I have an update that’s not going through.
Packages (1) ruby-bundler-2.7.2-1
Total Installed Size: 1.66 MiB
Net Upgrade Size: 0.01 MiB
(1/1) checking keys in keyring [--------------------------------------------------------------------] 100%
(1/1) checking package integrity [--------------------------------------------------------------------] 100%
(1/1) loading package files [--------------------------------------------------------------------] 100%
(1/1) checking for file conflicts [--------------------------------------------------------------------] 100%
error: failed to commit transaction (conflicting files)
ruby-bundler: /usr/lib/ruby/gems/3.4.0/gems/bundler-2.7.2/exe/bundle exists in filesystem
ruby-bundler: /usr/lib/ruby/gems/3.4.0/gems/bundler-2.7.2/exe/bundler exists in filesystem
ruby-bundler: /usr/lib/ruby/gems/3.4.0/specifications/default/bundler-2.7.2.gemspec exists in filesystem
I suspect that some system-wide installed gem has brought in this version of ruby-bundler and I do remember trying to get ASCIIdoctor’s PDF support to work on this machine recently, which might have done this. Anyway, I’d like to fix this, but would have to remove a default gem. I found some sources explaining how to do it, but also some others making it seem like something one should not do. What’s the right way to go about this? I have considered removing ruby and all dependencies, but that also didn’t look like a good option…
