After my last system update I encountered a new problem.
I’m unable to activate PACAUR in octopi.
When I start a package search, I received the following message in the console :
QList::removeAt(): Index out of range.
And nothing appears in the result list.
Does anyone encounters the same problem ?
Is it still a supported way to work with AUR ?
After some more investigation I understood the problem.
pacaur didn’t work properly due to a broken dependency.
pacaur uses a tool called auracle, I forgot if I installed this tool from source years ago but it isn’t listed as a standard package in octopi.
auracle didn’t work anymore due to a removed shared library (libalpm.so.12).
To correct the problem I followed the next procedure :
