Hi there,
I just switched from Kubuntu to Manjaro-KDE. Most of the things went easy, but now I have a problem with the packaging system
When I try
pamac update --force-refresh
I get
Error: failed retrieving file 'custom.db' from disk : Couldn't open file /home/custompkgs/custom.db
failed to retrieve some files
Failed to synchronize databases
Preparing...
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
Error: failed retrieving file 'custom.files' from disk : Couldn't open file /home/custompkgs/custom.files
Error: Failed to prepare transaction: could not find database
And yes, there is no folder named /home/custompkgs
When I selcet ārefresh databaseā in pamac-manager I get a
I canot make updates via pamac-manager. Only get ācould not find databaseā
As I am totally new to manjaro I have no Idea, which additional information might be usefull
I cannot remember actively adding a repo (donāt even know how to do that).
I just activated AUR
From Debian I know /etc/apt/sources.lst.
Is there a similar technic in Manjaro?
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc manjaro-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
ParallelDownloads = 4
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir = /
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
# REPOSITORIES
# [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir = /
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
# REPOSITORIES
# [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir = /
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
# REPOSITORIES
# [repo-name]
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
[custom]
SigLevel = Optional TrustAll
Server = file:///home/custompkgs
this is what the contents of /etc/pacman.conf should look like: (click to expand)
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir = /
#CacheDir = /var/cache/pacman/pkg/
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
DownloadUser = alpm
#DisableSandbox
#ILoveCandy
# keyring can then be populated with the keys of all official Arch and Manjaro Linux
# REPOSITORIES
# [repo-name]
[core]
[extra]
[multilib]
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
What you posted was several bits of it repeated multiple times.
