Currently, the pacman-mirrors wiki guide suggests a few options for restricting mirrors based on physical location. I’ve encountered some difficulties in getting this to work correctly, however.
My attempts auto-generate the mirrorlist using the --geoip flag return the following:
$ sudo pacman-mirrors --geoip
::INFO Downloading mirrors from repo.manjaro.org
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.896 Australia : https://manjaro.lucassymons.net/
2.180 Australia : https://mirror.aarnet.edu.au/pub/manjaro/
1.912 Australia : http://mirror.aarnet.edu.au/pub/manjaro/
::INFO Writing mirror list
::Australia : https://manjaro.lucassymons.net/stable
::Australia : https://mirror.aarnet.edu.au/pub/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
Additionally, using the --continent flag returns:
$ sudo pacman-mirrors --continent
1.894 Bangladesh : http://mirror.xeonbd.com/manjaro/
1.374 China : https://mirrors.aliyun.com/manjaro/
2.371 China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
1.948 China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
2.755 China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
1.988 Georgia : https://manjaro.grena.ge/
1.562 Georgia : http://manjaro.grena.ge/
..... Hong_Kong : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/
..... Hong_Kong : ftp://ftp.cuhk.edu.hk/pub/Linux/manjaro/
::ERROR No connection adapters were found for 'ftp://ftp.cuhk.edu.hk/pub/Linux/manjaro/stable/core/x86_64/core.db.tar.gz'
1.135 Indonesia : https://mirror.deace.id/manjaro/
1.282 Indonesia : http://mirror.deace.id/manjaro/
1.693 Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
1.795 Philippines : http://mirror.rise.ph/manjaro/
..... Philippines : ftp://mirror.rise.ph/manjaro/
::ERROR No connection adapters were found for 'ftp://mirror.rise.ph/manjaro/stable/core/x86_64/core.db.tar.gz'
2.663 Singapore : https://download.nus.edu.sg/mirror/manjaro/
1.654 South_Korea : https://mirror.d-tl.com/manjaro/
1.588 Taiwan : http://free.nchc.org.tw/manjaro/
::Indonesia : https://mirror.deace.id/manjaro/stable
::China : https://mirrors.aliyun.com/manjaro/stable
::Georgia : https://manjaro.grena.ge/stable
::Taiwan : http://free.nchc.org.tw/manjaro/stable
::South_Korea : https://mirror.d-tl.com/manjaro/stable
::Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Bangladesh : http://mirror.xeonbd.com/manjaro/stable
::China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::Singapore : https://download.nus.edu.sg/mirror/manjaro/stable
::China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
Versioning:
$ pacman-mirrors --version
Version 4.20.0
$ uname -a
Linux localhost 5.9.16-1-MANJARO ... x86_64 GNU/Linux
It appears that pacman-mirrors resolved my location to be in Australia or Asia, when, in fact, my location is central United States. Using the recommended ‘reset’ command (sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu) before the above commands did not help either.
I confirmed that other geolocation services can correctly resolve my location.
After a bit of researching, I haven’t found any relevant forum posts, which leads me to believe I’m somehow using these flags incorrectly. Any advice on the correct usage would be appreciated.
Thank’s and congratulations for your work
~ sudo pacman-mirrors --geoip 5m 17s
[sudo] senha para cretoii:
DEBUG ME: Brazil
..... Brazil : https://manjaro.c3sl.ufpr.br/
..... Brazil : http://linorg.usp.br/manjaro/
0.574 Brazil : https://www.caco.ic.unicamp.br/manjaro/
::Brazil : https://www.caco.ic.unicamp.br/manjaro/stable
::Brazil : http://linorg.usp.br/manjaro/stable
::Brazil : https://manjaro.c3sl.ufpr.br/stable
~ ✔ 32s
My Location (Germany) is correct, but since yesterday after downloading your update i see a adapter connection error when im using: “sudo pacman-mirrors --fasttrack && sudo pacman -Syyu”
::INFO Using custom mirror file
1.130 Germany : https://mirror.alpix.eu/manjaro/
1.066 Germany : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
..... Germany : ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/
::ERROR No connection adapters were found for 'ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/core/x86_64/core.db.tar.gz'
1.072 Germany : https://manjaro.re/
0.967 Germany : http://manjaro.re/
1.078 Germany : https://manjaro.moson.eu/
0.981 Germany : http://manjaro.moson.eu/
1.075 Germany : https://manjaro.moson.org/
0.979 Germany : http://manjaro.moson.org/
1.078 Germany : https://ftp.halifax.rwth-aachen.de/manjaro/
..... Germany : ftp://ftp.halifax.rwth-aachen.de/manjaro/
::ERROR No connection adapters were found for 'ftp://ftp.halifax.rwth-aachen.de/manjaro/stable/core/x86_64/core.db.tar.gz'
1.040 Germany : https://mirror.atysleaks.org/manjaro/
1.061 Germany : http://mirror.atysleaks.org/manjaro/
1.045 Germany : https://mirror.netcologne.de/manjaro/
1.019 Germany : https://mirror.23media.com/manjaro/
0.949 Germany : http://mirror.23media.com/manjaro/
::Germany : https://mirror.23media.com/manjaro/stable/$repo/$arch
::Germany : https://manjaro.re/stable/$repo/$arch
::Germany : https://manjaro.moson.org/stable/$repo/$arch
::Germany : https://manjaro.moson.eu/stable/$repo/$arch
::Germany : https://mirror.netcologne.de/manjaro/stable/$repo/$arch
::Germany : https://mirror.atysleaks.org/manjaro/stable/$repo/$arch
::Germany : https://mirror.alpix.eu/manjaro/stable/$repo/$arch
core 164.9 KiB 1918 KiB/s 00:00 [#####################################] 100%
extra 2000.5 KiB 1796 KiB/s 00:01 [#####################################] 100%
community 6.6 MiB 1775 KiB/s 00:04 [#####################################] 100%
multilib 180.5 KiB 2.05 MiB/s 00:00 [#####################################] 100%
there is nothing to do
Should i ignore this connection issue or is there a way to fix it by myself?
Edit:
Im also noticed that Terminal command showed this:
Version 4.20.1
But in the GUI when i look at pacman-mirrors, the already installed version 4.20.1-1 showed up.
When you see a version 4.20.1-1 in Pamac gui you will see the package version too. This is signified with the -1
You can ignore the message - it has appeared after the rewrite to use the requests library - so I will have to look at the options for the requests library - I haven’t had time to dive into that aspect fully yet - but I think it is because requests library is for http.
The next version with yet a bugfix is already in testing and unstable. v4.20.2.
