Pacman gpg key problems
Due to gpg key problems I can’t install most software (yay for example)
error: yay: signature from "Helmut Stult (schinfo) <helmut.stult@schinfo.de>" is unknown trust
:: File /var/cache/pacman/pkg/yay-10.3.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
I looked around on the internet for solutions and came to the help page on the wiki for pacman troubleshooting
https://wiki.manjaro.org/index.php?title=Pacman_troubleshooting#Errors_about_Keys
Following the steps listed there doesn’t work (errors below)
  1. no errors
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: keyring is not writable
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
  1. no errors
  2. long error message which repeats the same block of text
https://pastebin.com/sfSm7Jdi
  1. extremely long output
https://pastebin.com/FRUZWtzE
  1. I don’t think theres anything wrong with the output of this step
https://pastebin.com/AuMuScyQ
Summary
This text will be hidden
subject exists
is there a solution in that thread? I can’t really understand 90% of the posts there
There is one now…
:+1:
Il faut faire les actions 1, 3, 4, 2 dans cet ordre, en omettant l’étape 5.
You have to do step 1, then 3 then 4 then 2 in that order and don’t execute step 5.
