do some clean up:
kde-servicemenus-rootactions
- this doesnt work, and its no longer supported, so remove it;
manjaro-documentation-en
manjaro-firmware
myki
these 3 packages are dead meat, they are no longer in official repos, nor are they in the aur, so you can remove them…
Done
Thanks for those.
I knew myki was no good no more.
I have replaced it with Bitwarden
[demo@manjaro Downloads]$ pamac remove kde-servicemenus-rootactions
Preparing...
Checking dependencies...
To remove (1):
kde-servicemenus-rootactions 2.9.1-2
Total removed size: 77.0 kB
Apply transaction ? [y/N] y
Removing kde-servicemenus-rootactions (2.9.1-2)... [1/1]
Arming ConditionNeedsUpdate... [1/2]
Refreshing PackageKit... [2/2]
[demo@manjaro Downloads]$ pamac remove manjaro-documentation-en
Preparing...
To remove (1):
manjaro-documentation-en 20181009-1
Total removed size: 10.0 MB
Removing manjaro-documentation-en (20181009-1)... [1/1]
Arming ConditionNeedsUpdate... [1/3]
Refreshing PackageKit... [2/3]
Updating the desktop file MIME type cache... [3/3]
[demo@manjaro Downloads]$ pamac remove manjaro-firmware
Preparing...
To remove (1):
manjaro-firmware 20160419-1
Total removed size: 2.6 MB
Removing manjaro-firmware (20160419-1)... [1/1]
[demo@manjaro Downloads]$ pamac remove myki
Preparing...
To remove (1):
myki 1.4.7-21
Total removed size: 287.0 MB
Removing myki (1.4.7-21)... [1/1]
Arming ConditionNeedsUpdate... [1/4]
Refreshing PackageKit... [2/4]
Updating icon theme caches... [3/4]
Updating the desktop file MIME type cache... [4/4]
good, so thats it
That was removed from the repos. if you have anything that needs it, that would be best to replace with electron12-bin
in the AUR. That way you don’t have to spend hours building it from source if there’s ever an update for it.
That was dropped from the repos long ago. Remove it and install dunst
instead if you need it.
That was dropped from the repos. Install balena-etcher
or etcher-bin
from the AUR instead.
Ok all that cleaned up.
[demo@manjaro Downloads]$ pamac remove electron12
Preparing...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing electron12 breaks dependency 'electron12' required by etcher
[demo@manjaro Downloads]$ pamac remove etcher
Preparing...
To remove (1):
etcher 1.7.9-1
Total removed size: 34.9 MB
Removing etcher (1.7.9-1)... [1/1]
Preparing...
To remove (1):
electron12 12.2.3-4
Total removed size: 171.3 MB
Removing electron12 (12.2.3-4)... [1/1]
[demo@manjaro Downloads]$ pamac remove dunstify
Preparing...
- removing dunstify breaks dependency 'dunstify' required by update-notifier
[demo@manjaro Downloads]$ pamac remove update-notifier
Preparing...
To remove (1):
update-notifier 0.7.8-1
Total removed size: 7.2 kB
Removing update-notifier (0.7.8-1)... [1/1]
Preparing...
To remove (1):
dunstify 1.7.3-1
Total removed size: 20.5 kB
Removing dunstify (1.7.3-1)... [1/1]
