When I run the update manager I get the error:
no se pudieron satisfacer las dependencias:
- incapaz de satisfacer la dependencia "nvidia-450xx-utils=450.80.02" requerida por linux57-nvidia-450xx
- incapaz de satisfacer la dependencia "nvidia-450xx-utils=450.80.02" requerida por linux58-nvidia-450xx
Wich translates, roughly to:
could not satisfy dependices:
- unable to satisfy dependency "nvidia-450xx-utils=450.80.02" required by linux57-nvidia-450xx
- unable to satisfy dependency "nvidia-450xx-utils=450.80.02" required by linux58-nvidia-450xx
How can I proceed in order to keep my system up to date?
Did this in the past, most likely related:
https://forum.manjaro.org/t/when-will-nvidia-450-drivers-update-arrive/20923
[noe@perezoso ~]$ inxi -F
Host: perezoso Kernel: 5.8.11-1-MANJARO x86_64 bits: 64
Desktop: Cinnamon 4.6.7 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450M MORTAR TITANIUM (MS-7B89)
v: 2.0 serial: <superuser/root required> UEFI: American Megatrends v: A.D0
date: 06/12/2020
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP
L2 cache: 3072 KiB
Speed: 3707 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 3745 2: 2066
3: 1954 4: 2038 5: 2448 6: 3473 7: 1971 8: 2454 9: 3802 10: 2065 11: 2081
12: 3768
Device-1: NVIDIA GM107GL [Quadro K2200] driver: nvidia v: 450.66
Display: x11 server: X.Org 1.20.9 driver: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: Quadro K2200/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
Device-1: NVIDIA GM107 High Definition Audio [GeForce 940MX]
driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: Trust Widescreen 3MP Webcam type: USB
driver: snd-usb-audio,uvcvideo
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlo1 state: up mac: 6c:6a:77:e1:15:4a
driver: r8169
IF: enp34s0 state: down mac: 00:d8:61:4e:b6:3b
Local Storage: total: 698.65 GiB used: 589.05 GiB (84.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 250GB
ID-2: /dev/sda vendor: Hitachi model: HDP725050GLA360 size: 465.76 GiB
ID-1: / size: 227.94 GiB used: 152.71 GiB (67.0%) fs: ext4
dev: /dev/nvme0n1p2
System Temperatures: cpu: 35.9 C mobo: 36.0 C gpu: nvidia temp: 44 C
Fan Speeds (RPM): fan-1: 0 fan-2: 920 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 42%
Processes: 346 Uptime: 28m Memory: 31.37 GiB used: 3.08 GiB (9.8%)
Shell: Bash inxi: 3.1.05
