Systemctl status optimus-manager
● optimus-manager.service - Optimus Manager Commands Daemon
Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2020-09-28 15:58:43 EDT; 21min ago
Main PID: 971 (python3)
Tasks: 1 (limit: 9227)
Memory: 32.0M
CGroup: /system.slice/optimus-manager.service
└─971 /usr/bin/python3 -u -m optimus_manager.daemon
Sep 28 15:58:43 xps7590 python3[971]: [1] INFO: Opening UNIX socket
Sep 28 15:58:43 xps7590 python3[971]: [1] INFO: Awaiting commands
Sep 28 16:01:45 xps7590 python3[971]: [182174] INFO: Received command : {
Sep 28 16:01:45 xps7590 python3[971]: “args”: {
Sep 28 16:01:45 xps7590 python3[971]: “mode”: “nvidia”
Sep 28 16:01:45 xps7590 python3[971]: },
Sep 28 16:01:45 xps7590 python3[971]: “type”: “switch”
Sep 28 16:01:45 xps7590 python3[971]: [182174] INFO: Writing requested GPU mode nvidia
Sep 28 16:01:45 xps7590 python3[971]: [182174] INFO: Writing state {‘type’: ‘pending_pre_xorg_start’, ‘requested_mode’: ‘nvidia’, ‘current_mode’: ‘intel’}
Im not getting any error messages.
optimus-manager --print-mode
A GPU switch from intel to nvidia is pending.
Log out and log back in to apply.
Current GPU mode : intel
When I log out and log back in nothing happens it just goes back to intel.
One thing to note, I cant modprobe nvidia but im not sure if I SHOULD be able.
inxi:
CPU: 6-Core Intel Core i7-9750H (-MT MCP-) speed/min/max: 2600/800/2600 MHz
Kernel: 5.8.6-1-MANJARO x86_64 Up: 43m Mem: 2820.0/7712.6 MiB (36.6%)
Storage: 476.94 GiB (51.1% used) Procs: 319 Shell: inxi: 3.1.05
Hi, inxi is not enough post at least inxi -SGazy
Also journalctl -b0 -u optimus-manager
use the </> button for the content
Usually it’s the DM which causes issues. Since you didn’t provide any useful info about your system, we can’t go into the details.
Generally, I can say that usually three things are possible here:
You didn’t configure your DM properly as shown in the guide
Your optimus-configuration isn’t correct
Your settings are not playing well with your hardware, you need to experiment with different switching methods and other settings till you get it right
Maybe a 4th thing would be a bad and conflicting driver installation. Or 5th - combination of all the above…
So for a beginning show us output of:
inxi -Fazy
and
mhwd - li
and the other outputs that others are asking here about.
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=8e73ea9e-8763-4fcd-a4dc-3fbb018ee61f rw intel_iommu=on iommu=pt
quiet
cryptdevice=UUID=eeed254b-2bd7-47bd-9a48-e26aebfb20f7:luks-eeed254b-2bd7-47bd-9a48-e26aebfb20f7
root=/dev/mapper/luks-eeed254b-2bd7-47bd-9a48-e26aebfb20f7
resume=/dev/mapper/luks-eeed254b-2bd7-47bd-9a48-e26aebfb20f7
scsi_mod.use_blk_mq=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11
dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.8.1
date: 07/03/2020
ID-1: BAT0 charge: 97.0 Wh condition: 97.0/97.0 Wh (100%) volts: 12.9/11.4
model: SMP DELL GPM0365 type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech G604 Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
L2 cache: 12.0 MiB
bogomips: 62431
Speed: 2535 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 2558 2: 2600
3: 2600 4: 2600 5: 2600 6: 1475 7: 2546 8: 2601 9: 2152 10: 2600 11: 2600
12: 2600
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 440.100
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-12:4 chip ID: 0c45:6d13
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: modesetting,nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1182x380mm (46.5x15.0")
s-diag: 1242mm (48.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: DP-1 res: 2560x1440 dpi: 93 size: 697x392mm (27.4x15.4")
diag: 800mm (31.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus ID: 3b:00.0 chip ID: 8086:2723
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: virbr1 state: down mac: <filter>
IF-ID-2: virbr1-nic state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 246.38 GiB (51.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-000L7
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 5L2QEXA7 scheme: GPT
ID-1: / raw size: 452.61 GiB size: 444.50 GiB (98.21%)
used: 244.77 GiB (55.1%) fs: ext4 dev: /dev/dm-0
ID-1: swap-1 type: partition size: 12.86 GiB used: 1.58 GiB (12.3%)
priority: -2 dev: /dev/dm-1
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 343 Uptime: 1d 57m Memory: 7.53 GiB used: 4.14 GiB (55.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 2190 lib: 530 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
video-hybrid-intel-nvidia-440xx-prime 2019.10.25 false PCI
Wow, you are over-installed. With Intel-Nvidia combo, you only need:
video-modesetting
and
or preferably newer one:
video-hybrid-intel-nvidia-450xx-prime
Rest should be uninstalled. They are probably creating some conflicts.
Back up your system, uninstall video-linux and video-vesa with mhwd -r.
See:
https://wiki.manjaro.org/index.php/Configure_Graphics_Cards
It is quite often that some drivers are a dependency of other installed package. If that is the case, mhwd will return error during uninstall attempt and will show you which package is blocking it. You need to uninstall this package first (if you need it, you can install it later again), then run uninstall by mhwd once again.
Holy crap, thats what it was.
I guess theres something to be said about using the same install across 4 laptops and almost 3 years lol.
system
Closed
3 October 2020 20:30
8
