Yesterday, pacman -Syyu
installed openvnc
I can`t find this package in the software manager under installed.
How can I remove it ?
installed openvnc
Hi @Keruskerfuerst,
There is no such package to be installed:
$ pamac search openvnc
There’s also no search results for it in the Arch wiki:
https://wiki.archlinux.org/index.php?search=openvnc
However there is an openvpn
package:
$ pamac search openvpn
sshmultitool 2016.03.10-1 AUR
A multi tool for SSH, SCP and SFTP, supporting port knocking and
openvpn (German version)
regolith-i3xrocks-config 1.6-19 AUR
Blocks and scripts needed for i3xrocks - fork of i3-blocks
nordvpn-configs 1.0.1-1 AUR
openvpn config files for NordVPN
goovpn-bin 1.0.6-2 AUR
Cross-platform gui (use wails) openvpn client.
vim-openvpn 1.11-2 AUR
OpenVPN configuration syntax highlighter
qopenvpn 2.0.0-8 extra
Simple OpenVPN GUI written in PyQt for systemd based distributions
ppp-hook-openvpn 0.0.2-2 AUR
Hook for ppp to reconnect openvpn upon connection
networkmanager-openvpn-gtk2 0.9.8.4-1 AUR
NetworkManager VPN plugin for OpenVPN
networkmanager-openvpn-git 1.8.13.dev.r73.gf9918d2-1 AUR
networkmanager-dispatcher-openvpn 0.r6.g031bc89-1 AUR
Networkmanager Dispatcher script for OpenVPN
namespaced-openvpn-git r32.5ef019d-1 AUR
Wrapper for OpenVPN on Linux solving various privacy issues
gopenvpn-git svn.migration.r12.gb4192eb-8 AUR
gopenvpn is a simple graphical front-end for OpenVPN, the open source
VPN solution.
dhcpcd-hook-openvpn 0.2.1-1 AUR
Hook for dhcpcd to send SIGUSR1 to openvpn and reestablish connection
networkmanager-openvpn 1.12.0-1 [Installed] extra
openvpn3-indicator-git r53.a00ecaa-1 AUR
Simple GTK indicator GUI for OpenVPN 3 Linux
openvpn3-git 22_dev.r5.ga3de5e2-2 AUR
OpenVPN 3 Linux client
openvpn3 22_dev-7 AUR
openvpn-update-systemd-resolved 1.3.0-4 AUR
OpenVPN systemd-resolved Updater
openvpn-update-resolv-conf-git r46.2485e9d-1 AUR
OpenVPN Update resolvconf
openvpn-unroot-git r1.f2e4844-1 AUR
Run OpenVPN without root privileges
openvpn-reconnect 1-2 AUR
A systemd hook for reconnecting OpenVPN after suspend
openvpn-radiusplugin-git 2.2.r1.g79d9869-1 AUR
Radiusplugin for OpenVPN - git checkout
openvpn-radiusplugin 2.1a_beta1-4 AUR
openvpn-otp 1.0-4 AUR
This plugin adds support for TOTP and HOTP tokens (like Google
Authenticator) for OpenVPN
openvpn-nordvpn 0.1.41-1 AUR
OpenVPN helper script for nordvpn.com
openvpn-nl 2.5.10nl1-1 AUR
An open-source fork of OpenVPN for use by the NL government up to Dep.V.
openvpn-netns-git r8.82342f7-1 AUR
A script that starts a openvpn connection inside a network namespace
openvpn-mbedtls 2.6.12-1 AUR
An easy-to-use, robust and highly configurable VPN (Virtual Private
Network), linked against the mbedtls library for crypto support.
openvpn-git 2.4.rc2.r864.g3b1ded39-1 AUR
Network) - git checkout
openvpn-dco-dkms 0.2.20231117-1 AUR
Optional Data Channel Offload kernel module for OpenVPN 2.5
openvpn-aws 2.6.10-1 AUR
Network) with patches to support AWS Client VPN
openvpn-auth-ldap 2.0.4-3 AUR
OpenVPN Auth via LDAP/AD plugin. RFC2307 support.
openvpn 2.6.12-1 [Installed] extra
Network)
Therefore, I suspect you have it wrong. If not, please provide the output of:
which openvnc
Looking in /var/log/pacman.log
might help you to check what you actually did yesterday.
grep -i "2024-09-02" /var/log/pacman.log | grep -i 'installed' /var/log/pacman.log
@Mirdarthos did you mean to say
since giving the file name in both grep
commands kind of spoils the pipeline
Or you could install pacutils
pamac install pacutils
And run:
paclog --after $(date -d "yesterday" '+%F')
I opened /var/log/pacman.log
and there is no package openvnc
I had a look at the log and there is [2024-10-02T10:49:38+0000] [ALPM] upgraded opencv (4.10.0-7 -> 4.10.0-7.0)
Here ist the log of yesterday:
[2024-10-02T04:44:07+0000] [PACMAN] Running 'pacman -Syyu'
[2024-10-02T04:44:07+0000] [PACMAN] synchronizing package lists
[2024-10-02T04:44:08+0000] [PACMAN] starting full system upgrade
[2024-10-02T10:49:31+0000] [PACMAN] Running 'pacman -Syyu'
[2024-10-02T10:49:31+0000] [PACMAN] synchronizing package lists
[2024-10-02T10:49:32+0000] [PACMAN] starting full system upgrade
[2024-10-02T10:49:37+0000] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-10-02T10:49:37+0000] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-10-02T10:49:37+0000] [ALPM] transaction started
[2024-10-02T10:49:38+0000] [ALPM] transaction completed
[2024-10-02T10:49:38+0000] [ALPM] running '30-systemd-update.hook'...
[2024-10-02T10:49:38+0000] [ALPM] running '90-packagekit-refresh.hook'...
[2024-10-03T15:36:05+0000] [PACMAN] Running 'pacman -Syyu'
[2024-10-03T15:36:05+0000] [PACMAN] synchronizing package lists
[2024-10-03T15:36:06+0000] [PACMAN] starting full system upgrade
So nothing has been installed that was not already present …
is not
Please, only use a single y
in the pacman command:
sudo pacman -Syu
