Hello,
Background
Running pamac upgrade gives:
Cloning touche build files...
Checking touche dependencies...
http://mirrors.colocall.net/manjaro/stable/core/x86_64/core.db: Could not connect: Socket I/O timed out
http://mirrors.colocall.net/manjaro/stable/extra/x86_64/extra.db: Could not connect: Socket I/O timed out
^Chttp://mirrors.colocall.net/manjaro/stable/community/x86_64/community.db: Could not connect: Socket I/O timed out
So I tried updating the mirrorlist as per this post
Issue
Running sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu gives:
::INFO Branch in config is changed
::INFO Protocols in config is changed
::INFO => Mirror status: http://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
2.139 Australia : https://manjaro.lucassymons.net/
..... Austria : http://mirror.easyname.at/manjaro/
..... Austria : ftp://mirror.easyname.at/manjaro/
..... Bangladesh : http://mirror.xeonbd.com/manjaro/
..... Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/
..... Belgium : http://ftp.belnet.be/mirrors/manjaro/repos/
..... Belgium : ftp://ftp.belnet.be/mirrors/manjaro/repos/
2.559 Belgium : https://mirror.futureweb.be/manjaro/
..... Belgium : http://mirror.futureweb.be/manjaro/
#######truncating to save space###########
2.856 Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/
..... Spain : http://ftp.caliu.cat/pub/distribucions/manjaro/
1.292 Sweden : https://ftp.lysator.liu.se/pub/manjaro/
1.951 Sweden : ftp://ftp.lysator.liu.se/pub/manjaro/
1.931 Sweden : https://mirror.zetup.net/manjaro/
..... Sweden : https://ftpmirror1.infania.net/mirror/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='ftpmirror1.infania.net', port=443): Max retries exceeded with url: /mirror/manjaro/stable/core/x86_64/core.db.tar.gz (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fb0db2e6eb0>: Failed to establish a new connection: [Errno -2] Name or service not known'))
..... Sweden : http://ftpmirror1.infania.net/mirror/manjaro/
::ERROR Connection: HTTPConnectionPool(host='ftpmirror1.infania.net', port=80): Max retries exceeded with url: /mirror/manjaro/stable/core/x86_64/core.db.tar.gz (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fb0db2e6c10>: Failed to establish a new connection: [Errno -2] Name or service not known'))
..... Sweden : ftp://ftpmirror1.infania.net/mirror/manjaro/Traceback (most recent call last):
File "/usr/lib/python3.9/urllib/request.py", line 1553, in ftp_open
host = socket.gethostbyname(host)
socket.gaierror: [Errno -2] Name or service not known
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/httpFn.py", line 162, in get_ftp_response
with closing(request.urlopen(url, timeout=maxwait)) as r:
File "/usr/lib/python3.9/urllib/request.py", line 214, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.9/urllib/request.py", line 517, in open
response = self._open(req, data)
File "/usr/lib/python3.9/urllib/request.py", line 534, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File "/usr/lib/python3.9/urllib/request.py", line 494, in _call_chain
result = func(*args)
File "/usr/lib/python3.9/urllib/request.py", line 1555, in ftp_open
raise URLError(msg)
urllib.error.URLError: <urlopen error [Errno -2] Name or service not known>
File "/usr/bin/pacman-mirrors", line 28, in <module>
pm.run()
File "/usr/lib/python3.9/site-packages/pacman_mirrors/pacman_mirrors.py", line 124, in run
common.build_mirror_list(self)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/builder/common.py", line 56, in build_mirror_list
work_pool = test_mirror_pool(self=self, worklist=work_pool)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/testMirrorFn.py", line 82, in test_mirror_pool
mirror_proto["resp_time"] = get_mirror_response(
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/httpFn.py", line 202, in get_mirror_response
message = get_ftp_response(url=probe_url, maxwait=maxwait)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/httpFn.py", line 166, in get_ftp_response
if e.reason.find('No such file or directory') >= 0:
AttributeError: 'gaierror' object has no attribute 'find'
I’m not sure what to do here. It seems the error returned by the Swedish repo is causing issues, but I’m not sure how to interpret that, or how to upgrade from a specific mirror.
Other info
I upgraded pamac twice yesterday as the AUR issue was being dealt with, so I think I’m on the latest version of that.
Running Manjaro KDE, output of inxi --full --verbosity=7 --filter --no-host:
System: Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: GOOGLE product: Samus v: EVT1 serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: GOOGLE model: Samus v: EVT1 serial: <filter> UEFI: coreboot v: MrChromebox-4.12 date: 06/04/2020
Battery: ID-1: BAT0 charge: 17.1 Wh (25.7%) condition: 66.5/72.3 Wh (91.9%) volts: 7.4 min: 7.6 model: SMP-ATL A55
type: Li-ion serial: <filter> status: Discharging cycles: 361
Memory: RAM: total: 15.51 GiB used: 6.35 GiB (40.9%)
CPU: Info: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell rev: 4 cache: L2: 4 MiB
bogomips: 19156
Speed: 2381 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 2381 2: 2342 3: 2439 4: 2606
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear
mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt
pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
Graphics: Device-1: Intel HD Graphics 5500 driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Silicon Motion NCM-G102 type: USB driver: uvcvideo bus-ID: 1-7:3 chip-ID: 2232:6001 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 2560x1700~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.0.2 direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: yes
Network: Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: 1840 bus-ID: 01:00.0 chip-ID: 8086:08b1
class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:4 chip-ID: 8087:07dc
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Logical: Message: No logical block device data found.
Device-1: luks-a96e049c-e778-4268-bf3f-24bda6abb66c type: LUKS dm: dm-0 size: 59.32 GiB
Components: p-1: sda2
RAID: Message: No RAID data found.
Drives: Local Storage: total: 242.97 GiB used: 232.87 GiB (95.8%)
ID-1: /dev/sda vendor: Kingston model: RBU-SUS151S364GD size: 59.63 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 02.3 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Generic model: Power Saving USB size: 183.35 GiB serial: <filter> rev: 0260
scheme: MBR
Partition: ID-1: / size: 58.09 GiB used: 28.63 GiB (49.3%) fs: ext4 dev: /dev/dm-0
mapped: luks-a96e049c-e778-4268-bf3f-24bda6abb66c label: N/A uuid: 7ec25ccd-995c-42df-9a15-e4776a67ccd5
ID-2: /boot/efi size: 299.4 MiB used: 448 KiB (0.1%) fs: vfat dev: /dev/sda1 label: NO_LABEL uuid: 7C26-72F2
ID-3: /home/<filter>/Nextcloud size: 1 PiB used: 204.23 GiB (0.0%) fs: fuse.rclone source: ERR-102 label: N/A
uuid: N/A
Swap: ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Unmounted: ID-1: /dev/sdb1 size: 183.33 GiB fs: <superuser required> label: N/A uuid: N/A
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Device-1: 1-4:2 info: Genesys Logic microSD Reader/Writer type: Mass Storage driver: usb-storage interfaces: 1
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05e3:0727 class-ID: 0806 serial: <filter>
Device-2: 1-7:3 info: Silicon Motion NCM-G102 type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 2232:6001 class-ID: 0e02
Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 8087:07dc class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 97.5 C mobo: N/A
Info: Processes: 250 Uptime: 15h 04m wakeups: 2 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1376
Shell: Bash v: 5.1.0 running-in: yakuake inxi: 3.3.04
Thank you.
