OpenGL 3.3 Rock Pi 4 Mali T860MP4 gpu
Hello.
I have a Rock Pi 4 C running Manjaro.
According to specifications, Rock Pi 4 has a Mali T860MP4 gpu.
I have try installed mesa drivers and mesa-git.
Is it possible to have hardware accelerated graphics and OpenGL 3.3?
right now glxgears runs about 70-80 FPS which is far from optimal
Going to provide a bit of info
Here is the info of inxi -Gazy
Device-1: display-subsystem driver: rockchip_drm v: N/A bus ID: N/A
chip ID: rockchip:display-subsystem
Device-2: rk3399-dw-hdmi driver: dwhdmi_rockchip v: N/A bus ID: N/A
chip ID: rockchip:ff940000
Device-3: rk3399-mali driver: panfrost v: kernel bus ID: N/A
chip ID: rockchip:ff9a0000
Display: server: X org 1.20.10 driver: modesetting alternate: fbdev
resolution:
OpenGL: renderer: llvmpipe (LLVM 11.1.0 128 bits)
v: 4.5 Mesa 21.1.0-devel (git-0a7224f3ff) compat-v: 3.1 direct render: Yes
Here is the info of glxinfo
name of display: :1001
display: :1001 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_no_error,
GLX_ARB_create_context_profile, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent,
GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Mesa/X.org (0xffffffff)
Device: llvmpipe (LLVM 11.1.0, 128 bits) (0xffffffff)
Version: 21.1.0
Accelerated: no
Video memory: 3860MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 3.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 11.1.0, 128 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 21.1.0-devel (git-0a7224f3ff)
OpenGL core profile shading language version string: 4.50
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_3DFX_texture_compression_FXT1, GL_AMD_conservative_depth,
GL_AMD_draw_buffers_blend, GL_AMD_gpu_shader_int64,
GL_AMD_multi_draw_indirect, GL_AMD_query_buffer_object,
GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
GL_AMD_shader_trinary_minmax, GL_AMD_texture_texture4,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_blend_func_extended,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_clip_control, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters,
GL_ARB_shader_bit_encoding, GL_ARB_shader_draw_parameters,
GL_ARB_shader_group_vote, GL_ARB_shader_image_load_store,
GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_stencil_export, GL_ARB_shader_storage_buffer_object,
GL_ARB_shader_subroutine, GL_ARB_shader_texture_image_samples,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_include, GL_ARB_shading_language_packing,
GL_ARB_spirv_extensions, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_tessellation_shader, GL_ARB_texture_barrier,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression_bptc,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ATI_blend_equation_separate,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXT_EGL_image_storage, GL_EXT_EGL_sync, GL_EXT_abgr,
GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_shader_framebuffer_fetch_non_coherent,
GL_EXT_shader_integer_mix, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_integer,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_R8,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shadow_lod,
GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
GL_EXT_vertex_array_bgra, GL_EXT_vertex_attrib_64bit,
GL_IBM_multimode_draw_arrays, GL_KHR_blend_equation_advanced,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_KHR_parallel_shader_compile, GL_KHR_robust_buffer_access_behavior,
GL_KHR_robustness, GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_framebuffer_flip_y,
GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
GL_MESA_texture_signed_rgba, GL_MESA_ycbcr_texture,
GL_NV_conditional_render, GL_NV_copy_image, GL_NV_depth_clamp,
GL_NV_packed_depth_stencil, GL_NV_texture_barrier, GL_OES_EGL_image,
GL_S3_s3tc
OpenGL version string: 3.1 Mesa 21.1.0-devel (git-0a7224f3ff)
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
    GL_AMD_draw_buffers_blend, GL_AMD_multi_draw_indirect,
    GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture,
    GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
    GL_AMD_texture_texture4, GL_ANGLE_texture_compression_dxt3,
    GL_ANGLE_texture_compression_dxt5, GL_APPLE_packed_pixels,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility,
    GL_ARB_clip_control, GL_ARB_color_buffer_float, GL_ARB_compatibility,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_depth_texture, GL_ARB_derivative_control,
    GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
    GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
    GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
    GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_spirv_extensions,
    GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_barrier,
    GL_ARB_texture_border_clamp, GL_ARB_texture_buffer_object,
    GL_ARB_texture_buffer_object_rgb32, GL_ARB_texture_buffer_range,
    GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
    GL_ARB_texture_stencil8, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_blend_equation_separate,
    GL_ATI_draw_buffers, GL_ATI_fragment_shader, GL_ATI_separate_stencil,
    GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
    GL_EXT_EGL_image_storage, GL_EXT_EGL_sync, GL_EXT_abgr, GL_EXT_bgra,
    GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
    GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
    GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
    GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
    GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color,
    GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_integer_mix,
    GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
    GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
    GL_EXT_texture_array, GL_EXT_texture_buffer_object,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
    GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
    GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_EXT_texture_integer, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
    GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_R8,
    GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control,
    GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
    GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
    GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
    GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
    GL_MESA_window_pos, GL_MESA_ycbcr_texture, GL_NV_blend_square,
    GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image,
    GL_NV_depth_clamp, GL_NV_fog_distance, GL_NV_half_float,
    GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
    GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.1.0-devel (git-0a7224f3ff)
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
    GL_ANDROID_extension_pack_es31a, GL_ANGLE_pack_reverse_row_order,
    GL_APPLE_texture_max_level, GL_EXT_EGL_image_storage,
    GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
    GL_EXT_buffer_storage, GL_EXT_clip_control, GL_EXT_clip_cull_distance,
    GL_EXT_color_buffer_float, GL_EXT_color_buffer_half_float,
    GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_copy_image,
    GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
    GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers,
    GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
    GL_EXT_draw_instanced, GL_EXT_float_blend, GL_EXT_frag_depth,
    GL_EXT_geometry_point_size, GL_EXT_geometry_shader, GL_EXT_gpu_shader5,
    GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
    GL_EXT_primitive_bounding_box, GL_EXT_read_format_bgra,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
    GL_EXT_separate_shader_objects,
    GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_group_vote,
    GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
    GL_EXT_shader_io_blocks, GL_EXT_tessellation_point_size,
    GL_EXT_tessellation_shader, GL_EXT_texture_border_clamp,
    GL_EXT_texture_buffer, GL_EXT_texture_compression_bptc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_s3tc_srgb,
    GL_EXT_texture_cube_map_array, GL_EXT_texture_format_BGRA8888,
    GL_EXT_texture_norm16, GL_EXT_texture_query_lod, GL_EXT_texture_rg,
    GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_RG8,
    GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_texture_view,
    GL_EXT_unpack_subimage, GL_KHR_blend_equation_advanced,
    GL_MESA_shader_integer_functions, GL_NV_conditional_render,
    GL_NV_draw_buffers, GL_NV_fbo_color_attachments, GL_NV_image_formats,
    GL_NV_pixel_buffer_object, GL_NV_read_buffer, GL_NV_read_depth,
    GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
    GL_OES_EGL_image_external, GL_OES_EGL_image_external_essl3,
    GL_OES_EGL_sync, GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image,
    GL_OES_depth24, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
    GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
    GL_OES_geometry_point_size, GL_OES_geometry_shader,
    GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
    GL_OES_required_internalformat, GL_OES_rgb8_rgba8, GL_OES_sample_shading,
    GL_OES_sample_variables, GL_OES_shader_image_atomic,
    GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation,
    GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
    GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
    GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer,
    GL_OES_texture_cube_map_array, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
    GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
    GL_OES_viewport_array
54 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0cc 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0cd 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0ce 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0cf 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0d4 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0d5 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0d6 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0d7 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0d8 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0d9 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0da 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0db 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0dc 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0dd 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0de 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0df 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0e4 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0e5 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0e6 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0e7 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0e8 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0e9 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0ea 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0eb 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0ec 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0ed 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0ee 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0f3 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0f4 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0f5 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0f6 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0f7 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0f8 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0f9 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0fa 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0fb 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0fc 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0fd 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0fe 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x103 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x104 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x105 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x106 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x107 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x108 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x109 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x10a 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x063 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x10b 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x10c 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x10f 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x110 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x111 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
70 GLXFBConfigs:
0x064  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x065  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x066  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x067  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x06c  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x06d  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x06e  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x06f  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x074 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x075 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x076 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x077 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x07c 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x07d 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x07e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x07f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x080 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x081 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x082 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x083 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x084 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x085 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x086 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x087 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x08c 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x08d 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x08e 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x08f 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x090 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x091 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x092 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x093 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x094  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x095  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x096  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x097  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x09c  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x09d  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x09e  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x09f  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0a4 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a5 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0a6 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a7 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0ac 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0ad 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0ae 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0af 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0b0 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0b1 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0b2 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0b3 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0b4 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0b5 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0b6 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0b7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0bc 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0bd 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0be 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0bf 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0c0 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c1 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0c2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0c4 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0c5 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0c8 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0c9 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0ca 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0cb 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
glxgears - LinuxReviews.
Use a real game instead. How many fps do you expect anyway? T860MP4 isn’t particularly a powerful GPU.
Okay. A couple of things.
  1. You seem to have something installed, that forces your GPU to use the software driver (llvm). Do you have xf86-video-fbturbo-git installed? If you do, please uninstall it and reboot.
  2. The Panfrost driver for the Midgard GPU generation, which is what’s present in the Rock Pi 4, only supports up to 3.1 in current mesa.
Hello.
I found the problem for hardware rendering as it was a missconfiguration on my X server.
Thanks for the info about the current status of Mesa I guess we just need to wait for further development then :slight_smile:
In addition, is it possible to get vulkan support for Mali T860?
nevermind I just read that Panfrost does not support vulkan yet…
