Pacman error during update
“Error: multilib.db: GPGME error: No data” when trying to run pacman -Syyu
I’ve run through all the steps I could find on this site. [I tried to link the 2 posts I read but your topic creator will not allow me to post links. I was going to post them here]
Nothing works. Last week my updates were fine. This week I’m getting the above mentioned error. Anyone have anything I can try besides re-installing?
search function is your friend
Did that… Got the following error(s?) back.
 core                                                  27.5 KiB   306 KiB/s 00:00 [###############################################] 100% extra                                                 27.5 KiB   918 KiB/s 00:00 [###############################################] 100% community                                             27.5 KiB  2.69 MiB/s 00:00 [###############################################] 100% multilib                                              27.5 KiB  1376 KiB/s 00:00 [###############################################] 100%error: could not open file /var/lib/pacman/sync/core.db: Unrecognized archive format
error: could not open file /var/lib/pacman/sync/extra.db: Unrecognized archive format
error: could not open file /var/lib/pacman/sync/community.db: Unrecognized archive format
error: could not open file /var/lib/pacman/sync/multilib.db: Unrecognized archive format
error: database 'core' is not valid (invalid or corrupted database (PGP signature))
error: database 'extra' is not valid (invalid or corrupted database (PGP signature))
error: database 'community' is not valid (invalid or corrupted database (PGP signature))
error: database 'multilib' is not valid (invalid or corrupted database (PGP signature))
 there is nothing to do
remove the files in /var/lib/pacman/sync and rerun pacman -Syu
the entire directory contents or specific files?
you can safely remove all files inside the sync folder - pacman will download them
rm -f /var/lib/pacman/sync/*
If you continue to have issues - you will have to change mirror
removed contents of that directory. New error below.
sudo pacman -Syu
core 27.5 KiB 275 KiB/s 00:00 [###############################################] 100% extra 27.5 KiB 459 KiB/s 00:00 [###############################################] 100% community 27.5 KiB 306 KiB/s 00:00 [###############################################] 100% multilib 27.5 KiB 688 KiB/s 00:00 [###############################################] 100%error: could not open file /var/lib/pacman/sync/core.db: Unrecognized archive format
error: database ‘core’ is not valid (invalid or corrupted database (PGP signature))
error: database ‘extra’ is not valid (invalid or corrupted database (PGP signature))
error: database ‘community’ is not valid (invalid or corrupted database (PGP signature))
error: database ‘multilib’ is not valid (invalid or corrupted database (PGP signature))
:: Starting full system upgrade…
How would I change the mirror…or is there something else to mitigate the above error?
Thanks for your help, btw!
Anyone have any further ideas?
pacman-mirrors --continent
Eureka! That seemed to work…finally! Thank you kind sir.
