I just updated the system and among other small issues Openrgb seems to have lost control over a set of fans connected to one ARGB connector of the motherboard. I noticed it because before the update I was able to turn off all RGB lighting while now said fans stays on in what it seems their default rainbow lighting.
Openrgb also gives a warning popup
I gave it a try doing
sudo pacman -S sudo libi2c-dev
warning: sudo-1.9.17.p1-1 is up to date -- reinstalling
error: target not found: libi2c-dev
Then
sudo modprobe i2c-dev
sudo modprobe i2c-piix4
I restarted the system but those LEDs are still on.
Any suggestions?
