slira
30 August 2025 17:56
1
Following the advise during an update I installed the 6.16.4-2 kernel.
It’s the one running now.
The Oracle VM does not start; it was working fine with the 6.15.11…
I already checked and the modules for the 6.16 are there.
Any idea how to solve? thanks
Teo
30 August 2025 17:59
2
Try 6.12 LTS, or 6.17rc if you like living on the edge?
philm
30 August 2025 18:34
3
Why not keep using 6.15.11. It might be still in our repos for couple of weeks …
slira
30 August 2025 19:17
4
Yeap, the 6.12 LTS is still here, just in case…
slira
30 August 2025 19:23
5
Sorry!
The issue is NOT with the kernel, it’s with the Oracle VM.
If anyone faces the same issue, see here: #22193 (segfault on arch linux due to missing libdl.so => fixed in SVN) – Oracle VirtualBox
I solved my situation in a much easier way: using VirtualBoxVM --startvm “name of the vm” in my terminal starts my only vm machine directly with no problems.
Thanks.
system
Closed
2 September 2025 19:23
6
