Hey, I just downloaded the Manjaro Ornana 21.0 iso that’s on the official build page for KDE but for some reason I notice that when I go and install the OS, it doesn’t even install the bootloader at all, in fact, the OS doesn’t even seem to install at all, but it does format the disks. I’m not sure what to do next, I’ve gone and verified the Iso and it matched the hashes listed on the website. The iso im using is the full install of manjaro kde with Linux 5.10. And for the installer, I have the iso sitting in ventoy v1.0.38.
Hello @NovaViper
To investigate what was wrong there, boot up the install disk again, open a terminal and type sudo calamares -d
to start the installer in debug mode and install again. After installation you can copy and paste the log from the terminal output or look at /var/log/
; there must be a file named with calamares.log
Please post the log here
Ok, im doing it now. By the way, is there an older version of the ISO? I really need to get my computer back on for school
Here you go: Downloading File /kde - Manjaro Linux - OSDN
Erm… no file was generated in /var/log. And this is all I ended up getting
16:37:36 [6]: virtual void Calamares::JobThread::run()
Starting job "Delete partition /dev/sda1." ( 5 / 42 )
16:37:38 [6]: virtual void Calamares::JobThread::run()
Starting job "Create new 300MiB partition on /dev/sda (SPCC Solid State Disk)." ( 6 / 42 )
16:37:42 [6]: virtual void Calamares::JobThread::run()
Starting job "Set flags on partition /dev/sda1." ( 7 / 42 )
16:37:42 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
Setting flags on "/dev/sda" partition "/dev/sda1" to QFlags(0x1)
16:37:43 [6]: virtual void Calamares::JobThread::run()
Starting job "Delete partition /dev/sda3." ( 8 / 42 )
16:37:45 [6]: virtual void Calamares::JobThread::run()
Starting job "Delete partition /dev/sda2." ( 9 / 42 )
16:37:48 [6]: virtual void Calamares::JobThread::run()
Starting job "Create new 17614MiB partition on /dev/sda (SPCC Solid State Disk)." ( 10 / 42 )
16:37:51 [6]: virtual void Calamares::JobThread::run()
Starting job "Set flags on partition /dev/sda2." ( 11 / 42 )
16:37:51 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
Setting flags on "/dev/sda" partition "/dev/sda2" to QFlags(0x4)
16:37:52 [6]: virtual void Calamares::JobThread::run()
Starting job "Create new 226283MiB partition on /dev/sda (SPCC Solid State Disk)." ( 12 / 42 )
16:38:05 [6]: virtual void Calamares::JobThread::run()
Starting job "Delete partition /dev/sdb1." ( 13 / 42 )
16:38:08 [6]: virtual void Calamares::JobThread::run()
Starting job "Create new 715403MiB partition on /dev/sdb (WDC WD7500BPVX-60JC3T0)." ( 14 / 42 )
16:38:23 [6]: virtual void Calamares::JobThread::run()
Starting job "Set partition information" ( 15 / 42 )
16:38:23 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
Building partition information map
.. partitions on "/dev/sda"
.. mapping for "/dev/sda1" "/dev/sda1"
partlabel : ""
partuuid : "87368493-20EE-5F49-A250-49462BD87833"
parttype : ""
partattrs : "13511005043687473"
mountPoint: : "/boot/efi"
fs: : "fat32"
fsName : "fat32"
uuid : "8A4A-97E9"
claimed : "true"
.. mapping for "/dev/sda3" "/dev/sda3"
partlabel : ""
partuuid : "D2180E77-FC18-B04B-BD98-278B37B3586F"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "btrfs"
fsName : "btrfs"
uuid : "515f911b-34b0-407d-9c73-c0a8fb3421de"
claimed : "true"
.. mapping for "/dev/sda2" "/dev/sda2"
partlabel : ""
partuuid : "05D780F1-3B5D-E240-84E4-43488A5DDA31"
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
fsName : "linuxswap"
uuid : "77a855e9-6405-45bb-bf06-1858c694d7cb"
claimed : "true"
.. partitions on "/dev/sdb"
.. mapping for "/dev/sdb1" "/dev/sdb1"
partlabel : ""
partuuid : "2D6D3805-E1E1-1043-9F34-0F8B72BEB951"
parttype : ""
partattrs : "0"
mountPoint: : "/home"
fs: : "btrfs"
fsName : "btrfs"
uuid : "68459409-6492-47f6-bf76-fb4498df7d2d"
claimed : "true"
.. partitions on "/dev/sdc"
.. mapping for "/dev/sdc1" "/dev/sdc1"
partlabel : ""
partuuid : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "exfat"
fsName : "exfat"
uuid : "0544-06B9"
claimed : "false"
.. mapping for "/dev/sdc2" "/dev/sdc2"
partlabel : ""
partuuid : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "fat16"
fsName : "fat16"
uuid : "5079-58EC"
claimed : "false"
16:38:23 [6]: virtual Calamares::JobResult FillGlobalStorageJob::exec()
Saving partition information map to GlobalStorage["partitions"]
FillGlobalStorageJob writing empty bootLoader value
Starting job "Manage auto-mount settings" ( 16 / 42 )
this @0x55e6876df8f0 value S@0x7f25a80028a0 restore
Starting job "mount" ( 17 / 42 )
16:38:23 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/mount/main.py"
16:38:23 [6]: boost::python::api::object CalamaresPython::gettext_path()
Determining gettext path from ("/home/manjaro", "/usr/bin", "/usr/share/locale")
.. Found "en_US" in "/usr/share/locale/en_US"
.. Job description from pretty_name "mount" = "Mounting partitions."
chcon: failed to get security context of '/': Operation not supported
16:38:23 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "env" ("mount", "-t", "btrfs", "/dev/sda3", "/tmp/calamares-root-uet5jqou/")
.. Finished. Exit code: 0
Running "env" ("udevadm", "settle")
Running "env" ("sync")
Create subvolume '/tmp/calamares-root-uet5jqou/@'
umount: /tmp/calamares-root-uet5jqou unmounted
Running "env" ("mount", "-t", "btrfs", "-o", "subvol=@,", "/dev/sda3", "/tmp/calamares-root-uet5jqou/")
chcon: failed to get security context of '/boot/efi': Operation not supported
Running "env" ("mount", "-t", "vfat", "/dev/sda1", "/tmp/calamares-root-uet5jqou/boot/efi")
chcon: failed to get security context of '/dev': Operation not supported
Running "env" ("mount", "-o", "bind", "/dev", "/tmp/calamares-root-uet5jqou/dev")
chcon: failed to get security context of '/home': Operation not supported
Running "env" ("mount", "-t", "btrfs", "/dev/sdb1", "/tmp/calamares-root-uet5jqou/home")
chcon: failed to get security context of '/proc': Operation not supported
16:38:24 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "env" ("mount", "-t", "proc", "proc", "/tmp/calamares-root-uet5jqou/proc")
chcon: failed to get security context of '/run': Operation not supported
Running "env" ("mount", "-t", "tmpfs", "tmpfs", "/tmp/calamares-root-uet5jqou/run")
chcon: failed to get security context of '/run/udev': Operation not supported
Running "env" ("mount", "-o", "bind", "/run/udev", "/tmp/calamares-root-uet5jqou/run/udev")
chcon: failed to get security context of '/sys': Operation not supported
Running "env" ("mount", "-t", "sysfs", "sys", "/tmp/calamares-root-uet5jqou/sys")
chcon: failed to get security context of '/sys/firmware/efi/efivars': Operation not supported
Running "env" ("mount", "-t", "efivarfs", "efivarfs", "/tmp/calamares-root-uet5jqou/sys/firmware/efi/efivars")
16:38:24 [6]: virtual void Calamares::JobThread::run()
Starting job "unpackfs" ( 18 / 42 )
16:38:24 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/unpackfs/main.py"
16:38:24 [6]: boost::python::api::object CalamaresPython::gettext_path()
.. Job description from pretty_name "unpackfs" = "Filling up filesystems."
Running "env" ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs", "/tmp/tmpk3g4aj3k/rootfs")
.. Finished. Exit code: 0 output:
mount: /tmp/tmpk3g4aj3k/rootfs: WARNING: source write-protected, mounted read-only.
16:38:56 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "env" ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs", "/tmp/tmpk3g4aj3k/desktopfs")
mount: /tmp/tmpk3g4aj3k/desktopfs: WARNING: source write-protected, mounted read-only.
16:40:23 [6]: virtual void Calamares::JobThread::run()
Starting job "networkcfg" ( 19 / 42 )
16:40:23 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/networkcfg/main.py"
16:40:23 [6]: boost::python::api::object CalamaresPython::gettext_path()
.. Job description from pretty_name "networkcfg" = "Saving network configuration."
Starting job "Generate machine-id." ( 20 / 42 )
16:40:23 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemd-machine-id-setup")
Initializing machine ID from random generator.
16:40:25 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "ln", "-sf", "/etc/machine-id", "/var/lib/dbus/machine-id")
16:40:25 [6]: virtual void Calamares::JobThread::run()
Starting job "fstab" ( 21 / 42 )
16:40:25 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/fstab/main.py"
16:40:25 [6]: boost::python::api::object CalamaresPython::gettext_path()
.. Job description from pretty_name "fstab" = "Writing fstab."
Starting job "Set timezone to America/Chicago" ( 22 / 42 )
Running "chroot" ("/tmp/calamares-root-uet5jqou", "rm", "-f", "/etc/localtime")
Running "chroot" ("/tmp/calamares-root-uet5jqou", "ln", "-s", "/usr/share/zoneinfo/America/Chicago", "/etc/localtime")
Starting job "Set keyboard model to , layout to us-" ( 23 / 42 )
16:40:25 [6]: virtual Calamares::JobResult SetKeyboardLayoutJob::exec()
Executing SetKeyboardLayoutJob
16:40:25 [6]: bool SetKeyboardLayoutJob::writeVConsoleData(const QString&, const QString&) const
Writing vconsole data to "/tmp/calamares-root-uet5jqou/etc/vconsole.conf"
16:40:25 [6]: QString SetKeyboardLayoutJob::findConvertedKeymap(const QString&) const
Looking for converted keymap in "/tmp/calamares-root-uet5jqou/lib/kbd/keymaps/xkb"
16:40:25 [6]: QString findLegacyKeymap(const QString&, const QString&, const QString&)
Looking for legacy keymap "us" "" "" in QRC
.. Found legacy keymap "us" with score 12
.. Written KEYMAP= "us" to vconsole.conf 0
16:40:25 [6]: bool SetKeyboardLayoutJob::writeX11Data(const QString&) const
Writing X11 configuration to "/tmp/calamares-root-uet5jqou/etc/X11/xorg.conf.d/00-keyboard.conf"
.. Written XkbLayout "us" ; XkbModel "" ; XkbVariant "" to X.org file "/tmp/calamares-root-uet5jqou/etc/X11/xorg.conf.d/00-keyboard.conf" 0
16:40:25 [6]: bool SetKeyboardLayoutJob::writeDefaultKeyboardData(const QString&) const
Writing default keyboard data to "/tmp/calamares-root-uet5jqou/etc/default/keyboard"
.. Written XKBMODEL "" ; XKBLAYOUT "us" ; XKBVARIANT "" to /etc/default/keyboard file "/tmp/calamares-root-uet5jqou/etc/default/keyboard" 0
Starting job "localecfg" ( 24 / 42 )
Job file "/usr/lib/calamares/modules/localecfg/main.py"
.. Job description from pretty_name "localecfg" = "Configuring locales."
Running "chroot" ("/tmp/calamares-root-uet5jqou", "locale-gen")
Generating locales...
en_US.UTF-8... done
Generation complete.
[PYTHON JOB]: "/tmp/calamares-root-uet5jqou/etc/locale.gen done"
[PYTHON JOB]: "/tmp/calamares-root-uet5jqou/etc/locale.conf done"
[PYTHON JOB]: "/tmp/calamares-root-uet5jqou/etc/default done"
16:40:26 [6]: virtual void Calamares::JobThread::run()
Starting job "luksopenswaphookcfg" ( 25 / 42 )
16:40:26 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/luksopenswaphookcfg/main.py"
16:40:26 [6]: boost::python::api::object CalamaresPython::gettext_path()
.. Job description from pretty_name "luksopenswaphookcfg" = "Configuring encrypted swap."
Starting job "Configuring LUKS key file." ( 26 / 42 )
16:40:26 [6]: virtual Calamares::JobResult LuksBootKeyFileJob::exec()
There are 0 LUKS partitions
.. Nothing to do for LUKS.
Starting job "initcpiocfg" ( 27 / 42 )
Job file "/usr/lib/calamares/modules/initcpiocfg/main.py"
.. Job description from pretty_name "initcpiocfg" = "Configuring mkinitcpio."
16:40:26 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "sh", "-c", "which plymouth")
.. Target cmd: ("sh", "-c", "which plymouth") Exit code: 1 output:
which: no plymouth in (/home/manjaro/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin)
[PYTHON JOB]: "which plymouth exit code: 1"
Starting job "Creating initramfs with mkinitcpio." ( 28 / 42 )
16:40:26 [6]: virtual Calamares::JobResult InitcpioJob::exec()
Updating initramfs with kernel "linux510"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "mkinitcpio", "-p", "linux510")
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.23-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
16:40:39 [6]: virtual void Calamares::JobThread::run()
Starting job "Configure <pre>sudo</pre> users." ( 29 / 42 )
Starting job "Preparing groups." ( 30 / 42 )
Starting job "Create user novaviper" ( 31 / 42 )
16:40:39 [6]: virtual Calamares::JobResult CreateUserJob::exec()
[CREATEUSER]: creating user
16:40:39 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "useradd", "-m", "-U", "-s", "/bin/bash", "-c", "NovaViper", "novaviper")
Running "chroot" "/tmp/calamares-root-uet5jqou" "usermod" "-aG" "lp,network,power,sys,wheel" "novaviper"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "chown", "-R", "novaviper:novaviper", "/home/novaviper")
Starting job "Set password for user novaviper" ( 32 / 42 )
Running "chroot" "/tmp/calamares-root-uet5jqou" "usermod" "-p" <password> "novaviper"
Starting job "Set password for user root" ( 33 / 42 )
Running "chroot" "/tmp/calamares-root-uet5jqou" "usermod" "-p" <password> "root"
Starting job "Set hostname RyzenNova" ( 34 / 42 )
Starting job "displaymanager" ( 35 / 42 )
16:40:39 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/displaymanager/main.py"
16:40:39 [6]: boost::python::api::object CalamaresPython::gettext_path()
.. Job description from __doc__ "displaymanager" = "Configure display managers."
[PYTHON JOB]: "lightdm selected but not installed"
[PYTHON JOB]: "gdm selected but not installed"
[PYTHON JOB]: "mdm selected but not installed"
[PYTHON JOB]: "lxdm selected but not installed"
[PYTHON JOB]: "slim selected but not installed"
[PYTHON JOB]: "Using rootMountPoint '/tmp/calamares-root-uet5jqou'"
[PYTHON JOB]: ".. selected DE plasma"
[PYTHON JOB]: "Unsetting autologin."
Starting job "mhwdcfg" ( 36 / 42 )
Job file "/usr/lib/calamares/modules/mhwdcfg/main.py"
.. Job description from __doc__ "mhwdcfg" = "Configure the hardware"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "mhwd", "-a", "pci", "nonfree", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/catalyst/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-340xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-418xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-430xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-435xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-440xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-340xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-418xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-435xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-440xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
Warning: No config found for device: 0000:24:00.0 (0200:8086:24f3) Network controller Intel Corporation Wireless 8260
Warning: No config found for device: 0000:22:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
16:40:40 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "mhwd", "-a", "pci", "nonfree", "0280", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
Warning: No device of class 0280 found!
16:40:41 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "mhwd", "-a", "pci", "nonfree", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
> Using config 'video-nvidia' for device: 0000:27:00.0 (0300:10de:1c03) Display controller nVidia Corporation GP106 [GeForce GTX 1060 6GB]
> Installing video-nvidia...
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
downloading mhwd.db...
resolving dependencies...
Packages (3) lib32-nvidia-utils-460.56-1 linux510-nvidia-460.56-6 nvidia-utils-460.56-2
Total Download Size: 131.52 MiB
Total Installed Size: 447.24 MiB
:: Retrieving packages...
downloading nvidia-utils-460.56-2-x86_64.pkg.tar.zst...
downloading lib32-nvidia-utils-460.56-1-x86_64.pkg.tar.zst...
downloading linux510-nvidia-460.56-6-x86_64.pkg.tar.zst...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing nvidia-utils...
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-utils
gtk3: nvidia-settings [installed]
xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support
installing lib32-nvidia-utils...
Optional dependencies for lib32-nvidia-utils
lib32-opencl-nvidia
installing linux510-nvidia...
In order to use nvidia module, reboot the system.
(1/6) Creating system user accounts...
Creating group nvidia-persistenced with gid 143.
Creating user nvidia-persistenced (NVIDIA Persistence Daemon) with uid 143 and gid 143.
(2/6) Reloading system manager configuration...
Skipped: Current root is not booted.
(3/6) Arming ConditionNeedsUpdate...
(4/6) Updating module dependencies...
(5/6) Updating Kernel initcpios for Nvidia-DRM...
(6/6) Updating the desktop file MIME type cache...
nvidia-utils: install reason has been set to 'explicitly installed'
lib32-nvidia-utils: install reason has been set to 'explicitly installed'
linux510-nvidia: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
> Successfully installed video-nvidia
16:41:07 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "mhwd", "-a", "pci", "nonfree", "0302", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
Warning: No device of class 0302 found!
16:41:08 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "mhwd", "-a", "pci", "nonfree", "0380", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
Warning: No device of class 0380 found!
16:41:09 [6]: virtual void Calamares::JobThread::run()
Starting job "hwclock" ( 37 / 42 )
16:41:09 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/hwclock/main.py"
16:41:09 [6]: boost::python::api::object CalamaresPython::gettext_path()
.. Job description from pretty_name "hwclock" = "Setting hardware clock."
16:41:09 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "hwclock", "--systohc", "--utc")
[PYTHON JOB]: "Hwclock set using RTC method."
Starting job "services" ( 38 / 42 )
Job file "/usr/lib/calamares/modules/services/main.py"
.. Job description from pretty_name "services" = "Configure systemd services"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "avahi-daemon.service")
Created symlink /etc/systemd/system/dbus-org.freedesktop.Avahi.service -> /usr/lib/systemd/system/avahi-daemon.service.
Created symlink /etc/systemd/system/multi-user.target.wants/avahi-daemon.service -> /usr/lib/systemd/system/avahi-daemon.service.
Created symlink /etc/systemd/system/sockets.target.wants/avahi-daemon.socket -> /usr/lib/systemd/system/avahi-daemon.socket.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "bluetooth.service")
Created symlink /etc/systemd/system/dbus-org.bluez.service -> /usr/lib/systemd/system/bluetooth.service.
Created symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service -> /usr/lib/systemd/system/bluetooth.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "cronie.service")
Created symlink /etc/systemd/system/multi-user.target.wants/cronie.service -> /usr/lib/systemd/system/cronie.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "ModemManager.service")
Created symlink /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service -> /usr/lib/systemd/system/ModemManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/ModemManager.service -> /usr/lib/systemd/system/ModemManager.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "NetworkManager.service")
Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service -> /usr/lib/systemd/system/NetworkManager.service.
Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service -> /usr/lib/systemd/system/NetworkManager-dispatcher.service.
Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service -> /usr/lib/systemd/system/NetworkManager-wait-online.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "cups.service")
Created symlink /etc/systemd/system/printer.target.wants/cups.service -> /usr/lib/systemd/system/cups.service.
Created symlink /etc/systemd/system/sockets.target.wants/cups.socket -> /usr/lib/systemd/system/cups.socket.
Created symlink /etc/systemd/system/multi-user.target.wants/cups.path -> /usr/lib/systemd/system/cups.path.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "tlp.service")
Created symlink /etc/systemd/system/multi-user.target.wants/tlp.service -> /usr/lib/systemd/system/tlp.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "haveged.service")
.. Target cmd: ("systemctl", "enable", "haveged.service") Exit code: 1 output:
Failed to enable unit, unit haveged.service does not exist.
16:41:09 [2]: void CalamaresPython::warning(const string&)
WARNING: [PYTHON JOB]: "Cannot enable systemd .service haveged"
WARNING: [PYTHON JOB]: "systemctl enable call in chroot returned error code 1"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "apparmor.service")
Created symlink /etc/systemd/system/multi-user.target.wants/apparmor.service -> /usr/lib/systemd/system/apparmor.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "snapd.apparmor.service")
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.apparmor.service -> /usr/lib/systemd/system/snapd.apparmor.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "snapd.service")
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.service -> /usr/lib/systemd/system/snapd.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "fstrim.timer.service")
.. Target cmd: ("systemctl", "enable", "fstrim.timer.service") Exit code: 1 output:
Failed to enable unit, unit fstrim.timer.service does not exist.
WARNING: [PYTHON JOB]: "Cannot enable systemd .service fstrim.timer"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "pkgfile-update.timer.service")
.. Target cmd: ("systemctl", "enable", "pkgfile-update.timer.service") Exit code: 1 output:
Failed to enable unit, unit pkgfile-update.timer.service does not exist.
WARNING: [PYTHON JOB]: "Cannot enable systemd .service pkgfile-update.timer"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "sddm.service")
Created symlink /etc/systemd/system/display-manager.service -> /usr/lib/systemd/system/sddm.service.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "enable", "graphical.target")
The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
Alias= settings in the [Install] section, and DefaultInstance= for template
units). This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
* A unit may be statically enabled by being symlinked from another unit's
.wants/ or .requires/ directory.
* A unit's purpose may be to act as a helper for some other unit which has
a requirement dependency on it.
* A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, ...).
* In case of template units, the unit is meant to be enabled with some
instance name specified.
Running "chroot" ("/tmp/calamares-root-uet5jqou", "systemctl", "disable", "pacman-init.service")
Starting job "grubcfg" ( 39 / 42 )
Job file "/usr/lib/calamares/modules/grubcfg/main.py"
.. Job description from pretty_name "grubcfg" = "Configure GRUB."
Running "chroot" ("/tmp/calamares-root-uet5jqou", "sh", "-c", "which dracut")
.. Target cmd: ("sh", "-c", "which dracut") Exit code: 1 output:
which: no dracut in (/home/manjaro/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin)
Starting job "bootloader" ( 40 / 42 )
Job file "/usr/lib/calamares/modules/bootloader/main.py"
.. Job description from pretty_name "bootloader" = "Install bootloader."
[PYTHON JOB]: "Bootloader: grub (efi)"
Running "chroot" ("/tmp/calamares-root-uet5jqou", "grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force")
Installing for x86_64-efi platform.
Installation finished. No error reported.
[PYTHON JOB]: "UEFI Fallback: True"
[PYTHON JOB]: " .. installing 'bootx64.efi' fallback firmware"
16:41:11 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "grub-mkconfig", "-o", "/boot/grub/grub.cfg")
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
It's output will be used to detect bootable binaries on them and create new boot entries.
done
16:41:15 [6]: virtual void Calamares::JobThread::run()
Starting job "postcfg" ( 41 / 42 )
16:41:15 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/postcfg/main.py"
.. Job description from __doc__ "postcfg" = "Misc postinstall configurations"
16:41:15 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "pacman-key", "--init")
Running "chroot" ("/tmp/calamares-root-uet5jqou", "pacman-key", "--populate", "archlinux", "manjaro")
==> Appending keys from archlinux.gpg...
==> Appending keys from manjaro.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
-> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
-> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
-> Locally signing key 688E8F82879D0E25CE541426150C200743ED46D8...
-> Locally signing key 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90...
-> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
-> Locally signing key 76C6E477042BFE985CC220BD9C08A255442FAFF0...
-> Locally signing key DDB867B92AA789C165EEFA799B729B06A680C281...
-> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
-> Locally signing key 2D14560CDCE6A75BB186DB758238651DDF5E0594...
-> Locally signing key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
-> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
-> Locally signing key 7A443CEE69B6B3777740E258084A7FC0035B1D49...
-> Locally signing key 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA...
-> Locally signing key 0037505D6C3F595C37F5626AFD847358FF20E35C...
-> Locally signing key D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C...
-> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
-> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
-> Locally signing key F66AD0FF0E57C561615A0901CEE477135C5872B0...
-> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
-> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
-> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
-> Locally signing key 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5...
-> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
-> Locally signing key 3B794DE6D4320FCE594F4171279E7CF5D8D56EC8...
-> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
==> Importing owner trust values...
==> Disabling revoked keys in keyring...
-> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
-> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
-> Disabling key 684148BB25B49E986A4944C55184252D824B18E8...
-> Disabling key 5357F3B111688D88C1D88119FCF2CB179205AC90...
-> Disabling key 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F...
-> Disabling key 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
-> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
-> Disabling key 40440DC037C05620984379A6761FAD69BA06C6A9...
-> Disabling key FB871F0131FEA4FB5A9192B4C8880A6406361833...
-> Disabling key 487EACC08557AD082088DABA1EB2638FF56C0C53...
-> Disabling key 76B4192E902C0A52642C63C273B8ED52F1D357C1...
-> Disabling key 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
-> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
-> Disabling key 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
-> Disabling key 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
-> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD...
-> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
-> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887...
-> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
-> Disabling key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
-> Disabling key 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
-> Disabling key 5A2257D19FF7E1E0E415968CE62F853100F0D0F0...
-> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
-> Disabling key 5E7585ADFF106BFFBBA319DC654B877A0864983E...
-> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
-> Disabling key 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48...
-> Disabling key BFA1ECFEF1524EE4099CDE971F0CD4921ECAA030...
-> Disabling key 4D913AECD81726D9A6C74F0ADA6426DD215B37AD...
-> Disabling key 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
-> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
-> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
-> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
-> Disabling key 779CD2942629B7FA04AB8F172E89012331361F01...
-> Disabling key D921CABED130A5690EF1896E81AF739EC0711BF1...
-> Disabling key 5696C003B0854206450C8E5BE613C09CB4440678...
-> Disabling key 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
-> Disabling key 1A60DC44245D06FEF90623D6EEEEE2EEEE2EEEEE...
-> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
-> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
-> Disabling key 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A...
-> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
==> Updating trust database...
gpg: next trustdb check due at 2021-08-02
16:41:17 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "pacman-mirrors", "-f3")
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
1.789 Brazil : https://manjaro.c3sl.ufpr.br/
2.363 Russia : https://mirror.truenetwork.ru/manjaro/
1.161 Russia : http://mirror.truenetwork.ru/manjaro/
2.028 Brazil : https://www.caco.ic.unicamp.br/manjaro/
::INFO Writing mirror list
::Russia : https://mirror.truenetwork.ru/manjaro/stable
::Brazil : https://manjaro.c3sl.ufpr.br/stable
::Brazil : https://www.caco.ic.unicamp.br/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
16:41:31 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "pacman", "-Syy")
downloading core.db...
downloading extra.db...
downloading community.db...
downloading multilib.db...
16:41:53 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "pacman", "-R", "--noconfirm", "intel-ucode")
checking dependencies...
Packages (1) intel-ucode-20210216-1
Total Removed Size: 3.46 MiB
:: Do you want to remove these packages? [Y/n]
removing intel-ucode...
(1/1) Arming ConditionNeedsUpdate...
Running "chroot" ("/tmp/calamares-root-uet5jqou", "killall", "-9", "gpg-agent")
Running "chroot" ("/tmp/calamares-root-uet5jqou", "update-grub")
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
done
16:41:56 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
Running "chroot" ("/tmp/calamares-root-uet5jqou", "grub-editenv", "-", "set", "menu_auto_hide=1", "boot_success=1")
16:41:56 [2]: void CalamaresPython::warning(const string&)
WARNING: [PYTHON JOB]: "no office suite selected, None"
16:41:56 [6]: virtual void Calamares::JobThread::run()
Starting job "umount" ( 42 / 42 )
16:41:56 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/umount/main.py"
16:41:56 [6]: boost::python::api::object CalamaresPython::gettext_path()
.. Job description from pretty_name "umount" = "Unmount file systems."
Shutting down Calamares...
.. Finished shutdown.
[manjaro@manjaro ~]$ ls /var/log/
audit cups journal manjaro-live.log old private wtmp
btmp gssproxy lastlog mhwd-live.log pacman.log samba Xorg.0.log
[manjaro@manjaro ~]$ sudo ls /var/log/
audit btmp cups gssproxy journal lastlog manjaro-live.log mhwd-live.log old pacman.log private samba wtmp Xorg.0.log
[manjaro@manjaro ~]$ sudo ls /var/log/ -a
. .. audit btmp cups gssproxy journal lastlog manjaro-live.log mhwd-live.log old pacman.log private samba wtmp Xorg.0.log
[manjaro@manjaro ~]$ ls /var/log/ -a
[manjaro@manjaro ~]$ ls /var/log/lastlog
.bash_logout .bashrc .config/ .dir_colors Downloads/ .face.icon .kde4/ Music/ Public/ Templates/ .Xauthority .xinitrc
.bash_profile .cache/ Desktop/ Documents/ .face .gtkrc-2.0 .local/ Pictures/ .screenrc Videos/ .Xclients .zshrc
/var/log/lastlog
[manjaro@manjaro ~]$ cat /var/log/lastlog
[manjaro@manjaro ~]$ cat /var/log/m
[manjaro@manjaro ~]$ cat /var/log/manjaro-live.log
Loaded /etc/manjaro-tools/live.conf: 0.003ms
Detected none none: 0.217ms
Got consolefont and arch x86_64: 0.080ms
Configured language: en_US
Configured keymap: us
Configured timezone: UTC
Finished localization: 2.291ms
Created user manjaro with password manjaro: 0.181ms
Configured sudoers: 0.023ms
Deleting existing machine-id ...
Setting machine-id ...
Configured machine-id: 0.044ms
Configured accountsservice: 0.019ms
Configured displaymanager: 0.114ms
Configured root user: 0.228ms
Configured samba: 0.003ms
cat: /var/log/: Is a directory
We don’t recommend to use BTRFS, as that might be broken with the installer shipped.
With calamares this doesn’t work. Internally the installer create 2 subvolumes on “/”.
- “@home” → “/home”
So when choosing btrfs you have to choose only 1 partition for all mount points and use subvolumes.
It will install it like this, but it will not boot. At least on previous testing session.
Sorry for the delay! I finally got it sorted, I redownloaded the ISO and it works now (also threw in a new hard drive because I think my old one was failing >.>).
Uh… How would I go about creating it after the install?
–edit–
Tried to see if I can do it from live usb but Manjaro Architect is completely missing now… so I can’t install it that way, what do I do now?
Welp… I tried to install with one partition and now the entire thing is dead again, it’s not even showing up in my motherboard’s bios. Idk what to do now
On UEFI (gpt):
- /dev/sda1 → efi partition (fat32 + boot flag)
- /dev/sda2 → btrfs on /
- /dev/sda3 → swap (if needed)
On BIOS (ms-dos):
- /dev/sda1 → ext2 on /boot (bios_boot flag) (maybe not needed, better for compatibility)
On BIOS (gpt):
- /dev/sda1 → grub_bios
- /dev/sda2 → ext2 on /boot (bios_boot flag)(maybe not needed, better for compatibility)
- /dev/sda3 → btrfs on /
- /dev/sda4 → swap (if needed)
Thats all. The subvolumes “@” and “@home” are created automatically.
Also if previously installed with btrfs wipe the signatures first:
wipefs -a /dev/sda
Any reason you’re trying to install as soon as possible your school computer with an unknown custom partitioning scheme that you require people’s help for? I mean if you need it quick, do a normal installation. It’s OK to learn but that doesn’t seem logical right here right now.
I wanted to try btrfs because I heard it’s better optimized for backups. But what’s more troubling is it’s like if the iso doesn’t even install the bootloader, as the boot partition doesn’t even appear in my bios at all… which makes me think it’s the ISO and not the file system.
this?
The oddest thing is, it actually booted when I had the file system on different partitions (one for root, and one for home). But it still doesn’t make sense why that would prevent the installer from even installing the bootloader
Alright… it doesn’t even boot with ext4, same issue with not showing up in my computer’s bios
Strange… Please share your partition table and efi boot entries:
sudo parted -l
efibootmgr -v
Man, idk what’s happening… I flashed with etcher and it finally booted. Maybe my ventoy installer is somehow corrupt??
When did you update ventoy on the flash drive last time?
I just updated it earlier today to v1.0.38
