If I go to packages.manjaro.org it only shows 445 packages:
Update: It’s working now.
Yeah, seems it’s only seeing kde-unstable
repository.
@codesardine there is likely an issue in database creation.
Also the problem is only happening with the x86-64 “database” because if I switch to ARM it works just fine.
yes, in status, we have an error Invalid Date
for only X86_64 … 3 testing repo date not have minutes
'Aug. 16, 2022, 6 a.m.'
A bug in code when we convert repo date to database str ? if minute == 0
curl -IL 'https://mirrors.manjaro.org/repo/testing/core/x86_64/core.db'
HTTP/2 200
last-modified: Tue, 16 Aug 2022 06:00:27 GMT
