It is seen that there is update for org.kde.plasma but even after clicking apply update it does not happen.
Reason: These packages might have ask for update if you have flatpak repo . Since you don’t have flatpak installed in your system the update will not happen .
Solution:
Install flatpak first.
sudo pacman -S flatpak
Then run update
flatpak update
The update will fetch latest version of org.kde.platform package.
Bingo!!! your issue is resolved now
… or:
you remove flatpak support entirely - if you don’t have or use any flatpaks in the first place …
(who runs plasma as a flatpak?)
Which would only happen if you didn’t cleanup your first flatpak experiment.
You think you did - but no you didn’t…
Your problem originates
- activating flatpak
- installed an application
- decide to remove flatpak but forget to cleanup
This will leave lingering software - always remove all flatpak resources before removing flatpak support.
[root tip] [How To] Removing a flatpak app
TL:DR
flatpak list
flatpak remove <pkgname>
flatpak remove --unused
sudo flatpak repair
