Kernel: 6.8.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: GNOME v: 45.4 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 38.4 Wh (100.0%) condition: 38.4/60.0 Wh (64.0%) volts: 17.0 min: 15.4
model: Celxpert L19C4PC0 status: full
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1836 high: 3447 min/max: 1400/2900 boost: enabled cores: 1: 3447 2: 2900
3: 1652 4: 1400 5: 1420 6: 1400 7: 1400 8: 1400 9: 1413 10: 1400 11: 1532 12: 2900 13: 1426
14: 1400 15: 1400 16: 2900 bogomips: 92659
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia v: 550.67
arch: Turing bus-ID: 01:00.0
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
bus-ID: 05:00.0 temp: 56.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB bus-ID: 1-3:2
Display: x11 server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu,nvidia dri: radeonsi gpu: amdgpu resolution: 1920x1080~120Hz
API: Vulkan v: 1.3.279 drivers: radv,nvidia,llvmpipe surfaces: xcb,xlib devices: 3
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
API: ALSA v: k6.8.5-1-MANJARO status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.0.3 status: off
Server-4: PulseAudio v: 17.0 status: active
vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
I have over-amplification turned on, but when going beyond 100% there’s no increase in the volume. It used to work just fine. Using PulseAudio Volume Control to go beyond 100% works. What can I do to fix over-amplification?
