Optimus UI - prime-select is missing
Hello everybody,
I successfully installed nvidia drivers on my Manjaro, but when I tried to open Green with Envy, it says:
NV-CONTROL X extension not found
It was not possible to find the NVIDIA NV-CONTROL X extension on the current Display device.
Please make sure that the NVIDIA proprietary display drivers are installed and they support your current GPU
Well, then I installed Optimus + optimus GUI via Update Manager.
However, when I try to open Optimus UI, it says that prime-select is missing.
How do I install that?
I am very new to Manjaro, so I would appreciate step-by-step help.
Thanks in advance.
`System:
  Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=04bff2ce-8b24-430f-991b-0eb3dd7f7043 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Laptop System: Hewlett-Packard product: HP OMEN Pro 15
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 8104 v: 02.37 serial: <superuser required>
    part-nu: M2T41AA#UUW uuid: <superuser required> UEFI: Insyde v: F.23
    date: 03/23/2015
  ID-1: BAT0 charge: 33.2 Wh (92.0%) condition: 36.1/36.1 Wh (100.0%)
    power: 20.5 W volts: 15.6 min: 15.2 model: 13142 RR04058 type: Li-ion
    serial: <filter> status: discharging
  System RAM: total: 16 GiB available: 15.54 GiB used: 2.11 GiB (13.6%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Bottom - on board type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 16KTF1G64HZ-1G6E1 serial: N/A
  Device-2: Bottom - on board type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i7-4720HQ bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2600 min/max: 800/2600 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2600 2: 2600 3: 2600 4: 2600 5: 2600 6: 2600
    7: 2600 8: 2600 bogomips: 41521
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 4th Gen Core Processor Integrated Graphics
    vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-7.5
    process: Intel 22nm built: 2013 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0416
    class-ID: 0300
  Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Hewlett-Packard
    driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
    status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:0ff6 class-ID: 0302
  Device-3: Suyin HP TrueVision Full HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 064e:9314
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x11ed built: 2014 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.322 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 2
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.4.309 layers: 1 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4600 (HSW GT2) driver: N/A device-ID: 8086:0416
    surfaces: xcb,xlib
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:08b1 class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 8087:07dc
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 52.99 GiB (11.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZHPU512HCGL-000H1
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2H1Q scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 52.99 GiB (11.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 04bff2ce-8b24-430f-991b-0eb3dd7f7043
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 33BD-EC66
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 1-3:2 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
  Device-2: 1-4:3 info: Suyin HP TrueVision Full HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 064e:9314 class-ID: 0e02
    serial: <filter>
  Device-3: 1-13:4 info: Elan Micro Touchscreen type: HID
    driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
    chip-ID: 04f3:2016 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 36.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 6400 fan-2: 256
  Packages: 1304 pm: pacman pkgs: 1288 libs: 358 tools: pamac,yay pm: flatpak
    pkgs: 16
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    3: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    4: https://mirrors2.manjaro.org/stable/$repo/$arch
    5: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    6: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    7: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    8: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    9: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    10: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    11: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    12: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    13: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    14: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    15: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    16: https://mirror.23m.com/manjaro/stable/$repo/$arch
    17: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    18: https://mirror.init7.net/manjaro/stable/$repo/$arch
    19: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    20: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    21: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    22: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    23: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    24: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://manjaro.ynh.ovh/stable/$repo/$arch
    26: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    27: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    29: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    30: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    31: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    32: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    33: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    34: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    35: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    36: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    37: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    38: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    39: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    40: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    41: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    42: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    43: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    44: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    45: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    46: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    47: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    48: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    49: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    50: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    51: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    52: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    53: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    54: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    55: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    57: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    58: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    60: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    64: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    65: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    66: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    67: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    68: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    69: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    70: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    71: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    72: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    74: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    75: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    76: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    79: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    80: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    81: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    82: http://manjaro.grena.ge/stable/$repo/$arch
    83: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    84: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    85: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    86: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    87: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    88: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    89: http://manjaro.mirror.ac.za/stable/$repo/$arch
    90: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    91: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    92: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    93: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    94: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    95: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    96: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    97: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    98: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    99: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    100: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    101: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    102: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    103: https://linorg.usp.br/manjaro/stable/$repo/$arch
    104: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    105: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    106: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    107: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    108: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    109: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    110: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    111: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    112: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    113: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    114: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    115: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    116: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    117: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    118: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    119: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    120: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    121: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 247
  1: cpu: 7.1% command: opera pid: 1260 mem: 444.7 MiB (2.7%)
  2: cpu: 6.5% command: opera pid: 1700 mem: 302.3 MiB (1.8%)
  3: cpu: 6.0% command: opera pid: 1320 mem: 162.5 MiB (1.0%)
  4: cpu: 5.1% command: opera pid: 1528 mem: 315.2 MiB (1.9%)
  5: cpu: 4.2% command: konsole pid: 1943 mem: 156.6 MiB (0.9%)
  Memory top: 5 of 247
  1: mem: 444.7 MiB (2.7%) command: opera pid: 1260 cpu: 7.1%
  2: mem: 315.2 MiB (1.9%) command: opera pid: 1528 cpu: 5.1%
  3: mem: 302.3 MiB (1.8%) command: opera pid: 1700 cpu: 6.5%
  4: mem: 294.4 MiB (1.8%) command: plasmashell pid: 897 cpu: 1.2%
  5: mem: 268.2 MiB (1.6%) command: opera pid: 1500 cpu: 3.4%
  Processes: 247 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,upowerd
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Mod edit:- Please do not post photos/screenshots when a brief text description will easily describe the problem. Images removed.
Hi :wave:,
Well then, “step by step help” is something you might expect from Support services that you pay for. The Manjaro forum is mainly a community of volunteers dedicating some of their time to help fellow members.
Did I mention, these volunteers are not paid? They are not. Please keep this in mind before dictating how help should be provided.
Textual information should always provided as text rather than an image of text, which will allow it to be found in search results. Images do not allow this, and frequently create undesired server load.
Please post the exact error message (as text).
:point_right: Oh, look – a kind Moderator has done this for you.
Using *-fetch type applications may provide sufficient information for someone wishing to buy your computer, but for Support purposes it’s best to ask your system directly.
Please provide system information as described (below).
See the links provided (also below) to learn how to post code or command output as preformatted text in accordance with forum guidelines.
Learn the differences between posting as preformatted text or as a quote, and when each should be used; again, see the links below, particularly those marked with :eyes:.
Examples;
this becomes a scrollable preformatted text box
Note: The ` key can be found under Esc on a typical full keyboard; on laptop keyboards it may be located elsewhere. :man_shrugging:
[quote]
[/quote]
We all make typos sooner or later. Please make sure to correct them before you post; this demonstrates a certain respect for other members.
Regarding your issue;
I’m sure someone will offer to help when they are able.
In the meantime, have you searched the forum? There are many topics that might be helpful.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
Hey,
I updated the info, as per your request.
Of course, I tried to find a solution before I posted. Since I haven´t, I created this topic.
I am not dictating anything, I was simply stating the fact.
Nothing then?
Nobody knows how to solve this?
Hi,
I’m not using prime, but the inxi showed, that there is no driver for your nvidia loaded.
So check in System -> Manjaro Settings Manager -> Hardware Configuration, and install the properitary nvidia driver (video-nvidia) if not already done.
You did?
I did not see it.
… solve what?
Hi,
I tried to install before the proprietary driver (had to tty2 into Manjaro to do that), but once I done it, I had a black screen and base on the info I found on these forums, that means I had a wrong driver (although there is only one legacy driver for me to pick from).
So I had to reverse it back.
Now I tried also pressing “install the open source driver” - after it finishes it says “done” but after the PC restart, when I open System -> Manjaro Settings Manager -> Hardware Configuration , again, there is no change - it does not appear installed.
I would love to send you link to the screenshot, but it does not allow me.
You did?
I did not see it.
Yes, in the first post.
… solve what?
Answer to that is also in the first post.
good luck with these curt answers then - it’s only been going for nearly three weeks as of now
Thank you for updating your system information.
Perhaps nobody has step-by-step instructions.
As I do not personally use Nvidia, I can only suggest you look again;
You can post a screenshot elsewhere and link to it.
As you cannot (yet) create a live link, you can instead paste the full url in this format:
```https://forum.manjaro.org```
which will allow others to copy/paste the url if they wish.
I have changed the topic title.
The more concise title may help to attract some positive response from the Community.
Remember also that the forum is frequented mostly by volunteers who might only login whenever they personally have a problem which they cannot fix.
As you state
You should NOT jump into AUR and NOT while using stable branch (default).
→ [Need-To-Know] About Manjaro and AUR
No driver for Nvidia is active - but the output suggests that your card is supported by the 470.xx driver series
The message you supplied provides a hint to what you need to do
Manjaro is largely a self-service Linux distribution. Response to any topic is provided by community members like yourself - so you cannot request hand holding and extensive guiding - but any community member may choose to and if that happens you should thank the member(s) involved :bowing_man:
→ Manjaro Hardware Detection - Manjaro
Manjaro Settings Manager GUI - provides a GUI to install drivers
→ Manjaro Settings Manager - Manjaro
The CLI utility mhwd can be used as well
Selecting the driver based on a database
sudo mhwd -a pci nonfree 0300
Specify the driver to install
sudo mhwd -i pci video-nvidia-470xx
@Gizm0
Further to this;
does not appear on the;
This is a strong indication that your Nvidia graphics are not supported by the current Nvidia 570 drivers.
You will likely have better success with the Nvidia 470 drivers, as mentioned.
Update:
Listed as Quadro K1100M your graphics seem only compatible with the Nvidia 390 drivers:
Some possibly useful links from the Manjaro Wiki:
A quote from Nvidia for consideration;
And this is achieved by following the command-line directions given by @linux-aarhus (above).
The card is not mentioned in the 470 driver, but in the list for the 390.
Indeed, listed as Quadro K1100M in the Nvidia 390 for Linux compatibility list. Post updated.
@linux-aarhus + @soundofthunder + @AlexBoldt - Thanks for help.
So before I tried to install 390xx drivers, I updated the kernel (just to be sure).
However, if I try to use:
sudo mhwd -a pci non-free 0300
It ends up with:
Error: invalid use of option: -a/--auto (I tried to play around with it, thinking it might be just a typo, looked at the manual for this, command seems to correct, yet it does return the error)
Similarly:
sudo mhwd -i pci video-nvidia-390xx
ends up with:
Error: config 'video-nvidia-390xx' conflicts with config(s): video-nvidia
Based on that I assume I should first uninstall the current drivers.
sudo mhwd -li
reveals I have these installed currently:
video-linux 2024.05.06
video-nvidia 2025.01.13
When I try
sudo mhwd -r pci video-nvidia
It will end with script failure:
:: removing linux612-nvidia breaks dependency 'NVIDIA-MODULE' required by optimus-manager-git
Error: pacman failed!
Error: script failed!
Am I trying to uninstall it in wrong way? Should I uninstall the optimus manager before trying to uninstall the current drivers?
Yes. After you have added the new drivers, you can then rebuild optimus-manager-git to recognise them.
I realise the the command (written from memory) had a spelling error, the correct is
That aside - you will need to remove the custom package.
Then remove the video nvidia drivers
sudo mhwd -r video-nvidia
Then install the correct driver
I am not sure you need the optimus package you built to begin with, as the package envycontrol is in the repo.
sudo pacman -Syu envycontrol
This highlights the importance of verifying any commands given in the forum before using them. Mistakes (typo’s) are easy to make, but it’s just as easy to check the Wiki page or the manual of whatever command you might use.
This is a good habit to adopt because - depending on the command being used - a simple mistake can potentially be devastating.
Most commands have a manual easily accessed with;
man <command-name-here>
The majority of these are also duplicated on the Arch site; though it’s sometimes easier to fire up your favourite browser and search for arch man <command>.
So now I could install the drivers, but I ended up with black screen after loading the OS - this has happened to me before I started this thread as well.
I uninstalled the
optimus-manager-git then restarted the PC.
Then I uninstalled the current driver:
Installed the supported one:
and restarted the PC.
I will try again to tty2 inside and install the bumblebee version, if possible.
How can I list latest available drivers for my graphic card?
Heureka!
I made a progress (successfully installed the correct drivers - bumblebee version - they now even show properly as installed in the System -> Manjaro Settings Manager -> Hardware Configuration), but that returned me full circle to my very first post:
When I try to open the GreenWithEnvy, it still says:
Reason Why I installed Optimus is because I found that as a solution to this problem somewhere on a forums here. So how can I properly install the NV-CONTROL X extension?
I will post how I installed the proper drivers - it might get useful to someone down the line, I had to put it together from various posts:
How to uninstall Nvidia drivers when you have a black screen after OS has been loaded:
1.) You need to TTY2 into the system while booting OS (just when the Manjaro logo will pop-up):
Ctrl+Alt+F2, - use the same command again if you end up on a black screen and nothing is happening
2.) use your credentials and log in
3.) once inside, see what you have installed:
sudo mhwd -li
4.) If you will try to uninstall it now, you will get error:
Error: config 'video-nvidia' is not installed!
To avoid that, try adding the ibt parameter:
sudo nano /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes, after a space, add this parameter:
ibt=off -Dont remove anything from there!, just add it to existing parameters, save the file (Ctrl+O, then Ctrl+X to exit nano), update grub:
sudo update-grub
reboot
5.) Now you should be able to uninstall the driver:
sudo mhwd --remove pci [video driver name]
6.) install the proper nvidia drivers, then reboot:
sudo mhwd -i pci [video driver name]
in my case:
sudo mhwd -i pci video-hybrid-intel-nvidia-390xx-bumblebee
7.) Reverse changes from step 4
