by lib32-alsa-plugins
:: installing libcap (2.65-1) breaks dependency 'libcap=2.64' required by lib32-libcap
I’ve looked around, and one way to fix dependency issues, is apparently to use Multilib, so I went to pacman.conf, enabled multilib. Because of that, I get this as response :
error: failed retrieving file 'multilib-testing.db' from ftp.free.org : The requested URL returned error: 404
error: failed retrieving file 'multilib-testing.db' from manjaro.lucassymons.net : The requested URL returned error: 404
error: failed retrieving file 'multilib-testing.db' from mirror.dkm.cz : The requested URL returned error: 404
I looked around, apparently, updating my mirrors is the solution, I tried to run “pacman-mirrors --continent” Which gives me this error message :
::WARNING https://repo.manjaro.org 'Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Read timed out. (read timeout=2)'
::WARNING https://wikipedia.org 'Connection: HTTPSConnectionPool(host='wikipedia.org', port=443): Read timed out. (read timeout=2)'
::WARNING https://bitbucket.org 'Connection: HTTPSConnectionPool(host='bitbucket.org', port=443): Read timed out. (read timeout=2)'
I still can’t run Syuu, and I’m unable to keep some of my packages up to date, it is an issue. Would anyone be able to help me figure this out? Thanks.
