Hi there, I did a sudo pacman -Syyu and there was an update only for pacman-mirrors package. I proceeded and i get this below error:
Terminal Output
[sudo] password for dstyle:
:: Synchronising package databases...
core 164.9 KiB 182 KiB/s 00:01 [################################] 100%
extra 2000.5 KiB 351 KiB/s 00:06 [################################] 100%
community 6.6 MiB 304 KiB/s 00:22 [################################] 100%
multilib 180.5 KiB 195 KiB/s 00:01 [################################] 100%
resolving dependencies...
Packages (1) pacman-mirrors-4.20.1-1
Total Download Size: 0.14 MiB
Total Installed Size: 0.63 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
pacman-mirrors-4.20.1-1-any 142.4 KiB 106 KiB/s 00:01 [################################] 100%
(1/1) checking keys in keyring [################################] 100%
(1/1) checking package integrity [################################] 100%
(1/1) loading package files [################################] 100%
(1/1) checking for file conflicts [################################] 100%
(1/1) checking available disk space [################################] 100%
(1/1) upgrading pacman-mirrors [################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Configuring pacman-mirrors ...
::WARNING https://gitlab.manjaro.org '('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))'
::INFO Downloading mirrors from repo.manjaro.org
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/usr/lib/python3.9/site-packages/urllib3/connection.py", line 411, in connect
self.sock = ssl_wrap_socket(
File "/usr/lib/python3.9/site-packages/urllib3/util/ssl_.py", line 428, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(
File "/usr/lib/python3.9/site-packages/urllib3/util/ssl_.py", line 472, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.9/ssl.py", line 500, in wrap_socket
return self.sslsocket_class._create(
File "/usr/lib/python3.9/ssl.py", line 1040, in _create
self.do_handshake()
File "/usr/lib/python3.9/ssl.py", line 1309, in do_handshake
self._sslobj.do_handshake()
ConnectionResetError: [Errno 104] Connection reset by peer
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/lib/python3.9/site-packages/urllib3/util/retry.py", line 531, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3.9/site-packages/urllib3/packages/six.py", line 734, in reraise
raise value.with_traceback(tb)
conn.connect()
self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/usr/bin/pacman-mirrors", line 28, in <module>
pm.run()
File "/usr/lib/python3.9/site-packages/pacman_mirrors/pacman_mirrors.py", line 101, in run
httpFn.download_mirror_pool(config=self.config, tty=self.tty, quiet=self.quiet)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/httpFn.py", line 190, in download_mirror_pool
result = download_mirrors(config)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/httpFn.py", line 59, in download_mirrors
resp = requests.get(url=config["url_mirrors_json"],
File "/usr/lib/python3.9/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/lib/python3.9/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.9/site-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
The same connection reset error is happening when i did try to run pacman-mirrors --fasttrack . This may not bug me for a severe issue… but could be of a concern in the near future! Any help is appreciated!
TIA
-dstyle
