Hello, I was using openconnect-sso to connect to my complay’s SAML secured vpn with no issues until about 2 weeks ago when it stopped working. I was experimenting with the git and non git versions on AUR and OfficialRepos but without success.
When I try and login from the terminal using openconnect-sso -s vpn.server.de
I get following error output:
Connected to 93.....ip
SSL negotiation with vpn.server.de
Server certificate verify failed: signer not found
Connected to HTTPS on vpn.server.de with ciphersuite (blabla)
Got inappropriate HTTP CONNECT response: HTTP/1.1 401 Unauthorized
Creating SSL connection failed
Cookie was rejected by server; exiting.
I can login to the server from Windows anyconnect whith no problem. Any ideas what can be the issue?
Kernel Info: 6.1.80-1-MANJARO
