P2P miracast not working
I wanted to connect me to a Smart TV via Miracast. Unfortunately, I received an error message when activating P2P in the network settings.
What have I done:
  1. installed GNOME networkdisplays
    2.set the WIFI P2P Option to active
  2. click on the P2P settings Icon
Result I
As a result, a modal window popped up and showed the error message:
“Error processing the connection: A connection with the UUID (null) could not be found.”
In GNOME network display I see the TV but the connect fails.
What ist wrong or missing?
Some Information about my system:
CPU: 10-core (2-mt/8-st) 13th Gen Intel Core i7-1355U (-MST AMCP-)
speed/min/max: 415/400/5000:3700 MHz Kernel: 6.6.3-1-MANJARO x86_64 Up: 20m
Mem: 2.1/15.34 GiB (13.7%) Storage: 476.94 GiB (9.2% used) Procs: 268
Shell: Bash inxi: 3.3.31
 Network controller: Realtek Semiconductor Co., Ltd. Device b85b
	DeviceName: WLAN
	Subsystem: Hewlett-Packard Company Device 88e6
	Kernel driver in use: rtw89_8852be
	Kernel modules: rtw89_8852be
Wiphy phy0
	wiphy index: 0
	max # scan SSIDs: 8
	max scan IEs length: 394 bytes
	max # sched scan SSIDs: 0
	max # match sets: 0
	Retry short limit: 7
	Retry long limit: 4
	Coverage class: 0 (up to 0m)
	Device supports AP-side u-APSD.
	Device supports T-DLS.
	Supported Ciphers:
		* WEP40 (00-0f-ac:1)
		* WEP104 (00-0f-ac:5)
		* TKIP (00-0f-ac:2)
		* CCMP-128 (00-0f-ac:4)
		* CCMP-256 (00-0f-ac:10)
		* GCMP-128 (00-0f-ac:8)
		* GCMP-256 (00-0f-ac:9)
		* CMAC (00-0f-ac:6)
		* CMAC-256 (00-0f-ac:13)
		* GMAC-128 (00-0f-ac:11)
		* GMAC-256 (00-0f-ac:12)
	Available Antennas: TX 0x3 RX 0x3
	Configured Antennas: TX 0x2 RX 0
	Supported interface modes:
		 * managed
		 * AP
		 * AP/VLAN
		 * monitor
		 * P2P-client
		 * P2P-GO
	Band 1:
		Capabilities: 0x19ef
			RX LDPC
			HT20/HT40
			SM Power Save disabled
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			Max AMSDU length: 7935 bytes
			DSSS/CCK HT40
		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
		Minimum RX AMPDU time spacing: No restriction (0x00)
		HT Max RX data rate: 150 Mbps
		HT TX/RX MCS rate indexes supported: 0-7, 32
		HE Iftypes: managed
			HE MAC Capabilities (0x0801100a8060):
				+HTC HE Supported
				Trigger Frame MAC Padding Duration: 2
				All Ack
				BSR
				Maximum A-MPDU Length Exponent: 2
				OPS
				A-MSDU in A-MPDU
			HE PHY Capabilities: (0x02701e1f0dc0270e91bd00):
				HE40/2.4GHz
				Device Class: 1
				LDPC Coding in Payload
				HE SU PPDU with 1x HE-LTF and 0.8us GI
				NDP with 4x HE-LTF and 3.2us GI
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				Doppler Tx
				DCM Max Constellation: 3
				DCM Max NSS Tx: 1
				DCM Max Constellation Rx: 3
				SU Beamformee
				Beamformee STS <= 80Mhz: 3
				Ng = 16 SU Feedback
				Ng = 16 MU Feedback
				Codebook Size SU Feedback
				Codebook Size MU Feedback
				Triggered SU Beamforming Feedback
				Partial Bandwidth Extended Range
				Power Boost Factor ar
				HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
				Max NC: 1
				HE ER SU PPDU 4x HE-LTF 0.8us GI
				HE ER SU PPDU 1x HE-LTF 0.8us GI
				DCM Max BW: 2
				Longer Than 16HE SIG-B OFDM Symbols
				TX 1024-QAM
				RX 1024-QAM
				RX Full BW SU Using HE MU PPDU with Compression SIGB
				RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
			HE RX MCS and NSS set <= 80 MHz
				1 streams: MCS 0-11
				2 streams: not supported
				3 streams: not supported
				4 streams: not supported
				5 streams: not supported
				6 streams: not supported
				7 streams: not supported
				8 streams: not supported
			HE TX MCS and NSS set <= 80 MHz
				1 streams: MCS 0-11
		EHT Iftypes: managed
			EHT MAC Capabilities (0x0000):
			EHT PHY Capabilities: (0x0000000000000000):
			EHT MCS/NSS: (0x):
			EHT bw=20 MHz, max NSS for MCS 0-7: Rx=0, Tx=0
			EHT bw=20 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
			EHT bw=20 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
			EHT bw=20 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
		HE Iftypes: AP
			HE MAC Capabilities (0x0001120a0060):
				+HTC HE Supported
				All Ack
				BSR
				OM Control
				OPS
				A-MSDU in A-MPDU
			HE PHY Capabilities: (0x02701e580dc0270e91b900):
				HE40/2.4GHz
				Device Class: 1
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				Doppler Tx
				Rx HE MU PPDU from Non-AP STA
				SU Beamformee
				Ng = 16 SU Feedback
				Ng = 16 MU Feedback
				Max NC: 1
				DCM Max BW: 2
				RX 1024-QAM
				1 streams: MCS 0-11
				1 streams: MCS 0-11
		EHT Iftypes: AP
			EHT MCS/NSS: (0x):
		Bitrates (non-HT):
			* 1.0 Mbps
			* 2.0 Mbps
			* 5.5 Mbps
			* 11.0 Mbps
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 2412 MHz [1] (20.0 dBm)
			* 2417 MHz [2] (20.0 dBm)
			* 2422 MHz [3] (20.0 dBm)
			* 2427 MHz [4] (20.0 dBm)
			* 2432 MHz [5] (20.0 dBm)
			* 2437 MHz [6] (20.0 dBm)
			* 2442 MHz [7] (20.0 dBm)
			* 2447 MHz [8] (20.0 dBm)
			* 2452 MHz [9] (20.0 dBm)
			* 2457 MHz [10] (20.0 dBm)
			* 2462 MHz [11] (20.0 dBm)
			* 2467 MHz [12] (20.0 dBm)
			* 2472 MHz [13] (20.0 dBm)
			* 2484 MHz [14] (disabled)
	Band 2:
			RX LDPC
			HT20/HT40
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			DSSS/CCK HT40
		VHT Capabilities (0x03d071b2):
			Max MPDU length: 11454
			Supported Channel Width: neither 160 nor 80+80
			RX LDPC
			short GI (80 MHz)
			TX STBC
			SU Beamformee
			MU Beamformee
			+HTC-VHT
		VHT RX MCS set:
			1 streams: MCS 0-9
		VHT RX highest supported: 433 Mbps
		VHT TX MCS set:
			1 streams: MCS 0-9
		VHT TX highest supported: 433 Mbps
		VHT extended NSS: not supported
		HE Iftypes: managed
				+HTC HE Supported
				All Ack
				BSR
				OPS
				A-MSDU in A-MPDU
			HE PHY Capabilities: (0x04701e1f0dc0270e91bd00):
				HE40/HE80/5GHz
				Device Class: 1
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				Doppler Tx
				DCM Max NSS Tx: 1
				SU Beamformee
				Ng = 16 SU Feedback
				Ng = 16 MU Feedback
				Max NC: 1
				DCM Max BW: 2
				TX 1024-QAM
				RX 1024-QAM
				1 streams: MCS 0-11
				1 streams: MCS 0-11
			EHT MCS/NSS: (0x):
			EHT bw <= 80 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
			EHT bw <= 80 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
			EHT bw <= 80 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
		HE Iftypes: AP
				+HTC HE Supported
				All Ack
				BSR
				OM Control
				OPS
				A-MSDU in A-MPDU
			HE PHY Capabilities: (0x04701e580dc0270e91b900):
				HE40/HE80/5GHz
				Device Class: 1
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				Doppler Tx
				SU Beamformee
				Ng = 16 SU Feedback
				Ng = 16 MU Feedback
				Max NC: 1
				DCM Max BW: 2
				RX 1024-QAM
				1 streams: MCS 0-11
				1 streams: MCS 0-11
		EHT Iftypes: AP
			EHT MCS/NSS: (0x):
		Bitrates (non-HT):
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 5180 MHz [36] (23.0 dBm)
			* 5200 MHz [40] (23.0 dBm)
			* 5220 MHz [44] (23.0 dBm)
			* 5240 MHz [48] (23.0 dBm)
			* 5260 MHz [52] (20.0 dBm) (radar detection)
			* 5280 MHz [56] (20.0 dBm) (radar detection)
			* 5300 MHz [60] (20.0 dBm) (radar detection)
			* 5320 MHz [64] (20.0 dBm) (radar detection)
			* 5500 MHz [100] (26.0 dBm) (radar detection)
			* 5520 MHz [104] (26.0 dBm) (radar detection)
			* 5540 MHz [108] (26.0 dBm) (radar detection)
			* 5560 MHz [112] (26.0 dBm) (radar detection)
			* 5580 MHz [116] (26.0 dBm) (radar detection)
			* 5600 MHz [120] (26.0 dBm) (radar detection)
			* 5620 MHz [124] (26.0 dBm) (radar detection)
			* 5640 MHz [128] (26.0 dBm) (radar detection)
			* 5660 MHz [132] (26.0 dBm) (radar detection)
			* 5680 MHz [136] (26.0 dBm) (radar detection)
			* 5700 MHz [140] (26.0 dBm) (radar detection)
			* 5720 MHz [144] (13.0 dBm) (radar detection)
			* 5745 MHz [149] (13.0 dBm)
			* 5765 MHz [153] (13.0 dBm)
			* 5785 MHz [157] (13.0 dBm)
			* 5805 MHz [161] (13.0 dBm)
			* 5825 MHz [165] (13.0 dBm)
			* 5845 MHz [169] (13.0 dBm)
			* 5865 MHz [173] (13.0 dBm)
			* 5885 MHz [177] (disabled)
	Supported commands:
		 * new_interface
		 * set_interface
		 * new_key
		 * start_ap
		 * new_station
		 * new_mpath
		 * set_mesh_config
		 * set_bss
		 * authenticate
		 * associate
		 * deauthenticate
		 * disassociate
		 * join_ibss
		 * join_mesh
		 * remain_on_channel
		 * set_tx_bitrate_mask
		 * frame
		 * frame_wait_cancel
		 * set_wiphy_netns
		 * set_channel
		 * tdls_mgmt
		 * tdls_oper
		 * probe_client
		 * set_noack_map
		 * register_beacons
		 * start_p2p_device
		 * set_mcast_rate
		 * connect
		 * disconnect
		 * set_qos_map
		 * set_multicast_to_unicast
		 * set_sar_specs
	WoWLAN support:
		 * wake up on disconnect
		 * wake up on magic packet
		 * wake up on pattern match, up to 18 patterns of 1-128 bytes,
		   maximum packet offset 0 bytes
	software interface modes (can always be added):
		 * AP/VLAN
		 * monitor
	valid interface combinations:
		 * #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1,
		   total <= 2, #channels <= 1
	HT Capability overrides:
		 * MCS: ff ff ff ff ff ff ff ff ff ff
		 * maximum A-MSDU length
		 * supported channel width
		 * short GI for 40 MHz
		 * max A-MPDU length exponent
		 * min MPDU start spacing
	Device supports TX status socket option.
	Device supports HT-IBSS.
	Device supports SAE with AUTHENTICATE command
	Device supports scan flush.
	Device supports per-vif TX power setting
	Driver supports full state transitions for AP/GO clients
	Driver supports a userspace MPM
	Device supports configuring vdev MAC-addr on create.
	Device supports randomizing MAC-addr in scans.
	max # scan plans: 1
	max scan plan interval: -1
	max scan plan iterations: 0
	Supported TX frame types:
		 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
	Supported RX frame types:
		 * IBSS: 0x40 0xb0 0xc0 0xd0
		 * managed: 0x40 0xb0 0xd0
		 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * mesh point: 0xb0 0xc0 0xd0
		 * P2P-client: 0x40 0xd0
		 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * P2P-device: 0x40 0xd0
	Supported extended features:
		* [ RRM ]: RRM
		* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
		* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
		* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
		* [ CAN_REPLACE_PTK0 ]: can safely replace PTK 0 when rekeying
		* [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
		* [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
		* [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
[mirko@WaidTek ~]$ iw dev
phy#0
	Interface wlo1
		ifindex 2
		wdev 0x1
		addr 40:1a:58:56:be:d9
		ssid HeavensDoor
		type managed
		channel 5 (2432 MHz), width: 20 MHz, center1: 2432 MHz
		txpower 20.00 dBm
		multicast TXQ:
			qsz-byt	qsz-pkt	flows	drops	marks	overlmt	hashcoltx-bytes	tx-packets
			0	0	0	0	0	0	0	00
Thank you in advance for the help
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Have you tried gnome-network-displays-git?
Note that I fixed your formatting–this time. :wink: Please see [HowTo] Post command output and file content as formatted text
:+1: Thanks, I was wondering how I could do that.
actual installed is Gnome-network-displays -Should the Gnome-network-displays-git package be seen as an addition or replacement?
In the meantime I installed Gnome-network-displays-git. The behavior is exactly the same.
Look/read here:
https://aur.archlinux.org/packages/gnome-network-displays#comment-940674
An user says that dnsmasq is required.
gst-plugins-good and dnsmasq are ready installed. According to the reference you gave, I can only see my TV because the dnsmasq package is installed.
Otherwise the debug output seems to correspond to my problem.
(gnome-network-displays:2264): GStreamer-CRITICAL **: 17:43:55.998: gst_element_send_event: assertion ‘event != NULL’ failed
The dialogue in the forum you linked ends in a debate about non-exit keys for a gst-rtsp server.
At this point I’m out of there. You can learn a lot about package dependencies, but that doesn’t help me solve my problem myself.
I am grateful for further constructive and helpful suggestions.
The behavior is exactly the same with another much newer Smart TV.
I started gnome-network-displays in the terminal, here is the result:
** (gnome-network-displays:2326): WARNING **: 17:24:21.496: Error calling DBus method during Screencast portal initialization: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Keine derartige Schnittstelle »org.freedesktop.portal.ScreenCast« des Objekts im Pfad /org/freedesktop/portal/desktop
** (gnome-network-displays:2326): WARNING **: 17:24:21.496: Error initing screencast portal: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Keine derartige Schnittstelle »org.freedesktop.portal.ScreenCast« des Objekts im Pfad /org/freedesktop/portal/desktop
** (gnome-network-displays:2326): WARNING **: 17:24:21.496: Screencasting portal is unavailable! It is required to select the monitor to stream!
** (gnome-network-displays:2326): WARNING **: 17:24:21.496: Falling back to X11! You need to fix your setup to avoid issues (XDG Portals and/or mutter screencasting support)!
It would certainly be interesting to remove these warnings. Who can support me?
