so its in hybrid mode…
run it again:
sudo envycontrol -s nvidia
do you have the same error?
[demo@manjaro Downloads]$ sudo envycontrol -s nvidia
[sudo] password for demo:
Error: switching directly from integrated to Nvidia mode is not supported
Try switching to hybrid mode first!
so i have no idea whats wrong with it… im using envycontrol and have no issues…
so uninstall it:
pamac remove envycontrol
reboot and post output from:
find /etc/X11/ -name "*.conf"
to check for leftovers
[demo@manjaro Downloads]$ find /etc/X11/ -name "*.conf"
/etc/X11/mhwd.d/nvidia.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
output from:
cat /etc/X11/mhwd.d/nvidia.conf
[demo@manjaro Downloads]$ cat /etc/X11/mhwd.d/nvidia.conf
## Generated by mhwd - Manjaro Hardware Detection
looks ok, so you are running on kde?
yes sorry I didn’t say that earlier.
Here:
[demo@manjaro Downloads]$ inxi -Faaz
Kernel: 6.0.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet pci=nocrs
acpi=force "acpi_osi=Windows 2022" ibt=off
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.28 date: 07/14/2022
ID-1: BAT0 charge: 69.3 Wh (100.0%) condition: 69.3/69.3 Wh (100.0%)
volts: 13.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 178
Device-1: hid-0018:04F3:2992.0003-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2883 high: 3311 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3300 2: 2300 3: 3297
4: 3303 5: 958 6: 3298 7: 3311 8: 3300 bogomips: 36812
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 3b:00.0 chip-ID: 10de:1d13
class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: 3840x2160
hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 3840x2160
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.2.1
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Sound API: ALSA v: k6.0.6-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Local Storage: total: 931.51 GiB used: 258.21 GiB (27.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 39.9 C scheme: GPT
ID-1: / raw-size: 239 GiB size: 234.94 GiB (98.30%) used: 44.63 GiB (19.0%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 68.8 MiB
(71.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 415.57 GiB size: 407.98 GiB (98.17%) used: 213.51
GiB (52.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 48.0 C pch: 47.0 C mobo: N/A
Processes: 236 Uptime: 12m wakeups: 161 Memory: 15.26 GiB used: 3.88 GiB
(25.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1705 pm: pacman pkgs: 1699
libs: 487 tools: pamac,pikaur,yay pm: flatpak pkgs: 6 pm: snap pkgs: 0
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
thats ok, just wanted to be sure, so post output from:
cat /etc/sddm.conf
[demo@manjaro Downloads]$ cat /etc/sddm.conf
[General]
InputMethod=
Numlock=none
[Theme]
CursorTheme=breeze_cursors
DisableAvatarsThreshold=7
EnableAvatars=true
FacesDir=/usr/share/sddm/faces
ThemeDir=/usr/share/sddm/themes
[Users]
DefaultPath=/usr/local/sbin:/usr/local/bin:/usr/bin
HideShells=
HideUsers=
RememberLastSession=true
RememberLastUser=true
ReuseSession=false
[Wayland]
EnableHiDPI=false
SessionCommand=/usr/share/sddm/scripts/wayland-session
SessionDir=/usr/share/wayland-sessions
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
#DisplayCommand=/usr/share/sddm/scripts/Xsetup
#DisplayStopCommand=/usr/share/sddm/scripts/Xstop
EnableHiDPI=false
MinimumVT=1
ServerArguments=-nolisten tcp
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
SessionDir=/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
UserAuthFile=.Xauthority
XauthPath=/usr/bin/xauth
XephyrPath=/usr/bin/Xephyr
so lets try again with optimus:
pamac install optimus-manager optimus-manager-plasma
reboot
switch to nvidia via optimus tray icon, and check if it worked with:
nvidia-smi
I think we have success:
demo@manjaro Downloads]$ nvidia-smi
Sun Oct 30 15:04:13 2022
| NVIDIA-SMI 520.56.06 Driver Version: 520.56.06 CUDA Version: 11.8 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:3B:00.0 Off | N/A |
| N/A 46C P0 N/A / N/A | 1115MiB / 2048MiB | 1% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 2021 G /usr/lib/Xorg 413MiB |
| 0 N/A N/A 2073 G /usr/bin/kwalletd5 1MiB |
| 0 N/A N/A 2129 G /usr/bin/ksmserver 1MiB |
| 0 N/A N/A 2131 G /usr/bin/kded5 1MiB |
| 0 N/A N/A 2132 G /usr/bin/kwin_x11 320MiB |
| 0 N/A N/A 2167 G /usr/bin/plasmashell 113MiB |
| 0 N/A N/A 2194 G ...de-authentication-agent-1 1MiB |
| 0 N/A N/A 2197 G ...ib/xdg-desktop-portal-kde 1MiB |
| 0 N/A N/A 2273 G /usr/lib/kdeconnectd 1MiB |
| 0 N/A N/A 2274 G /usr/bin/latte-dock 20MiB |
| 0 N/A N/A 2296 G /usr/bin/kaccess 1MiB |
| 0 N/A N/A 2313 G /usr/lib/DiscoverNotifier 1MiB |
| 0 N/A N/A 2316 G /usr/bin/pamac-tray-plasma 1MiB |
| 0 N/A N/A 2460 G /usr/lib/kf5/kioslave5 1MiB |
| 0 N/A N/A 2476 G /usr/bin/konsole 1MiB |
| 0 N/A N/A 2479 G /usr/lib/firefox/firefox 219MiB |
| 0 N/A N/A 2493 G /usr/bin/dolphin 1MiB |
| 0 N/A N/A 2538 G /usr/bin/optimus-manager-qt 1MiB |
| 0 N/A N/A 2643 G /usr/lib/kf5/kioslave5 1MiB |
it looks like it…
so do you want to make it permanent? so that you dont switch to nvidia every time you boot your pc…
open optimus settings via the tray, and locate the startup mode and switch it to nvidia, click ok;
then reboot, and see if you can boot normally with nvidia…
if you booted, check again with:
nvidia-smi
Ok made it permanent. Rebooted.
[demo@manjaro Downloads]$ nvidia-smi
Sun Oct 30 15:10:41 2022
| | | MIG M. |
| N/A 51C P0 N/A / N/A | 1131MiB / 2048MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 677 G /usr/lib/Xorg 437MiB |
| 0 N/A N/A 762 G /usr/bin/kwalletd5 1MiB |
| 0 N/A N/A 856 G /usr/bin/ksmserver 1MiB |
| 0 N/A N/A 858 G /usr/bin/kded5 1MiB |
| 0 N/A N/A 859 G /usr/bin/kwin_x11 321MiB |
| 0 N/A N/A 893 G /usr/bin/plasmashell 112MiB |
| 0 N/A N/A 922 G ...de-authentication-agent-1 1MiB |
| 0 N/A N/A 924 G ...ib/xdg-desktop-portal-kde 1MiB |
| 0 N/A N/A 1013 G /usr/lib/kdeconnectd 1MiB |
| 0 N/A N/A 1015 G /usr/bin/latte-dock 23MiB |
| 0 N/A N/A 1030 G /usr/bin/kaccess 1MiB |
| 0 N/A N/A 1032 G /usr/lib/DiscoverNotifier 1MiB |
| 0 N/A N/A 1044 G /usr/bin/pamac-tray-plasma 1MiB |
| 0 N/A N/A 1190 G /usr/lib/kf5/kioslave5 1MiB |
| 0 N/A N/A 1203 G /usr/bin/konsole 1MiB |
| 0 N/A N/A 1206 G /usr/lib/firefox/firefox 209MiB |
| 0 N/A N/A 1220 G /usr/bin/dolphin 1MiB |
| 0 N/A N/A 1260 G /usr/bin/optimus-manager-qt 1MiB |
| 0 N/A N/A 1350 G /usr/lib/kf5/kioslave5 1MiB |
So to summarize all of this.
I had multiple python issues which we think I might still have some.
After fixing those issues optimus was able to be installed and set and worked.
Sorry for all of that and I appreciate you sticking with me on this.
I am going to go back and look through all the steps we went through and see if there is anything else I want to check.
thats basically the summary…
and you are correct that more packages may be affected …
also you are running:
latte-dock
which is no longer supported, so it can cause issues down the road…
also you are having:
DiscoverNotifier
which is probably from the discover … why do you use discover… you have pamac and pacman for packages…
On latte-dock .
It was the preferred dock when I installed KDE.
I am using the latte-dock AUR package as it fixes some of the issues it has.
On Discover.
I have it and use it to reference items that need updated.
I believe it updates kde.org themes and such that pacman doesn’t update.
That is all I use it for.
ok, i see…
post also output from:
pamac list -qm
[demo@manjaro Downloads]$ pamac list -qm
anydesk-bin
asix-ax88179-dkms
aurutils
deadbeef
dunstify
electron12
etcher
hardinfo-gtk3
joplin-appimage
kde-servicemenus-rootactions
latte-dock-git
lightly-qt
manjaro-documentation-en
manjaro-firmware
myki
numix-circle-icon-theme-git
numix-icon-theme-git
ocs-url
pikaur
playonlinux
qt5ct-kde
thonny-git
ttf-ms-fonts
ulauncher
update-notifier
viber
xscreensaver-aerial
yay-git
zoom
Indeed. Someone had been installing /uninstalling Python packages with sudo pip
That someone was me.
I was following some instructions from people telling me to do that to run some python programs I was using to do some python programming with not knowing what damage it was going to cause.
I was listening to people that know more than I know so I thought they knew what they were doing.
I have learned since then but installed so much stuff and didn’t know all the packages I installed.
I wanted to play with the database programming and I am just beginning to learn python so I was ignorant on what packages to install.
