So I’ve recently reset my Windows Machine due to some new drives, however I’ve been trying to SSH into my Linux machine for FileZilla and other things, I have had this working prior to my reinstall on my Windows machine.
Since the update it is no longer working, I have checked both my UFW settings and my Router settings to make sure they’re all forwarded and what not. It just doesn’t seem to be working for some reason, I have the port opened and I’m putting the correct information into FileZilla and it’s not able to connect.
I have some game servers on the same machine and they’re allowing me to connect via the domain name and ports. I’m not 100% to do honestly. I’ve updated everything and I’m still at all loss.
Any help would be greatly appreciated, thanks in advance.
~Blood
Recently, OpenSSH disabled some older, insecure ciphers. See the announcement from the OpenSSH project. OpenSSH: Release Notes
If your Windows SSH Client requires older, less secure ciphers, you need to allow them in your SSH Server config. (It would be better to update your client)
It may be helpful to first try ssh directly. Then you can add -v , -vv, or -vvv If you read this log carefully, this does show where the problem may be.
