The amd_pstate CPU power scaling driver is not active by default, but can be manually enabled when using a supported CPU (Zen 2 and newer) by adding amd_pstate=passive, amd_pstate=active or amd_pstate=guided as a kernel parameter. Some motherboards might not enable the required setting in their firmware, leading to a the _CPC object is not present in SBIOS or ACPI disabled error. Change Enable CPPC , usually found in the AMD CBS > NBIO > SMU > CPPC, from Auto to Enabled, or any similar settings in your UEFI. If they are not present, consult the vendor website for an update.
That is exactly what I wanted to know, thank You!!!
Confirmed this CPU uses the default acpi-driver on all kernels.
So the warning is to ignore safely…
