M3nos
13 May 2021 17:21
1
Greetings,
I attempted to install an xbox kinnect camera using cmake and git
The dependencies are:
cmake-3.20.2-1
libusb-1.0.24-2
Python 3.9.4
and I did a:
$ cd libfreenect
$ mkdir build
$ cd build
$ cmake ..
But when I try to load the camera using freenect-glview
I get:
Number of devices found: 0
When I run lsusb | grep Xbox
, I get:
Bus 001 Device 013: ID 045e:02b0 Microsoft Corp. Xbox NUI Motor
and:
cmake -L
gives me:
CMake Warning:
No source or binary directory provided. Both will be assumed to be the
same as the current working directory, but note that this warning will
become a fatal error in future CMake releases.
CMake Error: The source directory “/home/n0p3/libfreenect/build” does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
– Cache values
BUILD_AS3_SERVER:BOOL=OFF
BUILD_CPACK_DEB:BOOL=OFF
BUILD_CPACK_RPM:BOOL=OFF
BUILD_CPACK_TGZ:BOOL=OFF
BUILD_CPP:BOOL=ON
BUILD_CV:BOOL=OFF
BUILD_C_SYNC:BOOL=ON
BUILD_EXAMPLES:BOOL=ON
BUILD_FAKENECT:BOOL=ON
BUILD_OPENNI2_DRIVER:BOOL=OFF
BUILD_PYTHON:BOOL=OFF
BUILD_PYTHON2:BOOL=OFF
BUILD_PYTHON3:BOOL=OFF
BUILD_REDIST_PACKAGE:BOOL=ON
CMAKE_BUILD_TYPE:STRING=
CMAKE_INSTALL_PREFIX:PATH=/usr/local
LIBUSB_1_INCLUDE_DIR:PATH=/usr/local/include/libusb-1.0
LIBUSB_1_LIBRARY:FILEPATH=/usr/lib/libusb-1.0.
If anyone knows how to install it on manjaro it seems to not be happy. libusb is uptodate. My best guess is it is a path issue. Thank you for your time.
fatal error: libusb.h: No such file or directory
30 | #include <libusb.h>
Fabby
13 May 2021 23:24
2
I’m not familiar with the exact package you’re trying to build but if:
it just should work…
So, please, post an inxi --admin --verbosity=7 --filter --no-host --width
, as that would be the minimum required information we need to help you… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
M3nos
14 May 2021 01:37
3
inxi output
Kernel: 5.4.114-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID= rw quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, plank wm: xfwm4
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Apple product: MacBookPro11,4 v: 1.0 serial: <filter>
Chassis: type: 9 v: Mac-06F11 serial: <filter>
Mobo: Apple model: Mac-06F11 v: MacBookPro11,4 serial: <filter>
UEFI: Apple v: 199.0.0.0.0 date: 06/11/2020
ID-1: BAT0 charge: 83.4 Wh (96.1%) condition: 86.8/99.8 Wh (87.0%)
volts: 12.8 min: 11.4 model: DP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 365
RAM: total: 15.52 GiB used: 2.56 GiB (16.5%)
Info: Quad Core model: Intel Core i7-4770HQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 46 (70) stepping: 1 microcode: 1C cache:
L2: 6 MiB bogomips: 35128
Speed: 998 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 998 2: 998 3: 998
4: 998 5: 999 6: 998 7: 999 8: 999
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Crystal Well Integrated Graphics vendor: Apple driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0d26 class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x2880 s-dpi: 96 s-size: 1016x762mm (40.0x30.0")
s-diag: 1270mm (50")
OpenGL: renderer: Mesa DRI Intel Iris Pro Graphics P5200 (HSW GT3)
v: 4.5 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Crystal Well HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0d0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A bus-ID: 04:00.0
chip-ID: 14e4:1570 class-ID: 0480
Sound Server-1: ALSA v: k5.4.114-1-MANJARO running: yes
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 14e4:43ba
class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-2.3:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20u2u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB
driver: btusb,hid-generic,usbhid bus-ID: 1-8:3 chip-ID: 05ac:8290
class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 233.76 GiB used: 5.57 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: SA0Q scheme: GPT
ID-1: / raw-size: 233.46 GiB size: 228.74 GiB (97.98%) used: 5.57 GiB (2.4%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 27825e3f-109d-4613-9e80-79b25356e422
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: B250-361D
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Hub-2: 1-1:9 info: NEC HighSpeed Hub ports: 3 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0409:005a class-ID: 0900
Device-1: 1-1.2:10 info: Microsoft Xbox NUI Motor type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 045e:02b0 class-ID: 0000
Hub-3: 1-5:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-4: 1-5.4:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-5.4.2:7 info: Razer USA DeathAdder 2013 type: Mouse,HID,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1532:0037 class-ID: 0301
Device-2: 1-5.4.4:8 info: Razer USA DeathStalker Expert type: Keyboard,Mouse
power: 500mA chip-ID: 1532:0202 class-ID: 0300
Device-3: 1-5.5:6 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
Device-4: 1-8:3 info: Apple Bluetooth Host Controller
type: Keyboard,Mouse,Bluetooth driver: btusb,hid-generic,usbhid
interfaces: 6 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8290 class-ID: fe01
Device-5: 1-12:4 info: Apple Apple Internal Keyboard / Trackpad
type: HID,Keyboard,Mouse driver: apple,bcm5974,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 05ac:0274 class-ID: 0300
serial: <filter>
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-6: 2-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 2-2.3:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-7: 2-2.4:5 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 45.5 C mobo: N/A
Processes: 228 Uptime: 2h 55m wakeups: 396 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 928 lib: 265
Shell: Bash v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.04 ```
Also I ran
sudo pacman -U libfreenect-git-v0.6.2.r0.g4d6b941-1-x86_64.pkg.tar.zs
Fabby
14 May 2021 07:23
4
Ah, no driver loaded!
Have you tried 5.10 LTS, or if that doesn’t give you a driver neither, 5.12 stable yet?
If no driver loaded neither, you indeed need to follow these instructions and if you did, you made a typo:
cmake -L ..
the ..
will ensure you build the project one directory level up.
If you would have any errors go here to open issues, but everyone will assume you’re a developer that knows how to program C, C++ and Python.
M3nos
14 May 2021 13:22
5
Greetings,
Good to know I can try a different kernel. Spaced on that,
but saw that it actually should grep 3 devices total. 2 cameras,
and a motor. I will definitly go back and RTFM on cmake. I was
under the impression that using the makepkg as an alternate
installation method would work. I will try a scratch install again,
under a different kernel. I am pretty sure I hit all the correct
python packages.
