Suddenly pacman
has stopped responding. It doesn’t give me any response at all. Also, the default terminal stopped working (I’m using Manjaro XFCE). I could use pacman-static
to install alacritty
using the tty2
. But I cannot make pacman
work. Running yay
gives me the following error:
yay : error while loading shared libraries: /usr/lib/libalpm.so.12: file too short
Please help me out. My system info is as follows:
inxi -Fazy
Kernel: 5.11.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=96cbf077-2c45-4acc-b876-4bbd6b670707 ro quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop Mobo: Gigabyte model: H81M-S v: x.x serial: <filter>
UEFI: American Megatrends v: F1 date: 06/11/2014
Info: Dual Core model: Intel Core i3-4130 bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L2: 3 MiB
bogomips: 27146
Speed: 3380 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 3380 2: 2506
3: 3393 4: 2891
Type: l1tf
Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:041e
class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound Server-1: ALSA v: k5.11.19-1-MANJARO running: yes
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 367.78 GiB (39.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: MBR
ID-1: / raw-size: 48.83 GiB size: 47.81 GiB (97.92%) used: 14.41 GiB (30.1%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda8 maj-min: 8:8
ID-3: /home raw-size: 366.38 GiB size: 359.63 GiB (98.16%)
used: 49.32 GiB (13.7%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 184 Uptime: 21m wakeups: 0 Memory: 3.71 GiB
used: 1.02 GiB (27.5%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 0 snap: 4 Shell: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.04
