dmax
April 12, 2021, 8:59pm
#1
Hi, I recently started my move from Windows to Linux and it’s been really smooth so far but the OpenGL drivers seem to have some issues, all my OpenGL games look like this, I know I can’t include links but I need to show what’s going on, as it’s purely visual and I don’t get an error or anything:
drive.google. com/file/d/1KxkH-8gJnv-o7JLxDPvcke3FNj5TclVp/view?usp=sharing
drive.google. com/file/d/1fn2PrWY3NM4slSnBv82FlT-cQ17eLJP2/view?usp=sharing
Models get this distortion which is sometimes a lot more dramatic and performance also seems to be affected when they’re on screen, I haven’t been able to find someone with the same issue, on Windows I don’t have this issue but I’d rather be able to play most of what I can here that performance is much more stable and as most of what I play are old games which need OpenGL.
Any idea of what’s happening? The Intel drivers are installed, so I’m not sure of what to do about this.
Welcome here
Well, the Intel drivers are built into the Kernel. Have you tried other Kernels to see if it still persists, in case it was just regression in your current kernel?
I have a laptop with a i7-7600U
(or i7-7660U
, don’t remember) and haven’t encountered this myself.
Also, can you please provide the output of inxi -Fza
? Please put ``` before and after your output so that it’s easier to read.
Also also, how are you running your games? WINE? .bin files? Steam (Native or Proton)? Lutris?
dmax
April 13, 2021, 12:12am
#3
Thank you for the welcome!
Yes, installed another Kernel just before responding, issue persists.
Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=e4543b9e-eb9a-4b0e-82b7-538d92cd3a78 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: Acer product: Aspire ES1-411 v: V1.01
serial: <filter>
Mobo: Acer model: EA42_BM v: Type2 - A01 Board Version serial: <filter>
UEFI-[Legacy]: Insyde v: 1.01 date: 07/29/2014
ID-1: BAT1 charge: 22.2 Wh (74.2%) condition: 29.9/37.0 Wh (80.7%)
volts: 15.4 min: 14.8 model: SANYO AL12A32 type: Li-ion serial: <filter>
status: Discharging
Info: Dual Core model: Intel Celeron N2840 bits: 64 type: MCP
arch: Silvermont family: 6 model-id: 37 (55) stepping: 8 microcode: 838
cache: L2: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8671
Speed: 504 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 504 2: 583
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0f31 class-ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 21.0.1
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:0f04 class-ID: 0403
Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 2000 bus-ID: 02:00.0
chip-ID: 168c:0036 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
bus-ID: 03:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f1 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 17.24 GiB (3.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw-size: 147.53 GiB size: 144.15 GiB (97.71%)
used: 17.24 GiB (12.0%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 162 Uptime: 6m wakeups: 1 Memory: 3.73 GiB
used: 1.28 GiB (34.2%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1102 pacman: 1097 lib: 303 flatpak: 0 snap: 5
Shell: Bash v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.03
Native Linux games both with and without Steam while Proton games do the same, that seems to make no difference.
