Whenever I try to launch pamac from the dock as a favorite it creates two of itself. If I try to remove it as a favorite and re-add it from the new icon that launched, it won’t add. This is basically a clean install of manjaro, I have only used it for a few hours. It is really bugging me that it creates two icons if I launch the package manager as a favorite. I am really stumped as to why it would do this and how to fix it.
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=2afbb717-dcce-48cd-993e-6e879fad33f8 rw quiet apparmor=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.1
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: P8H61-M LE/CSM R2.0 v: Rev x.0x
serial: <filter> UEFI: American Megatrends v: 1414 date: 09/23/2014
Info: Quad Core model: Intel Core i5-2400 bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25559
Speed: 1795 MHz min/max: 1600/3400 MHz Core speeds (MHz): 1: 1942 2: 1938
3: 2556 4: 2319
Type: l1tf
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ZOTAC driver: nvidia
v: 450.80.02 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c82
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.80.02
direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Device-2: NVIDIA GP107GL High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:095a
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: d000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 4.09 TiB used: 21.75 GiB (0.5%)
ID-1: /dev/sda vendor: Western Digital model: WDBNCE5000PNC size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: 00WD scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SBK2 scheme: GPT
ID-3: /dev/sdc vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB
rotation: 5400 rpm serial: <filter> rev: 0007 scheme: GPT
ID-1: / raw size: 122.86 GiB size: 120.43 GiB (98.02%)
used: 21.73 GiB (18.0%) fs: ext4 dev: /dev/sda6
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 27 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 45%
Processes: 304 Uptime: 10h 05m Memory: 7.71 GiB used: 1.78 GiB (23.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1251 pacman: 1235
lib: 348 flatpak: 11 snap: 5 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.08
