Installed OpenSnitch but its not running. I wondered if there are any other packages I need to install to get it up and working?
Any advice appreciated.
Hello there
According to them:
For ArchLinux/Manjaro users this worked:
installed was from AUR python-unicode-slugify-git
removed it and installed python-unicode-slugify
Tried installing as suggested and this popped up.
onflicting files:
Uninstall this then try again.
I have uninstalled. I’ll give it ago and let you know how it goes.
Hello! I’ve been having the same issue. I finally dug around their FAQ’s on this Page, FAQs · evilsocket/opensnitch Wiki · GitHub , and found that the reason the GUI would run, but nothing was happening was because the Daemon wasn’t running.
The solution was down a couple of topics, under Opensnitch not Running.
Status is Not Running
Be sure that the daemon is running: pgrep opensnitchd
If it’s not running, you may need to enable and start it:
$ sudo systemctl enable opensnitchd
$ sudo systemctl start opensnitchd.service
Those two commands did the trick!
worked for me and then you can check with:
sudo opensnitch-ui
