I’ve been using Oxygen Mono as my monospace font in the kitty terminal emulator, after I failed to get Monaco working (I installed it, but it was not considered monospace by the system). When I updated my packages yesterday, Oxygen Mono stopped working in kitty, and fc-query
shows that it doesn’t have a spacing value. kitty wasn’t updated in this batch of updates and the font itself is still recognised by the system and hasn’t moved or been modified. I have no idea what caused this or how to fix it.
Here is my output for inxi -Fazy
Kernel: 5.7.12-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=3ee3ea5d-c1ba-43e1-887b-8ef291ef557e rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Apple product: iMac13,2 v: 1.0 serial: <filter>
Chassis: type: 13 v: Mac-FC02E91DDD3FA6A4 serial: <filter>
Mobo: Apple model: Mac-FC02E91DDD3FA6A4 v: iMac13,2 serial: <filter>
UEFI: Apple v: 291.0.0.0.0 date: 04/12/2020
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Topology: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 54297
Speed: 1620 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1596 2: 1597
3: 1597 4: 1597 5: 1596 6: 1597 7: 1596 8: 1597
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GK104M [GeForce GTX 680MX] vendor: Apple iMac 13 2
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:11a3
Device-2: Apple type: USB driver: uvcvideo bus ID: 1-1.1:3
chip ID: 05ac:8511 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting
alternate: fbdev,nouveau,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DP-1 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVE4 v: 4.3 Mesa 20.1.6 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Device-2: NVIDIA GK104 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0a
Sound Server: ALSA v: k5.7.12-arch1-1
Device-1: Broadcom and subsidiaries NetXtreme BCM57766 Gigabit Ethernet PCIe
vendor: Apple driver: tg3 v: kernel port: 2000 bus ID: 03:00.0
chip ID: 14e4:1686
IF: enp3s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Broadcom and subsidiaries BCM4331 802.11a/b/g/n
vendor: Apple AirPort Extreme driver: wl v: kernel modules: bcma port: 2000
bus ID: 04:00.0 chip ID: 14e4:4331
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: enp0s20u1c4i2 state: down mac: <filter>
IF-ID-2: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 2.73 TiB used: 28.08 GiB (1.0%)
ID-1: /dev/sda vendor: Apple model: HDD ST3000DM001 size: 2.73 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: AQ03 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Toshiba model: TransMemory size: 3.75 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: PMAP
scheme: MBR
ID-1: / raw size: 147.92 GiB size: 144.60 GiB (97.75%)
used: 28.03 GiB (19.4%) fs: ext4 dev: /dev/sda6
System Temperatures: cpu: 68.0 C mobo: N/A gpu: nouveau temp: 63 C
Processes: 306 Uptime: 20h 16m Memory: 15.58 GiB used: 3.50 GiB (22.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1277 lib: 324 flatpak: 0 Shell: Zsh v: 5.8 running in: kitty
inxi: 3.1.05
