I don’t think man-pages
should be an orphan.
You should be able to remove virt-viewer
, seeing that the package itself is orphaned.
Thanks for the help btw
I did:
sudo pacman -D --asexplicit man-pages
and then:
$ sudo pacman -Qtdq | sudo pacman -Rns -
control of dependencies in progress...
Packages (2) libgovirt-0.3.7-1 virt-viewer-8.0-2
Total size of packages removed: 1.50 MiB
:: Do you want to remove these packages? S/n]
:: Processing changes to the package...
(1/2) removal of virt-viewer [#################################] 100% in progress
(2/2) ongoing removal of libgovirt [#################################] 100%.
:: Execution of post-transaction hooks...
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating icon theme caches...
(3/4) Updating the desktop file MIME type cache...
(4/4) Updating the MIME type database...
Now I can say that I fixed?
I would think so.
thanks for the help!!
