Optimus manager in Wayland
I have a laptop (amd cpu + nvidia discrete gpu) and an external 165Hz 1080P monitor. On xorg everything is fine but if I switch to wayland, the max refresh rate of my external display is limited to ~84 Hz. Optimus manager (also tries nv control, same result) is not working on wayland or I should say nvidia prime is not working properly on wayland. Is there any solution?
  Host: Ultron Kernel: MANJARO x86_64 bits: 64 compiler: gcc
    v: 11.1.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-x86_64
    root=UUID=ae8ac2cf-fbd1-473d-bfff-8e6b11a36512 rw rootflags=subvol=@
    quiet splash resume=UUID=7d46ec8f-c2ad-472b-b831-1e162c8d9316
    udev.log_priority=3
  Desktop: Plasma
  Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
  Mobo: HP model: 8786 v: 22.58 serial: <superuser required> UEFI: AMI
    v: F.13 date: 03/04/2021
  ID-1: BAT0 charge: 58.4 Wh (100.0%) condition: 58.4/58.4 Wh (100.0%)
    volts: 12.8 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: N/A status: Full cycles: 525
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600106
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1527 high: 2960 min/max: 1400/3000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
    3: 1397 4: 1397 5: 1396 6: 1397 7: 1397 8: 1397 9: 1397 10: 2960 11: 1397
    12: 1397 bogomips: 71895
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
  Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
    vendor: Hewlett-Packard driver: nvidia v:
    alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191
    class-ID: 0300
  Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
    bus-ID: 07:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-3: Luxvisions Innotech Limited HP Wide Vision HD Camera type: USB
    driver: uvcvideo bus-ID: 3-3:2 chip-ID: 30c9:000e class-ID: 0e02
  Display: x11 server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon failed: ati
    alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
  Device-1: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
    class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x,snd_pci_acp5x bus-ID: 07:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.45 running: no
    vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  IF: eno1 state: down mac: 30:24:a9:89:55:7a
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
    chip-ID: 8086:2723 class-ID: 0280
  IF: wlo1 state: up mac: 78:2b:46:4a:91:60
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 3-4:3 chip-ID: 8087:0029 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 1.38 TiB used: 15.42 GiB (1.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: 50026B768474B93C
    rev: S5Z42109 temp: 24.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
    model: MZVLB512HBJQ-000H1 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: S4GLNX0N998775
    rev: HPS0NEXF temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 460.08 GiB size: 460.08 GiB (100.00%)
    used: 15.42 GiB (3.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
    used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
  ID-3: /home raw-size: 460.08 GiB size: 460.08 GiB (100.00%)
  ID-4: /var/log raw-size: 460.08 GiB size: 460.08 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.56 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Processes: 347 Uptime: 24m wakeups: 1 Memory: 15.06 GiB
  used: 2.55 GiB (16.9%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: N/A Packages: pacman: 991 lib: 292 Shell: Zsh v: 5.8
  running-in:
Hi @Computer_Email23,
Honestly?
:man_shrugging:
Especially since you mentioned Nvidia and Wayland together.
All I can suggest is looking through the Arch wiki, maybe there’s something useful:
https://wiki.archlinux.org/title/Wayland
https://wiki.archlinux.org/title/NVIDIA#Wayland
This could be the cable quality and the connection type DP vs. HDMI vs. Thunderbolt
I have read somewhere about limitations - something with pixel bandwidth - don’t know any more than a user was advised - for Plasma - add to /etc/environment - for kwin it defaults to 30 but lowering the value made a change
KWIN_DRM_PREFER_COLOR_DEPTH=24
Source: https://lemmy.linuxuserspace.show/comment/342687
thanks for replying
in xorg i am getting 165Hz no problem
I have one laptop display and another external display. scaling on laptop display defaults to 125% and 100% on external display, while using plasma on wayland. So I want to use plasma with wayland because it supports different scaling on different displays.
The scaling has nothing to do with the refresh rate…
So try capping your refresh rate…
but that is not a real solution
I guess DSC is not working in wayland then. In order to get a high refresh rate it needs to sacrifice something. If croma subsampling (DSC) is not working, it will limit the refresh rate, to fit the available bandwidth.
It could be also true, that xorg uses a color subsampling of 4:2:0 and wayland uses 4:4:4.
I mean there is noticeable lag in ui of my external monitor. Is there anything like optimus manager in Wayland? With optimus manager when I select hybrid/nvidia graphics, everything becomes smooth but in xorg session. So I want something like optimus manager in Wayland.
Shouldnt be using opimus-manager on anything, wayland or not.
If you need some sort of switcher utility then use one of these…
(no idea about xorg vs wayland, optimus-manager is just buggy and hacky and gross)
Which one is it?
Remove all the optimus-manager junk.
Try prime.
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
prime-run glxgears
Then, if you need a switcher utility for some reason, add it, and see how it works then.
Using envycontrol now. Enabled nvidia mode. But still facing stuttering on external monitor. If I move the mouse in blank space it is very smooth but as soon as I hover the mouse on some text or some apps, it stutters. Used gnome , kde plasma, even tried fedora gnome.
I have envycontrol installed. Can you guide me on how to completely remove envycontrol & use Prime ?
Edit : I am clean installing Manjaro Gnome latest version now.
Edit 1 : Installed Manjaro, external screen is completely white, can only move mouse cursor, nothing else can be seen.
tried installing driver from manjaro settings manager but failed… It has made me autologin to xorg session, no Wayland.
Starting
> Using config 'video-hybrid-amd-nvidia-prime' for device: 0000:01:00.0 (0300:10de:2191) Display controller nVidia Corporation TU116M [GeForce GTX 1660 Ti Mobile]
> Using config 'video-hybrid-amd-nvidia-prime' for device: 0000:06:00.0 (0300:1002:1636) Display controller ATI Technologies Inc Renoir
> Installing video-hybrid-amd-nvidia-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
checking dependencies...
:: removing libxnvctrl-390xx breaks dependency 'libxnvctrl' required by nvidia-settings
Error: pacman failed!
Error: script failed!
Done ...
https://manjaristas.org/branch_compare?q=libxnvctrl
Looks like its missing from the repos for some reason… I’ll ping @Yochanan who is the maintainer.
What should I do now?
Just let me know if Nvidia hybrid laptop GPU in Wayland with external display is possible right now or not.
Somehow a dependency of nvidia-settings is missing … so right now you can either switch branches to Unstable or you must just wait I suppose.
I have moved to testing branch.
Isnt going to help you.
Its missing there too.
Thats why its either Unstable Branch or wait.
(Sorry I dont control the repos :wink:)
Going to Unstable … >>>>>
still giving this error… what to do?
sudo mhwd -a pci nonfree 0300
> Using config 'video-hybrid-amd-nvidia-prime' for device: 0000:07:00.0 (0300:1002:1636) Display controller ATI Technologies Inc Renoir
successfully installed video-hybrid-amd-nvidia-prime by removing libxnvctrl-390xx and nvidia-settings.
the stuttering still occurs, which I mentioned previously. Looks like for now this is the situation in wayland & amd-nvidia hybrid laptop with external screen.
If someone has the solution then please write it down here. It will be helpful.
