Orange pi 3 lts minimal dev does not install
the last several versions of the minimal build do not install. Does not even get to command prompt, goes into a reboot. the reboot takes about 15 minutes with various services not shutting down correctly. if i press esc to see the detailed status. the last minimal dev build that would install was from april or may, but networking did not function
xfce version installs fine, networking, hdmi and sound work, i assume the other desktop versions work
