got ‘pacman is currently in use, please wait…’ error
and rm /var/lib/pacman/db.lck & reboot, with no luck.
how to fix?
Hi @Rip2,
I’m guessing you need to use sudo
for the deleting:
sudo rm /var/lib/pacman/db.lck
Hope this helps!
did it but no go.
What is the output?
sudo lsattr /var/lib/pacman/db.lck
db.lck is gone.
Then you should be able to continue.
no still same error message.
Reboot.
reboot, i said it above.
Purge Pamac. Worker maybe locked pacman at all in background after login.
Please post the output of:
sudo ls /var/lib/pacman/
And
sudo ps aux | grep -i pacma[n]
ok, give up & wait 2022-02 image, thanks everyone.
