I type pacman -Si
to get names of dependencies, but when I try to put some of the names into pacman -Si
, for example pacman -Si libpsl.so=5-64
, I get:
error: package 'libpsl.so=5-64' was not found
Although, when I try sudo pacman -S libpsl.so=5-64
, it seems to find the package but It says:
resolving dependencies...
Packages (1) libpsl-0.21.1-1
So I execute this (omitting the hyphen and the rest of the characters after it I suppose):
pacman -Si libpsl
And I successfully get the info.
I would like to know whether It is somehow possible, without having root access I suppose, to get the name of the package so I can put it in pacman -Si
without getting an error.
libpsl
provides libpsl.so=5-64
. The former is the package name and the latter is a library provided by the package. Since the package provides it, using pacman -S linbpsl.so
resolves the package it belongs to. If you want to find the package that includes a library or file, use pacman -F <filename>
. You can also use a wildcard search: pacman -Fx libpsl.so*
What about libgl
? Is it also the name of the file or library?
Neither. There are quite a few libraries beginning with libgl*
, but the first thing I thought of was mesa
that provides mesa-libgl
. If you use the commands I mention, you’ll see what I mean.
I executed pacman -Fx libgl
and it looks like it shows a lot of packages and files (I see some packages have libgl
in their names, lots of files have libgl
in their names also) but when I execute sudo pacman -S libgl
It lets install just libglvnd
. I’m not sure how does it decide what to install.
That’s because libglvnd
provides libgl
. I think there used to be a separate libgl
package.
