Yesterday I update my S.O but when I try to open a game in OpenGL It just don’t work.
I thought it was because of steam files or the game files. Reinstalling all but with no response.
pls help
check this before. I didn’t know about this before writing this issue
https://forum.manjaro.org/t/a-virus-need-a-rollback-urgent/131319
Does the GUI start ?
Can you post /var/log/Xorg.0.log ?
Yesterday I upgraded my O.S. I’m not very good at linux, I’m practically new. I did it through the package manager in “update all”.
Everything seems normal. but 3 packages were not installed. I found it strange. It was already night and I really didn’t care much. When I tried to “update” it told me something that I did not read completely. The point is that I download them. (press a button that said confirm and copy)
After that. This day when starting one of my games in steam this appeared
(steam:16943): LIBDBUSMENU-GLIB-WARNING **: 18:41:27.863: Trying to remove a child that doesn't believe we're it's parent.
(steam:16943): LIBDBUSMENU-GLIB-WARNING **: 18:41:27.864: Trying to remove a child that doesn't believe we're it's parent.
I have no idea if it was that or something in the game.
Everything was working as it should before the update
Edit: apparently this is a steam issue already seen before by the video drivers
opened 06:04AM - 13 Aug 14 UTC
closed 06:58PM - 13 Aug 14 UTC
duplicate
reviewed
Hi,
I'm not seeing any problems as far as the functionality of Steam, it appers… to be working fine.
I just wanted to report these messages just flood the console, after connected to Steam they just pour into the console without stopping...
Please let me know if you need my System Specs to troubleshoot this...
(steam:22405): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent.
pls help me to fix this
can you report , from terminal
inxi -Fza
sudo mhwd-kernel -li
sudo mhwd -li
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4e6d4124-3c79-44cd-b81d-205e2ece96d6 rw quiet splash apparmor=1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Gigabyte model: F2A68HM-H v: x.x serial: <superuser required>
BIOS: American Megatrends v: FC date: 01/19/2016
Info: model: AMD A6-6400K APU with Radeon HD Graphics bits: 64 type: MT MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 0x13 (19) stepping: 1 microcode: 0x6001119
Topology: cpus: 1x cores: 2 smt: enabled cache: L1: 96 KiB
desc: d-2x16 KiB; i-1x64 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 1897 high: 1967 min/max: 1800/3900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1967 2: 1828
bogomips: 15577
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Richland [Radeon HD 8470D] vendor: Gigabyte driver: radeon
v: kernel arch: TeraScale-3 code: Northern Islands process: TSMC 32nm
built: 2010-13 ports: active: VGA-1 empty: DVI-D-1,HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:9996 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :1 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: VGA-1 mapped: VGA-0 model: Lenovo L194 Wide serial: <filter>
built: 2008 res: 1440x900 dpi: 89 gamma: 1.2 size: 410x257mm (16.14x10.12")
diag: 484mm (19.1") ratio: 16:10 modes: max: 1440x900 min: 720x400
API: OpenGL v: 4.5 Mesa 22.3.1 renderer: AMD ARUBA (DRM 2.50.0 /
5.15.85-1-MANJARO LLVM 14.0.6) direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 65.91 GiB (7.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD1002FBYS-05A6B0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 1.5 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: NA01 scheme: MBR
ID-1: / raw-size: 407.16 GiB size: 399.7 GiB (98.17%)
used: 65.91 GiB (16.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 18.4 C mobo: N/A gpu: radeon temp: 6.0 C
Processes: 196 Uptime: 17m wakeups: 0 Memory: 6.73 GiB
used: 1.73 GiB (25.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1572 pm: dpkg
pkgs: 0 tools: apt,apt-get,gnome-software pm: pacman pkgs: 1564 libs: 469
tools: pamac pm: rpm pkgs: 0 pm: flatpak pkgs: 3 pm: snap pkgs: 5 Shell: Zsh
v: 5.9 running-in: gnome-terminal inxi: 3.3.24
Currently running: 5.15.85-1-MANJARO (linux515)
* linux515
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
I can’t find the directory
there is this point
can you return ( add if missing mesa-demo)
glxinfo | grep OpenGL
OpenGL vendor string: X.Org
OpenGL renderer string: AMD ARUBA (DRM 2.50.0 / 5.15.85-1-MANJARO, LLVM 14.0.6)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 22.3.1
OpenGL core profile shading language version string: 4.50
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.5 (Compatibility Profile) Mesa 22.3.1
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 22.3.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
rying display: wayland
Trying display: x11
vainfo: VA-API version: 1.16 (libva 2.16.0)
vainfo: Driver version: Mesa Gallium driver 22.3.1 for AMD ARUBA (DRM 2.50.0 / 5.15.85-1-MANJARO, LLVM 14.0.6)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
is gstreamer installed ?
sudo pacman -S manjaro-gstreamer
didn’t work. It’s still don’t open the game
FYI, the legacy radeon driver does not support Vulkan. Only the current amdgpu driver does. Since you have a Northern Islands card, in theory amdgpu should already be in use.
You may try installing the amdgpu-experimental package which accomplishes what is outlined here: AMDGPU - ArchWiki
If the reboot is not successful after installing the aforementioned package, switch to a TTY, remove it and reboot.
Do native Linux start on your computer ?
Like glxgears.
Doing it.
What it is TTY? Sorry for my ignorence.
