for my fine Manjaro system on Pinebook Pro I would like to open a wish list for packages that today are not available for ARM resp. can not be installed/built:
AESCrypt (…for me prio 1)
kuro
microsoft-edge-stable-bin
p3x-onenote
( these are in the repos resp in AUR but stop the build process with error “…not available for aarch64…”,
which is not ideal because I think if not available for that architecture it should not be offered in pamac)
but: I like Manjaro ARM on my Pinebook a lot and I am really fascinated and thankful for all your peoples work!
There is a reason for this message. When it tells you this, it’s because it’s read from a PKGBUILD on the AUR. That’s out of the supported software by Manjaro. Nothing we can do about that.
So you have a couple of options.
You can add aarch64 to the PKGBUILD and see if it builds. If it does, fine, you can then suggest the AUR package maintainer to add it to the PKGBUILD. If it doesn’t, then the software does not support the architecture. So that should be reported to the software developers themselves. Packages called -bin likely won’t work with this, as they are pre-compiled and just repackaged.
You can disable AUR support in Pamac, so you will not get offered any software that is not installable on your device. This will exclude all the software in the AUR for you, so all your wishlist goes to zero.
Find alternatives. Maybe there are other software available in the repo, that does the same thing or have the same function.
Create a separate repository, where you have built the packages you want from the AUR and add it to your pacman.conf. This is not as easy as the other 3 options, as it requires you to have knowledge of how to build the application for your architecture, how to package it and how to maintain a repository.
AUR is not supported by Manjaro. It can often by used, yes, but it’s not something we support.
AUR is built for Arch x86_64, not with aarch64 in mind. So there will be a lot of the packages there, not taking that into account.
This is build from source but aarch64 isn’t in arch=(), you can make this change and see if it builds, then you can politely ask to add aarch64 to the AUR maintainer
kuro and p3x-onenote
While building from source is an option these depends on electron which isn’t packaged for arm
Wow, that was really helpful and clarified things for me, thanks a lot!
