Hello together,
since today i’m not able to update my system with pacman if I use the command with sudo.
If I use pacman with su it is working.
What could be the problem?
Thank you!
~ >>> sudo pacman -Syu
[sudo] password for alexander:
sudo: pacman: command not found
~ >>> su [1]
Password:
[TUF-Dev alexander]# pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: gnome-shell-extension-nightthemeswitcher: local (52-1) is newer than community (51-2)
warning: gnome-shell-extension-unite: local (57-1) is newer than community (56-1)
warning: manjaro-hello: local (0.6.7-2) is newer than extra (0.6.6-9)
warning: zsh-theme-powerlevel10k: local (1.15.0+66+g3e515a7-1) is newer than community (1.15.0-2)
there is nothing to do
[TUF-Dev alexander]# exit
exit
