Hello,
I’m having an issue when I try to update my system using pacman -Syu. I get errors stating that my kernel is invalid or corrupted and I can’t continue my updates without deleting it. I’ve had to rescue my system with a flash drive and chroot in the past due to this issue.
Here’s the output when I try to update:
core downloading...
extra downloading...
community downloading...
multilib downloading...
resolving dependencies...
Packages (70) composefs-1.0.3-1 linux515-5.15.160-1 linux515-headers-5.15.160-1 linux515-nvidia-550.78-7 linux54-headers-5.4.277-1 llvm-17.0.6-5 lollypop-1.4.39-1 lvm2-2.03.24-1 magma-hip-2.8.0-2 man-pages-6.8-1 manjaro-release-24.0.1-1 manjaro-settings-manager-0.5.7-22 manjaro-settings-manager-notifier-0.5.7-22 mariadb-11.3.2-2 mariadb-clients-11.3.2-2 mariadb-libs-11.3.2-2 mhwd-nvidia-390xx-390.157-11 mhwd-nvidia-470xx-470.239.06-3 mkinitcpio-39.1-2 mpv-1:0.38.0-4 mysql-workbench-8.0.36-5 ndctl-78-2 net-snmp-5.9.4-4 nftables-1:1.0.9-3 nmap-7.95-1 nodejs-22.2.0-1 npm-10.8.0-1 opencl-headers-2:2024.05.08-1 opencv-4.9.0-8 ostree-2024.6-1 pavucontrol-1:6.0-1 pcsclite-2.2.3-1 perl-html-parser-3.82-1 perl-xml-sax-1.02-2 php-8.3.7-2 php-cgi-8.3.7-2 php-gd-8.3.7-2 php-sodium-8.3.7-2 poppler-glib-24.05.0-1 pyside6-6.7.1-1 python-annotated-types-0.7.0-1 python-automat-22.10.0-5 python-cryptography-42.0.6-1 python-fonttools-4.52.4-1 python-lxml-5.2.2-1 python-mako-1.3.3-3 python-packaging-24.0-1 python-pytorch-opt-rocm-2.3.0-5 python-scipy-1.13.1-1 python-trove-classifiers-2024.5.22-1 python-typing_extensions-4.12.0-1 qt5-location-5.15.13+kde+r7-1 qt5-webengine-5.15.17-1 qt6-svg-6.7.1-1 rapidjson-1.1.0-6 raptor-2.0.16-5 redis-7.2.5-1 samba-4.20.1-2 semver-7.6.2-1 shiboken6-6.7.1-1 snapd-2.63-1 systemd-sysvcompat-255.6-4 thunderbird-115.11.0-4 vapoursynth-R68-1 vivaldi-6.7.3329.39-1 webkit2gtk-2.44.2-1 wireless-regdb-2024.05.08-1 xdg-desktop-portal-gnome-46.2-1 xfsprogs-6.8.0-2 xorg-xwayland-24.1.0-1
Total Installed Size: 6675.07 MiB
Net Upgrade Size: 1875.88 MiB
:: Proceed with installation? [Y/n] y
checking keyring...
checking package integrity...
error: linux515: signature from "Manjaro Build Server <build@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/linux515-5.15.160-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: linux54-headers: signature from "Manjaro Build Server <build@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/linux54-headers-5.4.277-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: man-pages: signature from "Andreas Radke <andyrtr@archlinux.org>" is invalid
:: File /var/cache/pacman/pkg/man-pages-6.8-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
I’ve tried several commands to fix this issue, including:
sudo pacman -Scc
sudo rm -r /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate
sudo pacman-key --refresh-keys
The refresh-keys command takes a long time and a lot of keys don’t verify.
Here’s the output of pacman -Q archlinux-keyring; pacman -Ss archlinux-keyring:
archlinux-keyring 20240520-1
core/archlinux-keyring 20240520-1 [installed]
Arch Linux PGP keyring
And the output of pacman -V:
.--. Pacman v6.1.0 - libalpm v14.0.0
/ _.-' .-. .-. .-. Copyright (C) 2006-2024 Pacman Development Team
\\ '-. '-' '-' '-' Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
Any help would be greatly appreciated.
… this one too?
sudo rm -fr /etc/pacman.d/gnupg
sudo pacman-key --populate archlinux manjaro
refresh your list of mirrors
for example:
sudo pacman-mirrors -c Germany
sudo pacman -Syyu
if it fails again (it probably will), do the first set of commands
info sourced from here:
Getting invalid or corrupted package (PGP signature) error when updating - #4 by Nachlese
look at this and the links within it before you go ahead and copy/paste commands
sudo pacman-mirrors -c Germany revealed a problem where my python3 package was not functional. I was able to quickly reinstall it and refresh my mirrors. Unfortunately, pacman -Syyu has the same issue. I’ve also tested several variations of the commands listed above, including many of the ones from that forum post.
mkay - we will never know what you did and what the current responses where
if you don’t tell us
we are blind without that and speculation is inefficient at best
By the looks of it, you didn’t even click the link …
I certainly clicked the link. The baseless assumption that I didn’t is insultng.
history
351 sudo pacman -Syu
352 sudo pacman -Syu
353 sudo pacman-key --init
354 sudo pacman-key --populate archlinux
355 sudo pacman -Syu
356 sudo pacman -
357 sudo pacman -u
358 sudo pacman -Su
359 sudo pacman -Syu --overwrite ''~
360 sudo pacman -Syu --overwrite go
361 sudo pacman -Syu --overwrite go /usr/lib/go /usr/share/
362 sudo pacman -Syu --overwrite '/usr/lib/go' '/usr/share/'
363 sudo pacman -Uyu --overwrite '/usr/lib/go' '/usr/share/'
364 sudo pacman -Syu --overwrite '/usr/lib/go' '/usr/share/'
365 sudo pacman -Syu --overwrite '/usr/lib/go/' '/usr/share/'
366 sudo pacman -Syu --overwrite '/usr/lib/go/'
367 sudo pacman -Syu --overwrite '/usr/lib/go/*'
368 sudo pacman -Syu --overwrite '/usr/lib/go/*' '/usr.share/*'
369 sudo pacman -Syu --overwrite '/usr/lib/go/*' '/usr/share/*'
370 sudo pacman -Syu --overwrite '/usr/lib/go/*' '/usr/bin/go'
371 sudo pacman -Syu --overwrite '/usr/lib/go/' --overwrite '/usr/bin/' --overwrite '/usr/share/*'
372 sudo pacman -Syu --overwrite '/usr/*'
373 sudo pacman -Scc
374 sudo pacman -Syu
375 sudo archlinux-keyring-wkd-sync
376 sudo pacman -Syu
377 sudo pacman -Scc
378 sudo pacman -Scc
379 remove /var/lib/pacman/db.lck
380 sudo rm /var/lib/pacman/db.lck
381 sudo pacman -Scc
382 sudo pacman -Syu
383 sudo pacman -Sy archlinux-keyring
384 sudo pacman -Syu
385 pacman -Sy archlinux-keyring
386 sudo pacman -Sy archlinux-keyring
387 sudo pacman -Sy gpg-agent
388 sudo pacman -Syu
389 pacman -Sy archlinux-keyring
390 sudo pacman -Sy archlinux-keyring
391 gpgconf --kill all
392 sudo pacman -Syu
393 sudo pacman -Sy gnupg
394 sudo gpgconf --kill all
395 sudo pacman -Syu
396 sudo pacman -Scc
397 sudo pacman -Syu
398 sudo pacman -Syu --overwrite '/*'
399 sudo pacman -Scc
400 sudo pacman -Syu --overwrite '/*'
401 code-server
402 cd www
403 mix phx.new shop --no-ecto --adapter bandit --no-mailer --no-live
404 sudo pacman -Syu
405 elixir -v
406 mix local.hex
407 mix archive.install hex phx_new
408 mix phx.new shop --no-ecto --adapter bandit --no-mailer --no-live
409 cd shop/
410 mix phx.server
411 clear
412 ls
413 cd ..
414 code-server
415 node -v
416 ls
417 sudo docker ps
418 sudo docker-compose down
419 sudo docker-compose up -d
420 top
421 ls
422 cp docker-compose.yml docker-compose.yml.bak
423 nano docker-compose.yml
424 nano docker-compose.yml
425 nano docker-compose.yml
426 sudo docker-compose down
427 sudo docker-compose up -d
428 docker run --runtime=nvidia --rm nvidia/cuda:10.0-base nvidia-smi
429 sudo docker run --runtime=nvidia --rm nvidia/cuda:10.0-base nvidia-smi
430 sudo ntpdate time.nist.gov
431 sudo pacman -Sy nvidia-container-toolkit
432 sudo systemctl restart docker
433 ls
434 sudo docker ps
435 sudo docker-compose up -d
436 nano docker-compose.yml
437 sudo docker-compose up -d
438 nvidia-container-runtime
439 sudo docker-compose up -d
440 nvidia-container-cli -k list
441 nano /etc/docker/daemon.json
442 sudo nano /etc/docker/daemon.json
443 sudo systemctl restart docker
444 sudo docker ps
445 sudo docker-compose up -d
446 top
447 nvidia-container-cli -k list
448 neofetch
449 top
450 ls
451 top
452 nano docker-compose.yml
453 top
454 sudo systemctl stop code-server@spk.service
455 top
456 top
457 shutdown
458 sudo shutdown
459 sudo shutdown now
460 sudo code-server
461 sudo su
462 curl -fsSL https://code-server.dev/install.sh | sh
463 date
464 sudo systemctl enable --now code-server@$USER
465 sudo systemctl status code-server@spk.service
466 sudo systemctl disable code-server
467 sudo systemctl disable code-server@
468 sudo systemctl status code-server@spk.service
469 sudo systemctl status code-server@spk.service
470 sudo code-server
471 clear
472 code-server
473 curl -fsSL https://code-server.dev/install.sh | sh
474 curl -fsSL https://code-server.dev/install.sh | sh --version=4.22.1
475 curl -fsSL https://code-server.dev/install.sh | sh -s --version=4.22.1
476 curl -fsSL https://code-server.dev/install.sh | sh -s -- --version=4.22.1
477 code-server
478 yay -S code-server
479 code-server
480 nano ~/.config/code-server/config.yaml
481 sudo systemctl enable code-server@.service
482 sudo systemctl enable code-server@
483 sudo systemctl enable --now code-server@$USER
484 sudo systemctl status code-server@$USER
485 top
486 ls
487 sudo systemctl status code-server@spk.service
488 nano .config/code-server/config.yaml
489 sudo systemctl restart code-server@spk.service
490 sudo systemctl status code-server@spk.service
491 cd ..
492 clear
493 ls
494 cd .surrealdb/
495 ls
496 sh exportdb.sh
497 ls
498 mix phx.server
499 cd ..
500 rm -rf geckos
501 ls
502 sudo systemctl restart code-server@spk.service
503 curl -fsSL https://code-server.dev/install.sh | sh
504 sudo systemctl enable --now code-server@$USER
505 sudo systemctl restart code-server@$USER
506 sudo systemctl status code-server@$USER
507 sudo systemctl stop code-server@$USER
508 sudo systemctl disable code-server@$USER
509 curl -fsSL https://code-server.dev/install.sh | sh
510 sudo systemctl enable --now code-server@$USER
511 sudo systemctl status code-server@$USER
512 code-server
513 sudo ntpdate time.nist.gov.
514 sudo ntpdate time.nist.gov
515 nano fixtime.sh
516 nano fixtime.sh
517 sudo chmox +x fixtime.sh
518 sudo chmod +x fixtime.sh
519 ./fixtime.sh
520 sudo pacman -Syu
521 sudo pacman -Scc
522 sudo pacman -Syu
523 sudo nano /etc/pacman.conf
524 sudo pacman -Syu
525 sudo nano /etc/pacman.conf
526 sudo pacman-key --init
527 sudo pacman-key --populate archlinux manjaro
528 sudo pacman-key --refresh-keys
529 sudo rm -r /etc/pacman.d/gnupg
530 sudo pacman-key --init
531 sudo pacman-key --populate
532 screen -S update
533 clear
534 sudo pacman -S
535 sudo pacman -U
536 sudo pacman -U pacman
537 screen -r update
538 checkupdates
539 pacman -Q archlinux-keyring; pacman -Ss archlinux-keyring
540 screen - r
541 screen -r update
542 screen -r update
543 clear
544 ls
545 neofetch
546 ls
547 cat output.txt
548 pacman -Q archlinux-keyring; pacman -Ss archlinux-keyring
549 sudo pacman -U pacman
550 sudo pacman -version
551 sudo pacman -e
552 sudo pacman -t
553 sudo pacman t
554 man pacman
555 pacman -V
556 cat output.txt
557 pacman -v
558 pacman -Q archlinux-keyring
559 neofetch
560 sudo pacman-mirrors -c usa
561 sudo pacman-mirrors -c Germany
562 sudo pacman-mirrors -c Germany
563 python3
564 sudo pacman -S python3
565 python3
566 clear
567 sudo pacman-mirrors -c Germany
568 nano /etc/pacman.d/mirrorlist
569 sudo pacman-mirrors -c USA
570 sudo pacman-mirrors -c United_States
571 sudo pacman-mirrors -id
572 sudo pacman-mirrors -c all
573 sudo pacman -Syyu
574 sudo pacman -Fy
575 sudo pacman -Syyu
576 history
The link shows the number of times it was used - at least to me.
Now it does show one click - it didn’t a few minutes ago when I said this.
I didn’t intend to insult - but I now choose to not participate here anymore.
Good luck!
OP data shows pacman update found 3 packages with invalid signatures and requested deletion.
But package deletion was declined so update failed rather than install invalid or corrupted packages
I suggest delete the invalid or corrupted packages from cache
sudo rm /var/cache/pacman/pkg/linux515-5.15.160-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/linux54-headers-5.4.277-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/linux54-headers-5.4.277-1-x86_64.pkg.tar.zst
You one is here to insult you - however some may get hurt feelings when their possible errors i pointed out.
If you get errors with signarures and invalid packages - first cause of action is to search - and implement possible remidy actions.
