Output of Inxi graphic does not correspond with found graphic in game poe
Hi, i have a iris xe graphic in my laptop
Blockzitat System:
Host: Kiste Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce
v: 4.18.1 Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 17-cn0xxx v: N/A
serial:
Mobo: HP model: 883C v: 69.16 serial: UEFI: AMI
v: F.03 date: 03/11/2021
ID-1: BAT0 charge: 32.7 Wh (98.8%) condition: 33.1/33.1 Wh (100.0%)
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
cache: L2: 5 MiB
Speed (MHz): avg: 1105 min/max: 400/4200 cores: 1: 1241 2: 1362 3: 1277
4: 1329 5: 1419 6: 806 7: 1007 8: 400
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
dri: iris gpu: i915 resolution: 1600x900~60Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio
driver: sof-audio-pci-intel-tgl
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce
IF: wlp1s0 state: up mac: 80:d2:1d:d1:cc:55
Device-1: Realtek Bluetooth Radio driver: btusb type: USB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
Local Storage: total: 476.94 GiB used: 50.02 GiB (10.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ512HALU-000H1
ID-1: / size: 232.95 GiB used: 50.01 GiB (21.5%) fs: ext4
dev: /dev/nvme0n1p4
ID-2: /boot/efi size: 511 MiB used: 10.9 MiB (2.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 976 MiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 227 Uptime: 58m Memory: total: 32 GiB note: est.
available: 31.03 GiB used: 6.34 GiB (20.4%) Shell: Bash inxi: 3.3.28
but the game poe tells me that i only have a “Intel hd graphics 4000”
Is there the wrong driver installed on my laptop? How can i change it to Iris XE graphic? Thanks for helping :slight_smile: Please tell me what info you also need for to help and how i can get it cause i am only a low level linux user, do not know much.
There is only one driver for all Intel GPU. Maybe your GPU pretending to be another to avoid problems in game. Something like here
Some of the Intel Xe graphics processors identify as Intel 4000 — it’s their internal product ID — so that is perfectly fine. :wink:
Uuh, sounds crazy :scream: What if the games do internal settings cause of product ID? Not the best doing by Intel. Ok, i can play the game, the performance is good enough. So thanks for the answers. I will ignore it and hope Intel will do better in future.
According to me, that would be a terrible limitation. It’s internal, not for use by anyone else.
AFAIK games work with the driver for identifying capabilities anyway. Else, what would the use of a driver be?
mh, yes, sounds logic
