Hi!
I had a working system where the switching between the iGPU and dGPU worked well.
Unfortunately I had to reinstall my system and the switching wont work.
Here is some info about my system:
$ lspci | grep -E "VGA|3D"
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 05)
01:00.0 3D controller: NVIDIA Corporation TU117M (rev a1)
$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
$ inxi -G
Graphics: Device-1: Intel UHD Graphics driver: i915 v: kernel
Device-2: NVIDIA TU117M driver: N/A
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting resolution: 1920x1200~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.2
How should fix it?
pobrn
22 April 2021 17:04
2
What’s the output of lspci -d 10de: -nn -k and sudo dmesg | grep -i nvidia?
$ lspci -d 10de: -nn -k
01:00.0 3D controller [0302]: NVIDIA Corporation TU117M [10de:1f99] (rev ff)
Kernel modules: nouveau, nvidia_drm, nvidia
$ dmesg | grep -i nvidia
dmesg: read kernel buffer failed: Operation not permitted
pobrn
22 April 2021 17:13
4
Please run it with sudo as it was in my comment.
With sudo the output is nothing.
Now the X wont start. I must to send the startx command to get the X environment.
pobrn
22 April 2021 17:40
6
If a command outputs nothing, that’s also valuable information, so please post “nothing” in that case. Please run nvidia-modprobe, then sudo dmesg | grep -i nvidia again, and post the output.
nvidia-modprobe also gives nothing (with sudo).
pobrn
22 April 2021 18:08
8
Did you run sudo dmesg | grep -i nvidia after that? What was its output?
nvidia-modprobe and sudo dmesg | grep -i nvidia both of them gives nothing.
pobrn
22 April 2021 18:25
10
Okay, now what’s the output of lspci -d 10de: -nn -k?
Anybody with advise that could make progress?
pobrn
26 April 2021 10:19
13
What’s the output of echo "0000:01:00.0" | sudo tee /sys/bus/pci/drivers/nvidia/bind?
I can answer at the evening.
tee: /sys/bus/pci/drivers/nvidia/bind: No such file or directory
0000:01:00.0
pobrn
26 April 2021 16:57
16
What’s the output of sudo modprobe nvidia && lsmod | grep nvidia?
pobrn
26 April 2021 17:00
18
Now what’s the output of the above?
0000:01:00.0
tee: /sys/bus/pci/drivers/nvidia/bind: No such device
Do i need to do a fresh install?
