Some of the output messages are prefixed with backup file:. What are these backup files and where are they?
Some of the lines are warnings and say Permissions mismatch. How do I display what pacman thinks the permission should be, so I can compare it to what is actually on the system?
Most of the output (Modification time mismatch and Size mismatch) can be explained by configuration changes.
I think these are the files that would produce a pacsave if the corresponding package got uninstalled and they are called backup file because they were specified in the backup-directive in PKGBUILD.
