Is there a package available with network debugging tools? I’m thinking something similar to nslookup and something that could display the headers of whats going in/out of a nic.
Search for bind-tools returns no result. Search for nslookup gives a little tool from AUR that has 500+ Mb of dependencies.
For monitoring wireshark is what comes to my mind, but I don’t need it to be that advanced
maybe you are just looking for bind
theres also net-tools
with a lot of the classic basics … most of which have been replaced by ip
counterparts. Network configuration - ArchWiki
The binaries form the former bind-tools
package are now in the normal bind
package.
Oh. So thats where nslookup has gone.
Is there any way to search for packages that contain a specific tool? Or see a list of tools included in a package? Like, if you open the link in the bind package, you’re brought to the bind program site. That doesn’t tell anything about how the packages for various distros look like.
I found the watch command default installed in manjaro. Combined with iptables it can tell whats happening on the nics.
watch -d -n 1 iptables -v -L INPUT
Sure … or rather … to search the db for a file using regex… ex:
pacman -Fx nslookup
That returns a bit … but we can look for the binary:
pacman -Fx '/bin/nslookup'
(the same rules apply for the db as regular pacman … you may need to Fyx
or Fyyx
depending on your sync status)
This is also helpful for investigating issues like missing depends.
If you get a warning like ‘error loading something.so’ you can look it up using the method above.
If you want to know all files that are part of a package you can use
pacman -Fl bind
(implies that you update the files database with -Fy
before )
If the package is already installed you can also use
pacman -Ql bind
Very useful! Thanks a lot!
Too bad this forum does not accept to mark multiple posts as solution
