Hi
An issue has popped up after I added a second monitor to my setup.
Whenever I open up a terminal window my secondary monitor gets disabled, I’m able to re-enable the monitor in either Nvidia-settings or the display settings window of KDE. After I’ve enabled the monitor again I’m able to move the terminal window over to that monitor and use it as normal. However opening a second terminal window/tab will cause the monitor to become disabled again.
This only occurs with terminals for some reason, both new windows and new tabs (Konsole, xterm, Yakuake all cause it.)
Opening anything else seems to work fine and strangely the Yakuake drop down terminal starts on boot and doesn’t cause the issue, working fine on both screens until I open a second tab at which point the monitor disables.
inxi output:
$inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=0ae4e860-f8aa-497f-a41c-748c7b244a66 rw quiet
cryptdevice=UUID=25279589-3c9a-4269-87de-e5da00f6bb3a:luks-25279589-3c9a-4269-87de-e5da00f6bb3a
root=/dev/mapper/luks-25279589-3c9a-4269-87de-e5da00f6bb3a apparmor=1
security=apparmor
resume=/dev/mapper/luks-00d68909-87fe-4271-a7b3-970188b7fb42
udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 0908 date: 10/23/2015
RAM: total: 15.55 GiB used: 2.39 GiB (15.4%)
Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2 cache:
L2: 6 MiB bogomips: 28009
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b80
class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3839x1080 s-dpi: 80 s-size: 1219x343mm (48.0x13.5")
s-diag: 1266mm (49.9")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-5:5 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: f000 bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
v: kernel port: e000 bus-ID: 04:00.0 chip-ID: 168c:002b class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Message: No Bluetooth data was found.
Message: No LVM data was found.
Device-1: luks-00d68909-87fe-4271-a7b3-970188b7fb42 maj-min: 254:1
type: LUKS dm: dm-1 size: 15.62 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 15.63 GiB
Device-2: luks-25279589-3c9a-4269-87de-e5da00f6bb3a maj-min: 254:0
type: LUKS dm: dm-0 size: 207.65 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 207.65 GiB
Local Storage: total: 1.46 TiB used: 712.34 GiB (47.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra II 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 Series
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 6B0Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 model: SATA3 240GB SSD size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 0A0 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 500GB
rotation: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Seagate model: ST500DM002-1BC142
rotation: 7200 rpm serial: <filter> rev: JC4B scheme: MBR
ID-1: / raw-size: 207.65 GiB size: 203.39 GiB (97.95%)
used: 59.49 GiB (29.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-25279589-3c9a-4269-87de-e5da00f6bb3a label: N/A
uuid: 0ae4e860-f8aa-497f-a41c-748c7b244a66
used: 500 KiB (0.2%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: BBB1-3021
ID-3: /mnt/LinuxGaming raw-size: 205.86 GiB size: 201.63 GiB (97.95%)
used: 101.33 GiB (50.3%) fs: ext4 dev: /dev/sdd2 maj-min: 8:50
label: LinuxGaming uuid: b9795053-296f-4e66-a761-db250e13939a
ID-4: /mnt/LinuxStorage raw-size: 223.57 GiB size: 219.06 GiB (97.98%)
used: 107.43 GiB (49.0%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
label: LinuxStorage uuid: 4720777d-cc6b-4f64-b1e1-ff13f5791806
ID-5: /run/media/eli/Game Drive raw-size: 465.76 GiB
size: 465.76 GiB (100.00%) used: 444.09 GiB (95.3%) fs: ntfs dev: /dev/sde1
maj-min: 8:65 label: Game Drive uuid: 6EF8CF91F8CF55CD
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-00d68909-87fe-4271-a7b3-970188b7fb42 label: N/A
uuid: e24894e3-2c31-4f03-ae22-d592d21cf8de
ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 1CE1-C0A4
ID-2: /dev/sdb2 maj-min: 8:18 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb3 maj-min: 8:19 size: 111.01 GiB fs: ntfs label: N/A
uuid: 6A9AEA0F9AE9D799
ID-4: /dev/sdb4 maj-min: 8:20 size: 566 MiB fs: ntfs label: N/A
uuid: EAEAFA4CEAFA1513
ID-5: /dev/sdd1 maj-min: 8:49 size: 259.89 GiB fs: ntfs label: Game SSD
uuid: D8D8F046D8F02482
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-3:3 info: Corsair K30A Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1b1c:1b0a class-ID: 0300
Device-2: 1-4:4 info: Corsair CORSAIR IRONCLAW RGB Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b5d class-ID: 0300
serial: <filter>
Device-3: 1-5:5 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
Processes: 237 Uptime: 56m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: 1383 pacman: 1377 lib: 428 flatpak: 0
snap: 6 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
xrandr output with both monitors running fine:
$xrandr
Screen 0: minimum 8 x 8, current 3839 x 1080, maximum 32767 x 32767
DVI-D-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 74.97 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
HDMI-0 connected 1920x1080+1919+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
xrandr output after opening a terminal session (the second monitor no longer has resolution info or it’s alignment but is still connected) This matches the need to tick enable, re-apply a resolution and refresh rate before the second monitor will restart.
$xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
HDMI-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
journald output straight after opening a terminal window:
11/04/2021 15:28 systemd Started Konsole - Terminal.
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: RRNotify_CrtcChange
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 441
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Mode: 446
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Rotation: "Rotate_0"
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 0 0 1920 1080
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 442
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Mode: 0
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 0 0 0 0
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: RRNotify_OutputChange
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 476
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 0
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Connection: "Connected"
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Subpixel Order: 0
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: RRScreenChangeNotify
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Window: 39845893
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Root: 487
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Size ID: 0
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Size: 1920 1080
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: SizeMM: 602 342
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 476 update
m_connected: 0
m_crtc XRandRCrtc(0x55e13888a840)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Disconnected output 476 from CRTC 442
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 476 : connected = true , enabled = false
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
11/04/2021 15:28 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:121: TypeError: Cannot read property 'x' of null
11/04/2021 15:28 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:135: TypeError: Cannot read property 'y' of null
11/04/2021 15:28 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20956, resource id: 37748849, major code: 15 (QueryTree), minor code: 0
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Emitting configChanged()
11/04/2021 15:28 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
11/04/2021 15:28 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22248, resource id: 37748914, major code: 15 (QueryTree), minor code: 0
11/04/2021 15:28 systemsettings5 QQmlEngine::setContextForObject(): Object already has a QQmlContext
11/04/2021 15:28 systemsettings5 file:///usr/share/kpackage/kcms/kcm_kscreen/contents/ui/Panel.qml:138:13: Unable to assign [undefined] to int
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandR::setConfig
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Requested screen size is QSize(3839, 1080)
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Needed CRTCs: 2
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Actions to perform:
Primary Output: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Change Screen Size: true
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Old: QSize(1920, 1080)
Intermediate: QSize(3839, 1080)
New: QSize(3839, 1080)
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Disable outputs: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Change outputs: true
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: (445)
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Enable outputs: true
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: (476)
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: RRSetScreenSize
DPI: 79.9767
SizeMM: QSize(1219, 343)
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 445 ( "DVI-D-0" )
CRTC: 441
Pos: QPoint(0,0)
Mode: 446 KScreen::Mode(Id: "446" , Size: QSize(1920, 1080) @ 60 )
Rotation: KScreen::Output::None
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Result: 0
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 445 update
m_connected: 0
m_crtc XRandRCrtc(0x55e13888a660)
CRTC: 441
MODE: 446
Connection: 0
Primary: true
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: QMap((441, XRandRCrtc(0x55e13888a660))(442, XRandRCrtc(0x55e13888a840))(443, XRandRCrtc(0x55e138886e90))(444, XRandRCrtc(0x55e138887470)))
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Testing CRTC 441
Free: false
Mode: 446
Possible outputs: QVector(445, 476, 477, 478, 479, 480, 481, 482)
Connected outputs: QVector(445)
Geometry: QRect(0,0 1920x1080)
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Testing CRTC 442
Free: true
Mode: 0
Connected outputs: QVector()
Geometry: QRect(0,0 0x0)
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: RRSetCrtcConfig (enable output)
Output: 476 ( "HDMI-0" )
New CRTC: 442
Pos: QPoint(1919,0)
Mode: KScreen::Mode(Id: "446" , Size: QSize(1920, 1080) @ 60 ) Preferred: "446"
m_connected: 0
m_crtc QObject(0x0)
CRTC: 442
MODE: 446
Connection: 0
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Connected output 476 to CRTC 442
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandR::setConfig done!
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Size ID: 65535
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Size: 3839 1080
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: SizeMM: 1219 343
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Geometry: 1919 0 1920 1080
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 443
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: CRTC: 444
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 445
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 477
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Connection: "Disconnected"
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 478
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 479
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 480
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 481
11/04/2021 15:28 kscreen_backend_launcher kscreen.xcb.helper: Output: 482
m_connected: 0
CRTC: 442
MODE: 446
Connection: 0
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 476 : connected = true , enabled = true
m_connected: 0
CRTC: 442
MODE: 446
Connection: 0
Primary: false
11/04/2021 15:28 plasmashell trying to show an empty dialog
11/04/2021 15:28 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
m_connected: 0
CRTC: 441
MODE: 446
Connection: 0
Primary: true
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 445 : connected = true , enabled = true
m_connected: 0
CRTC: 442
MODE: 446
Connection: 0
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 477 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 477 : connected = false , enabled = false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 478 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 478 : connected = false , enabled = false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 479 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 479 : connected = false , enabled = false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 480 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 480 : connected = false , enabled = false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 481 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 481 : connected = false , enabled = false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: XRandROutput 482 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
11/04/2021 15:28 kscreen_backend_launcher kscreen.xrandr: Output 482 : connected = false , enabled = false
The journald kscreen output makes me think this is KDE related but I’m out of my depth in fixing this tbh, any help in how to fix or what to look for would be appreciated.
Thanks, Cornelius.
